I'd like to update the database for my Apollo GX55 GPS. $120 for the
raw data is bad enough, but Jeppesen also wants $150 for a writer. The datacard is a PCMCIA card, so wouldn't it be possible to work with it with a plain old laptop or a $10 reader from Best Buy? I'm wondering if someone has found a way to do this. -- |
The problem is that the data on the card is not in an open file format. So,
you need Jepp's application to do the writing. Jepp's application is designed to interface with their writer. This is not necessary but is the way it is designed. The alternative would be software drivers installed that know how to deal with the format of the card and can negotiate with other installed drivers to take over when appropriate - not an easy thing to control. Until they are willing to change their application, we're stuck with using their writer. -- ------------------------------- Travis Lake N3094P PWK "Charles" wrote in message news 4Oji.18991$Fc.10534@attbi_s21...I'd like to update the database for my Apollo GX55 GPS. $120 for the raw data is bad enough, but Jeppesen also wants $150 for a writer. The datacard is a PCMCIA card, so wouldn't it be possible to work with it with a plain old laptop or a $10 reader from Best Buy? I'm wondering if someone has found a way to do this. -- |
"Peter" wrote in message
... so that the PC software can write to it in a simple manner. I don't know what is involved but can tell you that if you plug one of these into a normal reader and invoke the windoze API call for reading physical sectors, all you see is rubbish; mostly zeroes. It looks like they are using some odd property of the flash chips, but that would lead to rapid obsolescence. No odd property of the flash chip at all. Just a low level data structure that makes no sense to the Windows drivers trying to interpret it as a device that supports a filesystem. It is entirely feasible to write a Windows driver for a Jepp datacard. You would bypass all of the Windows drivers and be writing a very low level device interface. I'm just glad they still support data updates at all. Pay the $150 and enjoy the updated data in your GX55. ------------------------------- Travis Lake N3094P PWK |
The GNS 480 and the MX 20 use a standard windows CF
reader (which they give you a sandisk one with the units). The cards have a serial number hidden in one of the FS fields, but otherwise are standard. JSUM pretty much doesn't care what hardware device you use to program it as it uses the standard windows filesystem calls to access it. I've used a PCCARD-CF adapater to program mine. |
On 7/7/07 10:13, "Charles" wrote:
I'd like to update the database for my Apollo GX55 GPS. $120 for the raw data is bad enough, but Jeppesen also wants $150 for a writer. The datacard is a PCMCIA card, so wouldn't it be possible to work with it with a plain old laptop or a $10 reader from Best Buy? I'm wondering if someone has found a way to do this. Charles, When you asked about this on the Husky list, I didn't know you were trying to duplicate the datacard. Don't know if it helps, but I used a program called Winhex to duplicate the compact flash card for a GNS 480. You might check and see if it fits the bill. http://www.x-ways.net/winhex/ - Don And let's get one thing straight. There's a big difference between a pilot and an aviator. One is a technician; the other is an artist in love with flight. - E. B. Jeppesen |
Do a search for Raw write/read you can clone the flash drives including
PCMCIA Flash Disk "Peter" wrote in message ... "Travis Marlatte" wrote so that the PC software can write to it in a simple manner. I don't know what is involved but can tell you that if you plug one of these into a normal reader and invoke the windoze API call for reading physical sectors, all you see is rubbish; mostly zeroes. It looks like they are using some odd property of the flash chips, but that would lead to rapid obsolescence. No odd property of the flash chip at all. Just a low level data structure that makes no sense to the Windows drivers trying to interpret it as a device that supports a filesystem. It is entirely feasible to write a Windows driver for a Jepp datacard. You would bypass all of the Windows drivers and be writing a very low level device interface. I'm just glad they still support data updates at all. Pay the $150 and enjoy the updated data in your GX55. No matter what the filing system is, one should still be able to read *logical sectors* from a CF using any cheap CF reader. AFAIK the reader just returns logical sectors - the file structure is down to the O/S. If you read a KLN94 CF cartridge (an old 48MB Sandisk part; they must have bought loads of them) in this way, you get mostly zeroes, plus a very small amount of rubbish which doesn't seem to be valid data and there is nowhere near enough of it for the size of the database (about 2MB). Hence my comment that they are invoking some flash chip feature. |
Here is a Code for the winhex 14.2 Current Version
Target: http://www.x-ways.net/winhex.zip Paste All 6 Lines Below Name: "Jeppesen Data Clone" Addr1: "Free For All" Addr2: "Planet Earth, Milkey Way" Key1: C9D87F5A45256C3257E22C50548FE8E6 Key2: F7056AAF6D4E6F7564335EAD978ED639 Chksm: D9 "No Spam" wrote in message ... On 7/7/07 10:13, "Charles" wrote: I'd like to update the database for my Apollo GX55 GPS. $120 for the raw data is bad enough, but Jeppesen also wants $150 for a writer. The datacard is a PCMCIA card, so wouldn't it be possible to work with it with a plain old laptop or a $10 reader from Best Buy? I'm wondering if someone has found a way to do this. Charles, When you asked about this on the Husky list, I didn't know you were trying to duplicate the datacard. Don't know if it helps, but I used a program called Winhex to duplicate the compact flash card for a GNS 480. You might check and see if it fits the bill. http://www.x-ways.net/winhex/ - Don And let's get one thing straight. There's a big difference between a pilot and an aviator. One is a technician; the other is an artist in love with flight. - E. B. Jeppesen |
It's used to clone GPS data cards and other type of media. Helps Recover
Lost Data it works really well for a lot of things read the web site on it. "Peter" wrote in message ... What is Winhex? "NW_Pilot" wrote Target: http://www.x-ways.net/winhex.zip |
| Thread Tools | |
| Display Modes | |
| Sup, All & Sorry, No Write Up On S/A | NW_Pilot | Piloting | 13 | May 4th 07 04:18 PM |
| Looking for Jeppesen Skybound 2 PCMCIA Software | Ron Lee | Piloting | 7 | August 30th 06 03:27 PM |
| 2006 WGC daily write ups | [email protected] | Soaring | 4 | June 4th 06 03:07 AM |
| "ELIPPSE" please write me | ELIPPSE | Home Built | 0 | January 25th 05 04:49 AM |
| SpaceShipOne - Write-Up and Pictures | Brenor Brophy | Piloting | 4 | June 25th 04 06:55 PM |
