John Carrier wrote:
wrote in message oups.com... On Jun 30, 1:54 pm, "John Carrier" wrote: "Schlomo Lipchitz" wrote in message ... Whevever I see a TV show about the F-4, all the AF guys do is bitch about the early models not having a gun. Just how many kills (if any) have the F-14, F-15, F-16, and F-18 had with guns??? On the Navy side, Zero for the F-14 and F-18. I don't think the USAF F-15/16 drivers have ever gotten a gun kill either, it's possible the Israelis have. With modern missile systems, you generally have to drive through the missile envelope to get to guns, so it makes little sense to pass up the opportunity and expose yourself more than necessary. A gun kill in a post-Vietnam world would also often require entering a hard-maneuvering engagement that is generally an unhealthy place to be. An interesting note. Most Vietnam gun kills were scored by the F-105, perhaps the least maneuverable aircraft in wide service there. No Crusader gun kills? The question was about the modern aircraft. For the F-8, if I counted correctly, 4 with the gun only, 3 more sidewinder + gun. And one with no ordnance expended ;-). And another 10 or so which were Sidewinder only. John, Given the lack of reliability of the F-8's guns, how much were you really relying on them? Was doctrine at the time to take advantage of the situation that since, in order to set yourself up for a gun shot, you'd drive right through the Sidewinder's best engagement zone and geometry, that you'd push for the gun shot, but it was mostly a follow-up if the missile didn't work? -- Pete Stickney Without data, all you have is an opinion |
![]() "Peter Stickney" wrote in message ... John Carrier wrote: wrote in message oups.com... On Jun 30, 1:54 pm, "John Carrier" wrote: "Schlomo Lipchitz" wrote in message ... Whevever I see a TV show about the F-4, all the AF guys do is bitch about the early models not having a gun. Just how many kills (if any) have the F-14, F-15, F-16, and F-18 had with guns??? On the Navy side, Zero for the F-14 and F-18. I don't think the USAF F-15/16 drivers have ever gotten a gun kill either, it's possible the Israelis have. With modern missile systems, you generally have to drive through the missile envelope to get to guns, so it makes little sense to pass up the opportunity and expose yourself more than necessary. A gun kill in a post-Vietnam world would also often require entering a hard-maneuvering engagement that is generally an unhealthy place to be. An interesting note. Most Vietnam gun kills were scored by the F-105, perhaps the least maneuverable aircraft in wide service there. No Crusader gun kills? The question was about the modern aircraft. For the F-8, if I counted correctly, 4 with the gun only, 3 more sidewinder + gun. And one with no ordnance expended ;-). And another 10 or so which were Sidewinder only. John, Given the lack of reliability of the F-8's guns, how much were you really relying on them? Was doctrine at the time to take advantage of the situation that since, in order to set yourself up for a gun shot, you'd drive right through the Sidewinder's best engagement zone and geometry, that you'd push for the gun shot, but it was mostly a follow-up if the missile didn't work? The guns weakness was the length of the flexible feeds from the ammo cans located behind the cockpit (head high) and the guns which were in the lower forward fuselage. Under G, some flexing would occur, the belted ammo would catch and break a link. The trick was to avoid firing at anything over 4 G, and preferably around 2.5 ... not easy against a turning adversary. As I noted in an earlier post, you usually flew though the Sidewinder envelope prior to reaching a gun solution. So ... rely on the missile. Snap (opportunity) shot at high TCA was still available with guns. The WCS allowed both guns and missiles to be available, missiles on the pickle and guns on the trigger. Pushing for the gun shot was generally ill-advised in a multi-plane engagement. The time expended from sidewinder envelope (1NM and within 40 degrees in the era) to guns (1000') created a predictable path the free bogey could exploit. The Thuds got lots of gun kills because most of the time that's what they had and all they had. With A/A missile armament, the gun is primarily a weapon of (somewhat unusual) opportunity and often (in the training environment) ego. R / John |
The article at:
