"Morgans" wrote in message
... "Blueskies" wrote "A friend flying an IO-360 powered Glasair installed an oxygen sensor system that has an panel mounted indicator light to show when balanced combustion is reached. He simply adjusts mixture until the light comes on and knows he has complete combustion (his theory is that EGT is really just a good guess). He has had very good results from this system in terms of fuel economy and performance. How does it deal with the lead fouling issue? I had always thought that Oxy sensors were only used while the engine was at low power settings, and that once it was cranked up to full power, the engines ran in a closed loop system, ignoring the Oxy sensor. I would think a mass airflow sensor, and a programmed controller to set the mixture to the ideal settings would be more useful. I would be interested in seeing how much the mixture was changed, with the advice of the Oxy sensor setup. Yes, lead would be a problem - the sensor won't last long with av-gas. You can run closed loop at most loads (depending on the type of sensor, you can run closed loop even when you want to run rich for power) For the most common sensor, the output "switches" as you pass through the chemically correct mixture of air and fuel - but you get best economy at air fuel ratios leaner than that... -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
Knock sensor circuit? | Jerry Wass | Home Built | 0 | May 17th 07 05:18 AM |
carburator temp sensor | Philippe Vessaire | Home Built | 0 | May 14th 06 04:35 PM |
New Thermal sensor | [email protected] | Soaring | 4 | February 1st 05 02:07 PM |
Westach 720-4a sensor | Ira Rampil | Home Built | 1 | June 21st 04 03:41 AM |
temperature sensor | Philippe Vessaire | Home Built | 2 | March 3rd 04 03:37 AM |
