Fuel tank foam
  #11
Old June 26th 07, 08:06 PM posted to rec.aviation.homebuilt
Stuart & Kathryn Fields
Default Fuel tank foam
I have a couple of baffles already, but having 28 gal 100LL just behind my
head makes my nerves twitch just a bit. Having the foam is supposed to make
explosive conflagration less likely in case of a prang.
Thanks
Stuart & Kathryn Fields, Publishers
Experimental Helo magazine
P. O. Box 1585
Inyokern, CA 93527
(760) 377-4478 ph
(760) 408-9747 publication cell
(760) 608-1299 technical cell
www.experimentalhelo.com
www.vkss.com
"Maxwell" wrote in message
"Stuart & Kathryn Fields" wrote in message
Is there anyone out there using fuel tanks filled with open cell foam?
I've heard that explosions are tamed as well as fuel slosh. I've also
heard that the foam must be replaced periodically. How often is the
replacement necessary? I'm using 100LL Av gas.
Perhaps a few metal baffels would be a better choice.
Saturn V S-IC-T (static test stage) fuel tank assembly is mated to the liquid oxygen (LOX) tank 6416666.jpg [email protected] Aviation Photos 0 April 12th 07 02:33 AM
Fuel tank balance Mxsmanic Piloting 101 October 3rd 06 08:56 AM
fuel tank plumbing pwm Home Built 18 January 27th 05 05:54 AM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 03:57 AM
blue foam, pink foam, yellow foam? Corrie Home Built 26 September 1st 03 06:01 PM
