... On Sun, 24 Jun 2007 16:36:11 -0000, wrote: seems to me the owner's manual on our Mooney says limits are 60 degrees bank and 30 degrees pitch. It also says the airplane should not be spun. I could be wrong about that. No, you are undoubtedly right. But there is no such thing as being "certified for 60 degree pitch." The manufacturer can place any warning they wish in the manual, but that's not the same as certification. The airplane is certified in the normal (or utility) category, in the aerobatic category. But this is a *G* limit, not an overt certification limit on bank or pitch angle. If Mooney said the limits are 59 degrees bank and 29 degrees pitch, that STILL wouldn't make it a "certification" limit. From what I can tell, Part 91's only comment about aerobatics is that you have to wear a 'chute...it doesn't seem to care about the certification category of the aircraft. The 91.13 catch-all undoubtedly works, though. As for practice of these manouvers? Do whatever you like. Probably it would not be wise to post here, though, except as a hypothetical question. There's nothing like a written record to influence courts or insurance companies. Well, let's get this out of the way, then. I regularly exceed 30 degrees of pitch in my US-registered aircraft, despite the airplane not being certified in the aerobatic category. My 25-year-old airplane has never undergone an annual inspection. I haven't held a medical for about four years, yet I hold a Private Pilot license and fly my N-numbered aircraft regularly. I'll just sit here and wait for the subpoenas and insurance cancellations, then.... Ron Wanttaja Actually, this explains a lot that had been made a little confusing by some of the discussions which I had heard. In other words, just as a type certif ied aircraft which falls within the LSA limitations of weight, speed and configuration; the same is true for an amateur built experimental with the appropriate operating limitations. That leaves one question about which I am still curious. Do you happen to know what pilot rating and medical certification requirements would exist for the initial pilot of a new amateur built experimental (or a new design) expected to comply with the LSA definitions. Thanks, Peter |
On Sun, 24 Jun 2007 19:51:58 -0400, "Peter Dohm" wrote:
That leaves one question about which I am still curious. Do you happen to know what pilot rating and medical certification requirements would exist for the initial pilot of a new amateur built experimental (or a new design) expected to comply with the LSA definitions. The FAA made this a bit more confusing than they had to. A couple years back, they developed a *definition* of a "Light Sport Aircraft," at the same time they developed two new certification categories, both with "Light Sport Aircraft" in the names (Special Light Sport Aircraft and Experimental Light Sport Aircraft). If an airplane meets the Light Sport Aircraft *definition*, then it can be flown by anyone with a Sport Pilot license or higher. If the aircraft meets the *definition*, a person with a Recreational/Private/Commercial/ATP license and a valid Class III medical or higher may fly the airplane. The same individuals may instead use a valid state drivers license in lieu of the standard medical, PROVIDING their last medical "died a natural death" (e.g., just expired rather than getting canceled) and they have not failed an FAA medical since. It's like the "fourth step" in the standard FAA medical. You can fly operations requiring a Class I for six months, then fly in operations only requiring a Class II for the NEXT six months, and finally can execute Private Pilot privileges for the next year. After that you, you can be a "Private Pilot executing Sport Pilot privileges" for as long as you have a driver's license and DON'T flunk an FAA medical. The certification status of the airplane is immaterial...it can be normal category, utility, aerobatic, experimental, limited, etc. If it *meets* the Light Sport Aircraft definition, a Private Pilot can execute Sport Pilot privileges and use a driver's license in lieu of a medical. The specific aircraft certification categories (Special LSA and Experimental LSA) implement simplified processes to gain airworthiness certificates and simplified maintenance requirements. I've got more details on my Fly Baby web page: http://www.bowersflybaby.com/tech/lsa.html Ron Wanttaja |
Somebody Terrified of Compound Curves ---- Or Just Lazy | Larry Smith | Home Built | 8 | October 31st 03 02:40 PM |
"Lazy Dogs" | Mike Yared | Naval Aviation | 1 | August 15th 03 06:00 PM |
