"Peter Dohm" wrote in message
... ... BTW, it is probably usefull to think of the Open Loop Mode of the automotive ECM at Wide Open Throttle as being analogous to the enrichment valve feature of an aircraft carburetor. As soom as you no longer tramp the accelerator firmly to the floor, the ECM will return to best economy (or possibly least emissions) mixture--at least that is the impression which I received from the limited litterature I read. Least emissions - it's all about the care and feeding of the three way catalyst (Oxidizes CO and unburned HC, Reduces NOx (NO and NO2)). At best economy (lean), the catalyst can't reduce the NOx. With a wide band (or "universal") oxygen sensor, you can stay closed loop even during power (or catalyst temperature protection) enrichment - but those sensor cost $15-$20 more (at OEM prices) so they are less common. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
Knock sensor circuit? | Jerry Wass | Home Built | 0 | May 17th 07 05:18 AM |
carburator temp sensor | Philippe Vessaire | Home Built | 0 | May 14th 06 04:35 PM |
New Thermal sensor | [email protected] | Soaring | 4 | February 1st 05 02:07 PM |
Westach 720-4a sensor | Ira Rampil | Home Built | 1 | June 21st 04 03:41 AM |
temperature sensor | Philippe Vessaire | Home Built | 2 | March 3rd 04 03:37 AM |
