On Mon, 18 Jun 2007 13:49:59 -0700, "RST Engineering"
wrote: I thought I had this compressor power thing down to a pretty good science until they started screwing around with "rated watts" and "peak power" and all that crap that makes their compressor look really good until you go to use it. Back when we were using "real" horsepower I used a figure of 750 (to make it easy to calculate, I believe 746 is the actual number) watts per horsepower and an efficiency factor of 85% so that a one horse motor would take 860 watts to do the actual work. But then you multiplied that times two for "starting" wattage for a couple of seconds to give 1725 watts under start and then times three for starting under some volume of air left in the compressor reservoir or about 2600 watts. That presses my 2200 watt continuous duty (2800 watts peak) fairly close to the load limit, but certainly gives a margin for error that seems reasonable. Before I tell elebendy bazillion Kitplanes readers that the Harbor Freight Subaru 2200 watt generator will drive the Sears 1 horse compressor (and even worse, buy the Sears compressor only to not have it work), will somebody please do a reality check on me for horsepower/watts for this lashup. (Note ... convert watts to amperes by dividing watts by 120 volts). 860w=7a 1725w=14a 2600w=21a Sears and Harbor Freight are damned near clueless about this sort of stuff. If anybody has a source I can reference for running/starting/starting under load for air compressors it would be well received. I'd LIKE to buy a 3/4 horse compressor but they go from the kiddie's 1/4 horse toy straight to one horse with darned little in between. Jim Jim, Living off-grid, and generating most of my own power from renewables, I am somewhat familiar with your issue. Although your approach may make theoretical sense, in the real world (as you found out) it frequently doesn't work. The startup surge for an electric motor is given by a parameter called "locked rotor amps" (means pretty much what it says). This can either be measured (with a clamp-on ammeter), or derived from a letter on the nameplate of the actual motor multiplied by the running amps. A compressor is one of the more difficult devices to start. Without specific data, I would figure starting amps to be at least five times the nameplate amperage rating. Fugedabout trying to convert nameplate HP to startup surge. It might be less, or not. So far as your generator is concerned, it is likely that the ratings assume a power factor of 1. But an induction motor, such as is in your compressor, will have a power factor considerably less than 1. This further increases the amount of "real power" the generator must supply. And may also explain why the nameplate amperage rating seems higher than what you predict by using HP and an assumed efficiency. I happen to have a Sears 1HP compressor (1.5HP Peak). Mine has a nameplate rating of 10.5A @ 120V. I could not see/locate the nameplate on the motor itself, so I figured a 52.5A startup surge (5X). My inverter has a 78A peak capacity (46A continuous) so I figured things would work -- and they have. Your 2800W peak generator translates to 23.3A at 120VAC. If you have the same Sears compressor as I do, I'm not surprised that the generator will have a problem starting it. Another issue that comes up with compressors has to do with flat spots on the rotor as they age. This causes them to draw the locked rotor amp startup current for a longer period of time when new. This can also cause an otherwise adequately sized system to "blow" on startup, occasionally. --ron |
On Jun 24, 5:20 am, Ron Rosenfeld wrote:
... Ron, what peak starting current should I expect on a single-phase, 240V, 3/4h.p., running current=7.8A motor used to lift my hangar door? I want to rig up a genny to lift the door during a power failure. The gear train on the door is rigged so that all of the cables are slack (i.e. only motor inertial) when the motor starts. |
![]() "Ron Rosenfeld" wrote A problem with small, inexpensive, gasoline fueled generators is that, unless you are religious about exercising them, they usually won't start when you need them. An exception to that rule is a Honda generator. I'm not a foreign car guy, or anything like that; quite the opposite. My dad had one that would sit for a couple of years, and it would start on the first or second pull, with fresh gas in the tank. It is amazing how many other uses come up, once you have a generator sitting around. -- Jim in NC |
On Wed, 27 Jun 2007 01:05:26 -0400, "Morgans"
