LS3A performance
Old July 3rd 07, 02:18 AM posted to rec.aviation.soaring
Eric Greenwell
Default LS3A performance
Chip Bearden wrote:
Personally, I'd probably take an LS-3 over an LS-3A even though the
wing is heavier--the 3 has fully automatic controls whereas the 3A
requires some control connections--but I suspect that either glider
would perform very well with the proper wing profile. They're still
very nice, very strong gliders. It's not well known that when the LS-3
and ASW 20 first appeared here in the US around 1977, the '3 was the
hot ship to have.
Even though George Moffat won the 15 M nationals at Ephrata in 1976,
using an ASW 20?
* "Transponders in Sailplanes" http://tinyurl.com/y739x4
Old July 3rd 07, 04:29 AM posted to rec.aviation.soaring
Chip Bearden
hot ship to have.
using an ASW 20?
Yeah, there are always exceptions.
Actually, I think George's win was in 1978. The year I'm thinking of
was, IIRC, 1977, in Hobbs? Rudy Mozer had one of the few (maybe the
only) '20 in the USA at the time. One day before the start, the flap/
aileron mixer broke loose in the fuselage. Skillfully and miraculously
Rudy pulled the dive brakes and put the nose down, which gave him some
fantastic dihedral and with whatever control he retained kept the
whole thing fairly level. By ruddering it around he was able to land
on a long runway there. He thought he'd forgotten to hook something up
that morning so, as the story goes, he didn't even bother to climb out
of the cockpit. He just told one of his kids to open up the hatch and
hook up the controls. With the puzzled response that the control
connections looked just fine, the situation got more complicated and
his contest was over.
So in 1977, the LS-3 was going great (Dick Johnson tested the '20 and
the '3 to be essentially equal), the '20 was dogged by a few doubts
about the flexible wings, and it was uncertain which way the wind
would blow. At least one former national champion we spoke with said
that if he had to pick between the two, he'd take the LS-3 because of
the more robust structure, the outstanding build quality, and the
price advantage (it was the cheapest of the new 15M ships at that
time).
A few years later, the story had changed and most hot pilots were
moving into the '20. Not long after that, the shrinkage over the spar
caps on the LS-3 wing began to affect cruise performance (except for
the handful of airplanes, like mine, that were corrected). It's
interesting how two airplanes with identical performance when new had
such dramatically different lives.
Chip Bearden
ASW 24 "JB"
USA
Old July 3rd 07, 10:54 PM posted to rec.aviation.soaring
Eric Greenwell
hot ship to have.
using an ASW 20?
You are right, as a search of Soaring magazine archives
(http://soaringweb.org/Soaring_Index) reveals. Dang, I can't remember
stuff that's only 30 years ago?
Old July 4th 07, 12:22 AM posted to rec.aviation.soaring
Andreas Maurer[_1_]
On Mon, 02 Jul 2007 20:29:48 -0700, Chip Bearden
It's
Looks like the early LS-3s were flown in a climate with very little
rain....
Didn't the dramatic performance loss of the LS-3 in rain show up
immediately?
Bye
Andreas
Old July 7th 07, 03:38 PM posted to rec.aviation.soaring
Chip Bearden
It's
rain....
immediately?
Bye
Andreas
Well, sort of. I got rained on many times when flying an annual
regional contest in Cordele, Georgia and noticed it. I can't say it
was the "falling out of the sky" feeling that PIK-20 owners complained
about, but performance suffered. In retrospect, it didn't seem any
worse than the few other gliders I've flown in rain (Libelle 201 and
ASW 24) even though I understand that airfoil does suffer more than
the newer airfoils from roughness.
I thought the LS-was somewhat less sensitive to rain after I contoured
the wings the first time and left them at 400 grit finish and I knew
other LS-3 drivers who did the same thing for the same reason. But
just before I sold it, I sanded it one last time and brought the
finish back up to a gloss. I might even have waxed it (not sure).
During my last contest with these polished wings, I flew into a
rainstorm flying the ridge in Pennsylvania. The sink rate did increase
but not as much as that of the DG-400 right behind me whose highly
experienced pilot complained he was forced to turn back to get out of
the rain and then use the engine to stay aloft. I eventually turned
back also but had no trouble staying aloft and waiting out the rain.
This was not exactly a scientific test but my impression was that
having polished wings hadn't really hurt and that the performance
degradation was significant but not unusual.
I concluded that the LS-3 probably wasn't much worse, if any, than the
other ships of its time when new. It's possible that it was more
sensitive after the flat spot over the spar cap developed due to
curing of the composite structure, making most other LS-3s more
vulnerable. Based on feedback from one PIK pilot, I also tended to use
more positive flap than normal when the wing was wet, which seemed to
help.
It's also possible that the LS-3's reputation developed more rapidly
in Europe due to the greater degree of bugs that can be deposited on
the wings. Bugs aren't generally a problem here in the U.S., even in
south Georgia in the summer (at altitude, that is; they're definitely
a serious problem on the ground!).
Chip Bearden
ASW 24 "JB"
USA
LS3a or Mini Nimbus [email protected] Soaring 14 November 11th 06 10:36 PM
Complex / High Performance / Low Performance R.T. Owning 22 July 6th 04 08:04 AM
FS - LS3a Simon Waddell Soaring 0 January 17th 04 04:05 PM
OPINIONS ON AN LS3A Gordon Schubert Soaring 6 November 14th 03 10:41 AM
Drag of LS3 compared LS3a. Peter Warburton Soaring 0 August 18th 03 06:59 AM
