![]() The reason that there aren't white LED lamps is the same reason that there aren't battery-electric airplanes. ![]() light, fluorescent lamps are just about the most efficient thing around. To make money, LEDs have to beat fluorescents and they aren't quite there yet - but probably will get there within the next few years. Matt Roberds Matt, Actually, that's not quite true. LEDs have just hit efficiencies of 90 lumens per watt, which is comparable to compact fluorescent. The biggest barrier to LED light bulbs right now is cost, but that should also change soon. Dean |
![]() wrote: The reason that there aren't white LED lamps is the same reason that there aren't battery-electric airplanes. ![]() light, fluorescent lamps are just about the most efficient thing around. To make money, LEDs have to beat fluorescents and they aren't quite there yet - but probably will get there within the next few years. Actually, that's not quite true. LEDs have just hit efficiencies of 90 lumens per watt, which is comparable to compact fluorescent. According to Klipstein (probably the most knowledgeable person on the subject of lighting that I know) CFLs are still down at around 55-60 lm/w. Only 32FT8 fluorescents are up in the 90+ lm/w range. (See upcoming November KP article or the Monday Oshkosh forum.) The below by Matt is also true. Lab conditions and home workshops are not in the same league. Jim In a lab, with a junction temperature of 25 C (in other words, on a heat sink with Freon running through it.) ![]() your grandmother can buy and install in her kitchen is still a ways off. I have no doubt it's coming but it's not here yet. Matt Roberds |
On Jun 25, 12:50 pm, wrote:
wrote: wrote: The reason that there aren't white LED lamps is the same reason that there aren't battery-electric airplanes. ![]() light, fluorescent lamps are just about the most efficient thing around. To make money, LEDs have to beat fluorescents and they aren't quite there yet - but probably will get there within the next few years. Actually, that's not quite true. LEDs have just hit efficiencies of 90 lumens per watt, which is comparable to compact fluorescent. In a lab, with a junction temperature of 25 C (in other words, on a heat sink with Freon running through it.) ![]() your grandmother can buy and install in her kitchen is still a ways off. I have no doubt it's coming but it's not here yet. Matt Roberds If you say so... ![]() |
old days | Airman | Rotorcraft | 23 | January 2nd 07 01:36 PM |
Dynamite bought the twin towers down say 73 top professors...I get it, you'll wait till you hear it from Katie Couric. | [email protected] | Piloting | 39 | September 13th 06 06:04 PM |
Just a few more days | Louis L. Perley III | Owning | 1 | December 31st 04 01:36 PM |
Two bad days... | Yeff | Military Aviation | 0 | July 3rd 04 09:31 PM |
Meigs, its not over till its over... | Stuart King | Instrument Flight Rules | 1 | October 22nd 03 04:08 PM |
