On Mon, 2 Jul 2007 16:35:20 -0400, "Peter R."
wrote in : I was taught that all the newer model C172s' Hobbs are wired to the master, Usually there's an oil pressure switch in series with the Hobbs meter, so that it is only energized when the engine is running. I have no idea if that is true of the newer aircraft, but it should be. |
fwd: For Hobbs | Jack | Soaring | 9 | November 26th 06 05:28 AM |
Hampton Inn Hobbs, NM | Kilo Charlie | Soaring | 5 | July 10th 04 02:03 AM |
Hobbs Day 5 7-08 # 711. | TomnKeyLargo | Soaring | 2 | July 9th 04 04:14 AM |
Hobbs Day 2 7-05-04 | TomnKeyLargo | Soaring | 0 | July 6th 04 05:24 AM |
LS8-18 FS after Hobbs (USA) | SAM AND LEIGH ZIMMERMAN | Soaring | 1 | April 5th 04 12:43 PM |