wrote: "Ron Rosenfeld" wrote A problem with small, inexpensive, gasoline fueled generators is that, unless you are religious about exercising them, they usually won't start when you need them. An exception to that rule is a Honda generator. I'm not a foreign car guy, or anything like that; quite the opposite. My dad had one that would sit for a couple of years, and it would start on the first or second pull, with fresh gas in the tank. It is amazing how many other uses come up, once you have a generator sitting around. Mine is 9500 watts continuous. It doesn't even have the option of a pull starter. I don't think I could pull it even if it did. I keep the tank full. When I shut it down I turn the gas off and let it dry out the carb. It's on wheels, but it'd take a truck to haul it so it could be called portable. OTOH it'd take three and preferably four men to put it in the truck. If it were in the shop I could do that with an engine hoist. I fire it up about every other month and let it run for about 10 minutes. In the winter I have to keep a small heat lamp on the battery. It'll run about 10 to 12 hours powering the whole house sans air conditioner (except for the little spare one stuck in the bedroom window) on 10 gallons. I had a little 4000 watt Coleman that used twice as much gas, but it was kinda portable and made a whole lot more noise. I purchased it new, *after* Y2K when there were lots of them available at half price and less. In the last 6 1/2 years I have well over 100 hours on it powering the house. Lots of power outages due to poor line maintenance and we are about 2 miles from the city limits and just over a mile from the substation. As for other uses, with help I some times pull it out of the generator shed and use it to power my 180 amp MIG welder. It's been a while but IIRC the engine doesn't even change pitch when welding. |
On Wed, 27 Jun 2007 01:25:27 -0400, "Roger (K8RI)"
wrote: On Wed, 27 Jun 2007 01:05:26 -0400, "Morgans" wrote: "Ron Rosenfeld" wrote A problem with small, inexpensive, gasoline fueled generators is that, unless you are religious about exercising them, they usually won't start when you need them. An exception to that rule is a Honda generator. I'm not a foreign car guy, or anything like that; quite the opposite. My dad had one that would sit for a couple of years, and it would start on the first or second pull, with fresh gas in the tank. It is amazing how many other uses come up, once you have a generator sitting around. Mine is 9500 watts continuous. It doesn't even have the option of a pull starter. I don't think I could pull it even if it did. I keep the tank full. When I shut it down I turn the gas off and let it dry out the carb. It's on wheels, but it'd take a truck to haul it so it could be called portable. OTOH it'd take three and preferably four men to put it in the truck. If it were in the shop I could do that with an engine hoist. I fire it up about every other month and let it run for about 10 minutes. In the winter I have to keep a small heat lamp on the battery. It'll run about 10 to 12 hours powering the whole house sans air conditioner (except for the little spare one stuck in the bedroom window) on 10 gallons. I had a little 4000 watt Coleman that used twice as much gas, but it was kinda portable and made a whole lot more noise. I purchased it new, *after* Y2K when there were lots of them available at half price and less. In the last 6 1/2 years I have well over 100 hours on it powering the house. Lots of power outages due to poor line maintenance and we are about 2 miles from the city limits and just over a mile from the substation. As for other uses, with help I some times pull it out of the generator shed and use it to power my 180 amp MIG welder. It's been a while but IIRC the engine doesn't even change pitch when welding. You might want to mention your isolation switch. Don |
On Tue, 26 Jun 2007 22:34:34 -0700, Don Tuite
wrote: On Wed, 27 Jun 2007 01:25:27 -0400, "Roger (K8RI)" wrote: On Wed, 27 Jun 2007 01:05:26 -0400, "Morgans" wrote: "Ron Rosenfeld" wrote A problem with small, inexpensive, gasoline fueled generators is that, unless you are religious about exercising them, they usually won't start when you need them. An exception to that rule is a Honda generator. I'm not a foreign car guy, or anything like that; quite the opposite. My dad had one that would sit for a couple of years, and it would start on the first or second pull, with fresh gas in the tank. It is amazing how many other uses come up, once you have a generator sitting around. Mine is 9500 watts continuous. It doesn't even have the option of a pull starter. I don't think I could pull it even if it did. I keep the tank full. When I shut it down I turn the gas off and let it dry out the carb. It's on wheels, but it'd take a truck to haul it so it could be called portable. OTOH it'd take three and preferably four men to put it in the truck. If it were in the shop I could do that with an engine hoist. I fire it up about every other month and let it run for about 10 minutes. In the winter I have to keep a small heat lamp on the battery. It'll run about 10 to 12 hours powering the whole house sans air conditioner (except for the little spare one stuck in the bedroom window) on 10 gallons. I had a little 4000 watt Coleman that used twice as much gas, but it was kinda portable and made a whole lot more noise. I purchased it new, *after* Y2K when there were lots of them available at half price and less. In the last 6 1/2 years I have well over 100 hours on it powering the house. Lots of power outages due to poor line maintenance and we are about 2 miles from the city limits and just over a mile from the substation. As for