Fear of flying cross country
Old June 29th 07, 04:06 PM posted to rec.aviation.soaring
Martin Gregorie[_1_]
Default Fear of flying cross country
ContestID67 wrote:
4) Equipment - Take you mind off navigation by flying with GPS. That
frees you to find that lift!!
An addition to that.
This applies if you carry a GPS and GPS-aware vario (one that can
compute final glides to a GPS way point. When you're local soaring make
sure both are running and that the GPS has your home field set as its
current way point. You can use the information these provide to push out
toward the glide angle limit and get a good feeling for being well away
from your home field, gain familiarity with the instruments and get to
know the wider local area. You'll also get a good feeling for how far
your glider can go from various heights. Just make sure you have a
conservative safety height set in the vario and have taken the trouble
to match its settings to your glider's polar.
I have an SDI C4 and a GPS II+ in my Std Libelle. If I'm soaring locally
rather than going XC this is the way I operate. Besides, doing this is a
lot more interesting that flapping round just outside the circuit.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Cross Country again! Michelle Piloting 10 August 6th 06 06:45 PM
FA : VFR Cross-Country Flying video BTB Aviation Marketplace 0 May 16th 05 02:29 AM
Cross country in the 1-34 mat Redsell Soaring 3 October 22nd 04 04:56 PM
51.2 Hours Cross Country PIC, NW_PILOT Piloting 6 July 3rd 04 03:02 AM
A 4,200 NM cross-country Phil Verghese Piloting 0 September 1st 03 10:03 PM