http://www.afa.org/magazine/July2007/0707strafing.asp includes the following: "We're using the gun quite a bit in the Iraq and Afghanistan operations. The fighters are using lots of 20 mm off F-15Es and F-16s and 30 mm off A-10s to hit ground targets. Why is that? For individuals, the gun is probably one of the most accurate weapons, with the least collateral damage. That 20 mm will end the bad guy's life, but stray rounds will just drive into the ground, and that's it. In Iraq, the adversary uses both road networks and riverine networks. There have been a number of occasions where boats have been identified carrying insurgents on the Tigris and Euphrates Rivers, and we've used 20 mm and 30 mm guns to destroy those boats. A moving target is hard to hit with a bomb. With a gun, it's no big deal. In one instance, the enemy was getting ready to move people somewhere to do something later that night, but we removed them from the fight. The same thing happened in Balad, where we found people going to get roadside bomb supplies. We have been using the gun against single persons who have been planting improvised exposive devices. You'll have an individual with a truck, and a couple of other individuals; you'll see them get out and move around, trying to dig a hole, and you'll bring in an F-16 or an F-15E, or maybe an A-10, and you'll use 20 or 30 mm and go kill them. If you have troops in contact, or you have individuals in buildings, you do the same thing." Discussions about aircraft guns usually center on air-to-air usage, but nowadays, that's a secondary mission. With the primary usage of aircraft guns being strafing. For how long has this been true? |
![]() wrote in message oups.com... The article at: http://www.afa.org/magazine/July2007/0707strafing.asp includes the following: "We're using the gun quite a bit in the Iraq and Afghanistan operations. The fighters are using lots of 20 mm off F-15Es and F-16s and 30 mm off A-10s to hit ground targets. Why is that? For individuals, the gun is probably one of the most accurate weapons, with the least collateral damage. That 20 mm will end the bad guy's life, but stray rounds will just drive into the ground, and that's it. In Iraq, the adversary uses both road networks and riverine networks. There have been a number of occasions where boats have been identified carrying insurgents on the Tigris and Euphrates Rivers, and we've used 20 mm and 30 mm guns to destroy those boats. A moving target is hard to hit with a bomb. With a gun, it's no big deal. In one instance, the enemy was getting ready to move people somewhere to do something later that night, but we removed them from the fight. The same thing happened in Balad, where we found people going to get roadside bomb supplies. We have been using the gun against single persons who have been planting improvised exposive devices. You'll have an individual with a truck, and a couple of other individuals; you'll see them get out and move around, trying to dig a hole, and you'll bring in an F-16 or an F-15E, or maybe an A-10, and you'll use 20 or 30 mm and go kill them. If you have troops in contact, or you have individuals in buildings, you do the same thing." Discussions about aircraft guns usually center on air-to-air usage, but nowadays, that's a secondary mission. With the primary usage of aircraft guns being strafing. For how long has this been true? Strafe can be a worthwhile employment of the gun, evidently done with much success in the ongoing pair of conflicts. Can be somewhat hazardous in the daytime if the bad guys have the capability to shoot back (a risk/reward thing). Pretty functional at night with goggles, etc. R / John |
This has been an issue for some time (at least two years) now and has
not made it to the front burner - but now with the USAF SOF looking at COIN aircraft and people admitting to the vulnerability of the helicopters and the fact that even the A-10's 30mm has become too big a weapon for the ROE there is an attitude change. You would think at first this all should not be interrelated but it has come down to the fact that the ground forces fighting an insurgency can not get a jump on the enemy without some help from the third dimension and everything tried now has been too big weapon wise, too late in getting to where it is needed, or too clumsy for small unit operations in urban environments. So now it is realized that when the fighters are up their 20mm guns and their accurate gunsights can make a difference especially if the ammo is basic ball. Visualize a 20/23/25 mm gun with a constantly chambered round (side-by-side twin for instance) that can get off quicker and a "spit-burst" of 6 to 10 rounds every trigger pull and combine that with a laser-sight. If the platform was survivable then you can see from the grunts poiunt of view it would become a very popular machine. It is not yet possible as a UAV although it should be put into the go-do locker for sure, yet a manned platform gives the grunt-air relationship a chance to exploit the combat situation as it always has and yet has been denied from this war for