Survivability VS landing speed
Old July 7th 07, 04:07 AM posted to rec.aviation.homebuilt
Default Survivability VS landing speed
Hi All,
Some time ago, kitplane had an article concerning the survivability as
a function of landing speed, at least I think that was the nature of
the article. Anyway, does anybody know about the article, or where I
can find a copy. If I remember correctly, the article was very well
written, and I am in need of some data that was presented.
Thanks in advance for the help
Best Regards,
Dave
Old July 7th 07, 03:52 PM posted to rec.aviation.homebuilt
Vaughn Simon
I can't help you on the specific article (I would like to see it myself).
Remember that Energy = MV^2, and the landing ain't over until all of that energy
has somehow been dissipated. It can be dissipated in aerodynamic drag, rolling
resistance, and by heating up brakes; or it can be dissipated by deforming the
airframe and its occupants. We naturally prefer the former.
Assume any weight you like for your airframe and do the math for different
speeds. You will quickly discover that ten knots one way or the other makes a
heluva difference. A lighter airframe also makes a significant difference.
This is why the Sport Pilot regulations limit both gross weight and stall
speed... to limit the landing energy the pilot must deal with.
Vaughn
Old July 7th 07, 09:46 PM posted to rec.aviation.homebuilt
Peter Dohm
"Vaughn Simon" wrote in message
myself).
energy
rolling
different
makes a
difference.
stall
Vaughn
Presuming, of course, that the plan is to crash--which has been one of my
biggest criticisms of both Ultralight Vehicles and LSA from the beginning.
OTOH, other things being equal, higher landing speed also equates to greated
crosswind capability. Given excellent pilot proficiency, 10 knots change in
landing speed means up to 4 knots change in maximum crosswind
component--which is also a heluva difference!
Peter
Old July 11th 07, 05:16 PM posted to rec.aviation.homebuilt
myself).
has somehow been dissipated. ...
... You will quickly discover that ten knots one way or the other
makes a heluva difference. ...
OTOH if it is low enough you never have to do a cross wind landing...
FF
Old July 11th 07, 05:53 PM posted to rec.aviation.homebuilt
Roger (K8RI)
myself).
I like that "up to" which means from nothing to the max of 4. IOW a
faster landing speed gives no guarantee of being able to handle more
cross wind component. How much cross wind can an F-16 handle?
Old July 11th 07, 07:30 PM posted to rec.aviation.homebuilt
C J Campbell[_1_]
On 2007-07-06 20:07:25 -0700, " said:
Hi All,
Best Regards,
Dave
I remember that article, but I am not sure it was Kitplane. I know it
was at least 3 or 4 years ago.
Waddling Eagle
World Famous Flight Instructor
Old July 11th 07, 08:24 PM posted to rec.aviation.homebuilt
Its true that collision energy is proportional to relative speed
squared. But if on landing you don't collide with anything (or flip
over, etc.) you should have a good chance not getting hurt. Just like
cars spinning out of control, they are ok if they don't bump into
anything - roll over, etc.
Loss of control during takeoff is more problematic. There typically
you don't have room to "slide" on the runway but bump into trees,
housing or whatever.
On Jul 6, 10:07 pm, " wrote:
Hi All,
Best Regards,
Dave
Old July 11th 07, 11:29 PM posted to rec.aviation.homebuilt
cavelamb himself
Blueskies wrote:
"cavelamb himself" wrote in message
ink.net...
The other important factor is angle of impact...
Actually it is how quickly you stop...
Angle of contact has a big impact on how fast you stop.
Even low velocity at a large angle could hurt.
But a low angle, even at high speed, shouldn't.
A Jet Blue Aircraft Landing with Sideway Landing-Gear Lufthansi Piloting 18 July 19th 06 05:13 AM
A Jet Blue Aircraft Landing with Sideway Landing-Gear Hansi Instrument Flight Rules 1 July 17th 06 04:01 AM
Plastic planes are fast but landing speed too high P S Owning 30 June 20th 06 10:30 PM
JASPO Experts On Civil Aircraft Survivability sid Military Aviation 2 February 13th 04 07:41 AM
Survivability in Combat ArtKramr Military Aviation 102 December 10th 03 06:40 PM
