Master Bumper
You are indeed correct. The Akavlieg Braunschweig tried this with the quite radical SB13 prototype. This Standard-Class glider first flew in 1988. Lots of details in Dr Fred Thomas' "Fundamentals of Sailplane Design. 15m wingspan, 15 degree sweep, elevons and winglets doubling as vertical stabilisers. Differential deflection of rudders on the winglets to counter yaw. It proved to have similar performance to contemporary standard class gliders.Some advantage in efficiency being generally lost to handling induced inefficiency. So - There was no compelling efficiency advantage. Conversely there were substantial operational and controllability issues and high pilot work load. etc... For example; It proved impossible to winch launch safely. Apparently Braunschweig has used the SB13 in contests, and also allows experienced akavlieg pilots to fly it. There are quotes like "it exhibits very poor flying and handling qualities in turbulent conditions." It is the subject of at least one thesis on aeroelastic properties. Details at: http://www.akaflieg-braunschweig.de/prototypen/sb13/ And here - http://www.sailplanedirectory.com/braunsch.htm#SB-13 The Genesis is a more modern design, and presumably learned from the difficulties they had with the SB13 - which was after all a prototype designed to investigate innovation, rather than a commercial endeavor. There have been others with a similar idea, in fact the SB13 was not the first I know of at improving on the Horten - the BKB1 has that honour. Although the information is unsubstantiated - there is some info here http://www.astercity.net/~krisabc/BK...hocki3-en.html Maybe Jim Marske will develop a giant killer from this concept - but I personally can't see it happening. It is a fascinating concept -and so we keep trying to minimise the tail boom (cf Diana 2) But it remains the best way to do things. Consider - Even Burt Rutan eventually went back to the conventional layout with the Global Flyer (http://www.scaled.com/projects/globalflyer.html) - it is not conventional for nothing - it represents the best compromise. My 2 (South African ) cents worth - not that that means much at ZAR 7 / USD but there you have it. bumper wrote: "Bill Daniels" bildan@comcast-dot-net wrote in message . .. Of course, an existing Genesis won't fly without the tail. But the Genesis CONCEPT could have as evidenced by Jim Marske's designs. Bill Daniels Would the resulting aircraft perform better than the much more numerous and seemingly more successful "standard" planform? While I admire experimenting and innovation, I wonder why, if the flying wing concept were so good, at least as applied to gliders, hasn't it been embraced by major manufacturers? They seem willing to go to great lengths to eek out as much performance as they can. Could it be that the tweaks needed to impart longitudinal stability, like reflexed trailing edges, are not efficient enough over a broad enough speed range? bumper Minden, NV |
![]() It proved to have similar performance to contemporary standard class gliders.Some advantage in efficiency being generally lost to handling induced inefficiency. So - There was no compelling efficiency advantage. It should be noted that most all hang gliders are flying wings. The reason for this has more to do with portability than with performance. The handling quality of many hang gliders since, say the early '80, are quite pleasant - remember, this is weight shift contol. Tony V |
youtube gliding videos | Mal[_3_] | Soaring | 3 | March 17th 07 04:55 AM |
The Holy Shroud | Acrux | Piloting | 3 | September 29th 06 02:16 AM |
Holy $#$ - eBay Copter | Jimbob | Home Built | 37 | September 13th 05 10:58 PM |
