air conditioning- nice, required, or silly?
Old July 8th 07, 12:41 PM posted to rec.aviation.owning
Mike Spera
Default air conditioning- nice, required, or silly?
Anybody have any experience with air conditioning in their plane-Nice
to have? Silly accessory? Don't leave home without it? 80% Summer
flying in Northeast.
Thanks for your opinion.
Andy
As others have stated, you cannot use if for takeoff. So, you use it on
the ground and then turn it on again in the climb. 4 minutes into the
climb, you are usually into cooler air anyway and shut it off.
Google A/C and see the persistent problems with these units.
They are R-12 systems in most planes. If you think it is expensive to
get a car charged with R-12, wait till you see what it will cost to get
an A&P to do it - if you can find one. Likely you will have to talk an
auto tech into bringing his equipment out to the airport for the A&P to
watch him charge the system. Then, you get to pay 2 folks for one
operation. R-134? Many techs will not do a conversion because they can
screw up some systems irreparably. Even though many have converted
Pipers, the local auto tech has no experience and likely will not want
to "experiment" with a very expensive airplane.
The hoses are now 20-30+ years old. They leaked like crazy when new and
have not gotten any better with age. If an auto tech charges the plane,
they will likely give you the speech about how they are required to
investigate why the system needed a charge and fix it. Or, they may
refuse to charge it at all UNTIL the leak is found and fixed.
As others have said, they rob you of 70 odd pounds in the Pipers. For a
140 that is 10% of its useful load and precludes any thoughts of a third
person.
The alternator belts and pulleys are the biggest pain. After 1000 hours,
the pulleys wear due to the high tension required on the skinny
alternator belt. Once worn, you can throw belts in as little as 2 hours.
Ironically, the compressor belt usually never breaks. Which would you
choose to go South unpredictably?
We removed ours and got back 43 pounds. We left the drop door and
condenser in because of the hassle of removing it. The cost to "convert"
back to stock can be staggering and the parts are NOT easy to identify
and find.
Opinions vary, but in many Midwest/Northern parts of the country, it is
not worth the hassle.
Good Luck,
Mike
Old July 8th 07, 03:21 PM posted to rec.aviation.owning
150flivver
On Jul 8, 6:41 am, Mike Spera wrote:
They are R-12 systems in most planes...R-134? Many techs will not do a conversion because they can
to "experiment" with a very expensive airplane...
Mike
I can't imagine that converting an R-12 system to R-134 wouldn't
require an STC.
Old July 8th 07, 07:27 PM posted to rec.aviation.owning
Mike Spera
Mike
require an STC.
I was not heading in that direction. My thought was that some R-12
systems contained some funky oil that turned to glue when R-134 oil hit
it. Hence, some auto guys will not do a "conversion" and risk getting
into a huge beef if the system gets all gummed up.
I would imagine that those same auto wrenches would also balk at going
to the local airport to "try out" converting a Piper from 12 to 134.
I would never suggest that a conversion would require and STC. But, some
FAA critter might.
Good Luck,
Mike
Old July 9th 07, 12:08 AM posted to rec.aviation.owning
The Visitor
I don't know if it is an stc thing, but there are conversions available.
It has always been far cheaper to stick with r12 in my seneca. I seem
to remembe being told is was about 6k to convert.
John
Mike
require an STC.
Old July 9th 07, 12:29 AM posted to rec.aviation.owning
Viperdoc[_3_]
How much does aftermarket AC cost? The best price I've seen for a Baron was
around $25,000 installed!
"The Visitor" wrote in message
I don't know if it is an stc thing, but there are conversions available. It
has always been far cheaper to stick with r12 in my seneca. I seem to
John
Mike
require an STC.
Old July 9th 07, 04:15 PM posted to rec.aviation.owning
The Visitor
You had better want it bad for 25k!
I have not heard of any aftermarket prices.
Mine was factory.
And if I were to buy again, I would pay 25k extra for the option.
John
Old July 9th 07, 07:42 PM posted to rec.aviation.owning
Dave[_16_]
The Visitor wrote:
Baron was around $25,000 installed!
Mine was factory.
John
Has anybody talked about the electric seat coolers here yet?
It can be a good option to keeping cooler during those hot days.
Dave
Old July 9th 07, 07:53 PM posted to rec.aviation.owning
Gig 601XL Builder
Mine was factory.
John
Dave
Got a link? I've never heard of them.
Old July 10th 07, 12:28 AM posted to rec.aviation.owning
Blueskies
"The Visitor" wrote in message ...
Viperdoc wrote:
How much does aftermarket AC cost? The best price I've seen for a Baron was around $25,000 installed!
Mine was factory.
John
That is how much the 172 costs...
Silly L/D stats Andy[_1_] Soaring 1 April 9th 07 05:14 AM
Silly controller Robert M. Gary Instrument Flight Rules 123 August 30th 06 01:56 AM
Saab 340 air conditioning? John Clonts Piloting 1 July 14th 06 05:00 PM
ELT Required for all SSA sanctioned contests starting 2006 ELT Required for all SSA sanctione Steve Leonard Soaring 2 September 14th 05 03:49 AM
Air Conditioning System for Homebuilts? JPAviation Home Built 18 February 6th 04 03:24 AM
