O2 sensor?
Old July 3rd 07, 01:05 AM posted to rec.aviation.homebuilt
Morgans[_2_]
Default O2 sensor?
"Montblack" wrote
My reading of his post suggests it's a "monitor only" O2 sensor. With the
data from the O2 sensor, the pilot then controls the mixture manually.
I understood that to be the case also.
My point is that in auto systems, the oxy sensor information must not be
very valuable, since the computer ignores it at high power, which is where
this system is attempting to function.
Would the sensor/monitor have very much positive benefit, is my question.
Jim in NC
Old July 3rd 07, 04:19 PM posted to rec.aviation.homebuilt
Woody
Default O2 sensor?
You have it backwards. When the car first starts it is in open loop ignoring
the O2 sensor. Once in closed loop the O2 sensor is used to control mixture
and prevent pollution. Bad O2 sensor will burn out the Catalytic converter
because of too much fuel in exhaust.
"Morgans" wrote in message
Jim in NC
Knock sensor circuit? Jerry Wass Home Built 0 May 17th 07 05:18 AM
carburator temp sensor Philippe Vessaire Home Built 0 May 14th 06 04:35 PM
New Thermal sensor [email protected] Soaring 4 February 1st 05 02:07 PM
Westach 720-4a sensor Ira Rampil Home Built 1 June 21st 04 03:41 AM
temperature sensor Philippe Vessaire Home Built 2 March 3rd 04 03:37 AM