too long. In Vietnam as you talk to the Thud pilots, which still represents an enormously proud and daring group of can-do people ("there is a way" right!) and what you see time and time again is their courage and airmanship being thrown up against incompetence in command and the whole targeting cycle and perceived purpose of air power in the war. If they would have been let loose, with people like Olds at the helm, they would have ripped North Vietnam a new asshole in a few months. If we honor their courage and dismiss the incompetence that sent them on their missions that only added to their risk, then we have failed both them and ourselves. This "gun" strafe issue in Iraq and again in Afghanistan is the same script being played in a different theater. Incompetence at the top, apathy at the midsection, and dead heroes at the bottom. Could or would we ever face off with the retired generals who we praise so much over and over, like Meyers - nice guy, hard worker but totally irrelevant to any path in this war to victory. When you read those words about how important a fighter strafing was to a ground unit, can you understand for a minute how just about everything else we have been doing has not added up to a hill of beans. We as a nation have accomplished this in five years of war - 100 dead a month / 1500 wounded / $30 billion spent - that's it, it does not get better then that and the thousands of troops that go out in small units, patrols, convoys, etc., all rarely get the chance to have real air assist and protection. In Afghanistan now the UK is concerned because their casualties are taking four hours to get to hospital, there are no spare helicopters, and those there are too vulnerable. We are looking at sling configured ultra-lights now. All of you in this group have enormous distinction in combat and in the aviation disciplines - you must not let this incompetence go on and on when you can see in a micro-seconds solutions that have yet to be even put on the table in the Pentagon and the commands. Politics aside - we are doing this to ourselves and we (you and I) are not doing enough to honor the Thud spirit for one, to get ride of the incompetence and bring back the warriors placing the network managers aside for a while until business with the al Qaeda can be finished. "John Carrier" wrote in message . .. wrote in message oups.com... The article at: http://www.afa.org/magazine/July2007/0707strafing.asp includes the following: "We're using the gun quite a bit in the Iraq and Afghanistan operations. The fighters are using lots of 20 mm off F-15Es and F-16s and 30 mm off A-10s to hit ground targets. Why is that? For individuals, the gun is probably one of the most accurate weapons, with the least collateral damage. That 20 mm will end the bad guy's life, but stray rounds will just drive into the ground, and that's it. In Iraq, the adversary uses both road networks and riverine networks. There have been a number of occasions where boats have been identified carrying insurgents on the Tigris and Euphrates Rivers, and we've used 20 mm and 30 mm guns to destroy those boats. A moving target is hard to hit with a bomb. With a gun, it's no big deal. In one instance, the enemy was getting ready to move people somewhere to do something later that night, but we removed them from the fight. The same thing happened in Balad, where we found people going to get roadside bomb supplies. We have been using the gun against single persons who have been planting improvised exposive devices. You'll have an individual with a truck, and a couple of other individuals; you'll see them get out and move around, trying to dig a hole, and you'll bring in an F-16 or an F-15E, or maybe an A-10, and you'll use 20 or 30 mm and go kill them. If you have troops in contact, or you have individuals in buildings, you do the same thing." Discussions about aircraft guns usually center on air-to-air usage, but nowadays, that's a secondary mission. With the primary usage of aircraft guns being strafing. For how long has this been true? Strafe can be a worthwhile employment of the gun, evidently done with much success in the ongoing pair of conflicts. Can be somewhat hazardous in the daytime if the bad guys have the capability to shoot back (a risk/reward thing). Pretty functional at night with goggles, etc. R / John |
Rivet Guns | tdfsks | Home Built | 3 | July 21st 05 01:43 AM |
P-51C crash kills pilot | Paul Hirose | Military Aviation | 0 | June 30th 04 05:37 AM |
Flying Guns: the Modern Era | Tony Williams | Military Aviation | 2 | March 26th 04 03:52 PM |
COWS WITH GUNS | Beefy Burger | Home Built | 14 | January 21st 04 07:07 AM |
Guns on fighters? | SKSvilich | Naval Aviation | 54 | December 8th 03 02:27 PM |
