On 27 Jun, 09:47, Chris Reed wrote:
Ian wrote: What about the Oly which clapped its wings as a result of an overspeed winch launch at - iirc - Sutton Bank? The accident report put the cause as severe corrosion of the spar end metal fittings. Certainly a factor, but if it hadn't oversped (overspeeded?) on launch, it wouldn't have failed. Well, not then, anyway. I knew of a Ka6 which pushed over so violently after a cable break that it landed afterwards - for the last time - with significant anhedral. OK, nothing to do with overspeeding, but a salutory tale illustrating something or other. Ian |
![]() "Ian" wrote in message oups.com... On 27 Jun, 09:47, Chris Reed wrote: Ian wrote: What about the Oly which clapped its wings as a result of an overspeed winch launch at - iirc - Sutton Bank? The accident report put the cause as severe corrosion of the spar end metal fittings. Certainly a factor, but if it hadn't oversped (overspeeded?) on launch, it wouldn't have failed. Well, not then, anyway. Well, that is pure speculation, isn't it ? |
On 27 Jun, 12:57, "Bert Willing" willing_no_spam_ple...@ir-
microsystems.com wrote: "Ian" wrote in message Certainly a factor, but if it hadn't oversped (overspeeded?) on launch, it wouldn't have failed. Well, not then, anyway. Well, that is pure speculation, isn't it ? My understanding was that the failure which occurred was deemed to be a result of structural problems triggered by overspeed. I am happy to be corrected if I am misremembering - I can't find accident reports on the BGA website any more to check. A friend of mine has an Oly which has been grounded for ever for this reason - the glue in the aluminium/wood/aluminium sandwich spar has seriously deteriorated and is beyond economic repair. He was winching it quite happily until the accident happened. Ian |
Ian,
Looks like we both recall correctly but incompletely. The AAIB report of the 1996 accident, at http://www.aaib.dft.gov.uk/cms_resou...pdf_502118.pdf states: "Several witnesses formed the opinion that this launch was faster and less steep than normal, the launches already being considered, by several witnesses, as being fast that day. One witness reported the presence of a strong wind gradient, the surface wind being 5/10 kt. At a height variously estimated by witnesses of between 600 and 700 feet the glider was seen to 'speed- up' and its climb angle reduce. At about this time, and whilst still in a nose high attitude and connected to the cable, several relatively rapid oscillations in pitch occurred. One witness estimated these to be as much as 15°, with the wings being seen to 'flex' correspondingly an abnormal amount. At about this point, the airbrakes were seen to briefly deploy. Almost immediately, they deployed again, this time coincident with the right wing failing in an upwards and rearwards direction, pivoting about its root end and releasing a cloud of debris." A doubled weak link was used, which could have allowed excessive loads on the airframe in previous launches and in this one. Part of the conclusion was: "In view of the fact that the corrosion had developed over a long period of time, during which the glider had been launched and flown without incident, and that the aircraft had been launched by winch earlier on the same day in similar conditions by the same pilot, it is considered probable that excessive loads were induced on this occasion. This, in turn, exploited the degraded strength of the wing spar, resulting in the upper spar boom collapse in the right wing." I read this as saying that continued overstressing on a weakened structure led to the failure, with that days's overstress being the final straw. The report says that other gliders flying from the same airfield had probably been overloaded. Only this one failed structurally, because of the corrosion. As I wrote before, flying outside the envelope takes one into uncharted territory. However, overspeeding on its own does not necessarily do so - it depends on how the pilot flies the launch and when the launch is abandoned. To summarise how I understand the UK training: 1. If overspeed is clearly excessive from the outset, release and land ahead if possible. If not possible to land ahead, see (3). 2. If moderately excessive in the lower 1/3 of the launch, give a chance for it to settle down and if not, signal too fast. 3. If it doesn't settle down, reduce the load on the airframe through a shallow rate of climb and release once a safe height is achieved. 4. Overspeed in the top 1/3 of the launch is potentially dangerous as the glider is under its highest load at that point, and cumulative overstress can lead to failure particularly if the structure is already weakened. 5. Too slow is more dangerous than too fast, provided you fly the fast launch so as not to overstress the airframe. I'd add that all suspicions of corrosion, overstress through excessive g, etc. need to be checked out by a qualified person. |
On Jun 27, 6:49 pm, Chris Reed wrote:
Ian, Looks like we both recall correctly but incompletely. The AAIB report of the 1996 accident, athttp://www.aaib.dft.gov.uk/cms_resources/dft_avsafety_pdf_502118.pd fstates... Sorry folks, I've just repeated some of what Chris posted, didn't notice that the conversation had "gone over the page". However, Chris does seem to be intimating that it's possible to structurally damage a glider during a winch launch from overspeeding. Providing the correct weak is used, that is not possible. Old myths die hard though. Dan |
Dan G wrote:
However, Chris does seem to be intimating that it's possible to structurally damage a glider during a winch launch from overspeeding. Providing the correct weak is used, that is not possible. Old myths die hard though. Apologies - didn't mean to intimate that. All I was trying to say is that overspeeding is not dangerous per se, but might become so depending on the condition of your glider, where you are in the launch and how you fly it. So far as structural damage is concerned, the only example we have is from an already damaged glider, so you may well be right that with the correct weak link you're protected from structural damage. However, I still refuse to accept overspeeding in the top 1/3 of the launch because (a) the glider is not designed for it, even if it won't fall apart, (b) I don't know whether my glider's structure has been invisibly weakened by past overspeeding, groundloops, etc, and (c) I can safely do something about it (bye bye cable). Below that, I'm prepared to try to sort out the situation unless it's clearly irredeemable. Of course, much depends on what you mean by overspeeding. 2kt over max winch is within the margin of error. 20kt over is far too much to live with all the way to the top. |
On 28 Jun, 21:23, Dan G wrote:
However, Chris does seem to be intimating that it's possible to structurally damage a glider during a winch launch from overspeeding. Providing the correct weak is used, that is not possible. Old myths die hard though. Why, then, is the winch launch maximum speed not Vne? Ian |
the Oz 3 surface trainer | patrick mitchel | Home Built | 2 | May 15th 07 03:19 AM |
WTB Trainer | Roy Bourgeois | Soaring | 0 | June 25th 06 04:50 PM |
***XC-Trainer Offer*** | [email protected] | Soaring | 0 | August 24th 05 05:21 PM |
AMD Alarus IFR Trainer | H.P. | Owning | 0 | August 5th 04 07:10 PM |
AMD Alarus IFR Trainer | H.P. | Piloting | 0 | August 5th 04 07:10 PM |
