Air Compressor Horsepower/Wattage/Amperage
Old June 27th 07, 06:25 AM posted to rec.aviation.homebuilt,rec.aviation.owning
Roger (K8RI)
Default Air Compressor Horsepower/Wattage/Amperage
On Wed, 27 Jun 2007 01:05:26 -0400, "Morgans"
"Ron Rosenfeld" wrote
A problem with small, inexpensive, gasoline fueled generators is that,
unless you are religious about exercising them, they usually won't start
when you need them.
An exception to that rule is a Honda generator. I'm not a foreign car guy,
or anything like that; quite the opposite. My dad had one that would sit
for a couple of years, and it would start on the first or second pull, with
fresh gas in the tank.
It is amazing how many other uses come up, once you have a generator sitting
around.
Mine is 9500 watts continuous. It doesn't even have the option of a
pull starter. I don't think I could pull it even if it did. I keep
the tank full. When I shut it down I turn the gas off and let it dry
out the carb. It's on wheels, but it'd take a truck to haul it so it
could be called portable. OTOH it'd take three and preferably four men
to put it in the truck. If it were in the shop I could do that with
an engine hoist. I fire it up about every other month and let it run
for about 10 minutes. In the winter I have to keep a small heat lamp
on the battery. It'll run about 10 to 12 hours powering the whole
house sans air conditioner (except for the little spare one stuck in
the bedroom window) on 10 gallons. I had a little 4000 watt Coleman
that used twice as much gas, but it was kinda portable and made a
whole lot more noise.
I purchased it new, *after* Y2K when there were lots of them available
at half price and less. In the last 6 1/2 years I have well over
100 hours on it powering the house. Lots of power outages due to poor
line maintenance and we are about 2 miles from the city limits and
just over a mile from the substation.
As for other uses, with help I some times pull it out of the generator
shed and use it to power my 180 amp MIG welder. It's been a while but
IIRC the engine doesn't even change pitch when welding.
Old June 27th 07, 06:34 AM posted to rec.aviation.homebuilt,rec.aviation.owning
Don Tuite
On Wed, 27 Jun 2007 01:25:27 -0400, "Roger (K8RI)"
when you need them.
around.
You might want to mention your isolation switch.
Don
Old June 28th 07, 01:06 AM posted to rec.aviation.homebuilt,rec.aviation.owning
Roger (K8RI)
On Tue, 26 Jun 2007 22:34:34 -0700, Don Tuite
when you need them.
around.
Ohhh...yahhh...Power companies get kinda excited about those.
I took a pair a big breakers and built a sliding connector between the
handles based on one I saw on a commercial transfer switch. If you
turn one on the other turns off first, but your can turn one off
without turning the other on. So, I fire up the generator and by the
time I can walk from the shed, around the end of the house, through
the garage and then down stairs the engine is warmed up enough for me
to throw the transfer switch. I left a coupe circuits on the mains
panel so when the power comes back on those lights come on to let me
know I can go switch back to the mains for power. I usually wait
about 5 minutes before switching and another 5 before shutting the
generator down. It'd be nice to have one of the fully automated
systems that runs on natural gas, which would be a lot quieter and
cheaper to run, but the initial cost would be about 10 times what I
have in this system.
Don
Air Compressor Horsepower/Wattage/Amperage RST Engineering Owning 32 June 30th 07 12:47 AM
more horsepower T-Bone Piloting 11 March 20th 06 10:56 PM
Lycoming Horsepower Calculation? Mark Doble Home Built 1 June 20th 05 10:46 PM
Thermals and Horsepower Ken Kochanski (KK) Soaring 14 January 9th 05 05:50 PM
Horsepower Andre Home Built 3 July 18th 03 10:50 AM
