On Tue, 26 Jun 2007 17:45:51 -0500, "Dan Luke"
wrote: "Peter Clark" wrote: The GIA2. The GIAs have been swapped and the problem stays. Sounds like at this point they're going to have to build a harness and ring out the graycode lines end-to-end from the GIA2 output through to the AP computer connector individually. If both GIAs are producing the issue and two AP computers are doing it, there's got to be something going wrong in the harness. It's all that's left.. Seems logical to me. The tech says he is talking to Garmin about the possibility that it is a software problem, although I cannot imagine how such a thing could appear in only one of many identical airplanes. Faulty memory chip, maybe? In two different GIAs and two different KAP140s? It seems rather remote that all four componants would have a software problem that only manifests itself on the one airframe. I think realistically it's down to there being a short somewhere. I've not jacked into a KAP140 for quite a while so I don't remember if there's a diagnostic page which shows the decoded input gray code, but one way for them to try and isolate which wires on the harness are bad would be to pump the aircraft up and see if the gray code as shown by the altimeter and gray code as decoded by the KAP140 A) correlate and B) change with the test set's altitude. Knowing which wires should be hot for a given pressure will let you know which ones are bad. Have they tried hooking up the pitot/staic testset and pumping it up? |
![]() "Peter Clark" wrote: Have they tried hooking up the pitot/staic testset and pumping it up? Don't know. They're getting complete schematics from Garmin for further trouble shooting. -- Dan T-182T at BFM |
On Tue, 26 Jun 2007 19:43:58 -0500, "Dan Luke"
wrote: "Peter Clark" wrote: Have they tried hooking up the pitot/staic testset and pumping it up? Don't know. They're getting complete schematics from Garmin for further trouble shooting. The baseline schematics from Garmin won't neccessarily match how Cessna has it set up. They should be looking at the wiring diagrams on the Cessna maintenance manual CD. Have they called Cessna about this? |
![]() "Peter Clark" wrote: Don't know. They're getting complete schematics from Garmin for further trouble shooting. The baseline schematics from Garmin won't neccessarily match how Cessna has it set up. They should be looking at the wiring diagrams on the Cessna maintenance manual CD. Have they called Cessna about this? That's the same thing John Jones on the CPA forum said. I'll ask them tomorrow. -- Dan T-182T at BFM |
Posting Trouble | Cody Dawg | Piloting | 3 | November 29th 06 08:06 PM |
Tie Down Trouble | Dylan Smith | Piloting | 16 | May 20th 06 09:47 PM |
XM financial trouble | [email protected] | Instrument Flight Rules | 21 | March 22nd 06 05:09 PM |
Delta in trouble | DrunkKlingon | Piloting | 1 | April 22nd 05 07:21 PM |
A little engine trouble | Peter Duniho | Piloting | 29 | June 17th 04 07:29 PM |