other uses, with help I some times pull it out of the generator shed and use it to power my 180 amp MIG welder. It's been a while but IIRC the engine doesn't even change pitch when welding. You might want to mention your isolation switch. Ohhh...yahhh...Power companies get kinda excited about those. I took a pair a big breakers and built a sliding connector between the handles based on one I saw on a commercial transfer switch. If you turn one on the other turns off first, but your can turn one off without turning the other on. So, I fire up the generator and by the time I can walk from the shed, around the end of the house, through the garage and then down stairs the engine is warmed up enough for me to throw the transfer switch. I left a coupe circuits on the mains panel so when the power comes back on those lights come on to let me know I can go switch back to the mains for power. I usually wait about 5 minutes before switching and another 5 before shutting the generator down. It'd be nice to have one of the fully automated systems that runs on natural gas, which would be a lot quieter and cheaper to run, but the initial cost would be about 10 times what I have in this system. Don |
wrote: "Ron Rosenfeld" wrote A problem with small, inexpensive, gasoline fueled generators is that, unless you are religious about exercising them, they usually won't start when you need them. An exception to that rule is a Honda generator. I'm not a foreign car guy, or anything like that; quite the opposite. My dad had one that would sit for a couple of years, and it would start on the first or second pull, with fresh gas in the tank. It is amazing how many other uses come up, once you have a generator sitting around. One problem is that frequently, after sitting around for a few years, there isn't fresh gas in the tank! (I should have been more specific as to the reasons). --ron |
One problem is that frequently, after sitting around for a few years, there isn't fresh gas in the tank! (I should have been more specific as to the reasons). --ron My 40kw runs on Natural Gas or Liquid Propane and is configured to automatically switch between them. No worries about fuel geauxing bad from evaporation or sucking moisture out of the air. Course those fuels aren't cheap either, but it sure cuts down on the hassle factor of trying to buy gasoline/diesel when all the retailers don't have power for any length of time... Spent over 60 hours on a 5.5kw due to hurricane Lili (6 gallon tank, used 90 gallons), it eventually burned the muffler off (bought it new in '85). Needed the 40kw for only 18 hours during/after Rita (didn't even get a drop of rain from Katrina) and it makes my UPS's very happy too when needed. Now I can cook and enjoy airconditioned comfort while my neighbors ice boxes are also plugged in as well... If I had to buy another portable, NG/Propane would definitely be high on the list for compatible fuels. Just remember you lose some power output when using those for fuel... |
On Wed, 27 Jun 2007 13:56:07 GMT, Darrel Toepfer
wrote: Ron Rosenfeld wrote: One problem is that frequently, after sitting around for a few years, there isn't fresh gas in the tank! (I should have been more specific as to the reasons). --ron My 40kw runs on Natural Gas or Liquid Propane and is configured to automatically switch between them. No worries about fuel geauxing bad from evaporation or sucking moisture out of the air. Course those fuels aren't cheap either, but it sure cuts down on the hassle factor of trying to buy gasoline/diesel when all the retailers don't have power for any length of time... Spent over 60 hours on a 5.5kw due to hurricane Lili (6 gallon tank, used 90 gallons), it eventually burned the muffler off (bought it new in '85). Needed the 40kw for only 18 hours during/after Rita (didn't even get a drop of rain from Katrina) and it makes my UPS's very happy too when needed. Now I can cook and enjoy airconditioned comfort while my neighbors ice boxes are also plugged in as well... If I had to buy another portable, NG/Propane would definitely be high on the list for compatible fuels. Just remember you lose some power output when using those for fuel... My backup generator is a 12kW unit; runs on propane and I have a 500 gallon tank which is usually 60-80% full (also supplies propane for heat, DHW, cooking, clothes dryer). It automatically runs for 10 minutes every 10 days, and has never failed to start. In the winter, I preheat it for an hour or two with electricity -- also automatic. I have a 5.5 kW gasoline unit sitting around. The last time someone asked to borrow it, it took him four or five hours to get it started, and then I think he could only use the 115V tap -- not the 230. --ron |
Air Compressor Horsepower/Wattage/Amperage | RST Engineering | Owning | 32 | June 30th 07 12:47 AM |
more horsepower | T-Bone | Piloting | 11 | March 20th 06 10:56 PM |
Lycoming Horsepower Calculation? | Mark Doble | Home Built | 1 | June 20th 05 10:46 PM |
Thermals and Horsepower | Ken Kochanski (KK) | Soaring | 14 | January 9th 05 05:50 PM |
Horsepower | Andre | Home Built | 3 | July 18th 03 10:50 AM |
