flaps
Old July 11th 07, 03:19 PM posted to rec.aviation.owning,rec.aviation.piloting
Andrew Gideon
Default flaps
On Wed, 11 Jul 2007 04:21:15 +0000, Jim Carter wrote:
It is almost 2nd nature to reach for the trim wheel right after
selecting flaps in a Cessna so why didn't the poster notice that he didn't
need to retrim?
Perhaps that - the "second nature" part - is exactly why it didn't
register.
I just did a flight review in our R182. Discussing gear use, the CFI
mentioned that during some training he did of someone once upon a time
there was some extended flight during which the gear horn was sounding (a
simulated engine failure). When it finally came time to land, the pilot
never put down the gear; he'd completely tuned out the sound.
Our brains are weird.
The CFI called a go around on that landing. The student went to pull the
gear up for the go around and only then realized that it was still up.
Despite the horn still doing it's bleat bleat.
- Andrew
Old July 10th 07, 11:01 PM posted to rec.aviation.owning,rec.aviation.piloting
Blueskies
Default flaps
"kontiki" wrote in message ...
Get a real A&P to check out the flap situation. If its
not the breaker it could be the flap motor (one of the
reasons I do like manual flaps).
As far as why you didn't notice that your flaps were
not working... well... that is disturbing. I notice
*every* little sound, motion, vibration or whatever in
my airplane.
I hardly ever land with full flaps unless its a short
field.
Why are you beating up the plane?
I was taught and used to teach that any landing without full flaps was an 'emergency' landing. The airplane has a
landing configuration and the performance in the book is based on that configuration...
It is good to practice emergency landings every so often.
Old July 11th 07, 12:05 AM posted to rec.aviation.owning,rec.aviation.piloting
kontiki
Default flaps
Beating up my plane? Have you ever flown a Comanche? All you
need is 20 degrees for smooth and graceful landings in a PA24.
If I'm going into a really short field (2000 feet?) then I'll
use full flaps.
All the 182's I've ever flown only need 20 degrees of flap
for nice landings too. Go full flaps and its like an anvil
with a parachute. The 182 is a great short field airplane.
Old July 11th 07, 12:49 AM posted to rec.aviation.owning,rec.aviation.piloting
Blueskies
Default flaps
"kontiki" wrote in message news
use full flaps.
So, what is the expected landing performance for the Comanche, landing with 20° flaps?
Tires and brakes at least are taking more than they need to. Wheel bearings too. Struts and oleos thumping over the
expansion joints, etc...
Always landed the PA32-300 with full flaps, nice and slow. And that was in HI with screwy cross winds pretty much always
blowing 15-20 knots.
Old July 11th 07, 01:53 AM posted to rec.aviation.owning,rec.aviation.piloting
Matt Whiting
Default flaps
an 'emergency' landing. The airplane has a landing configuration and
use full flaps.
I can make nice landings with 0 or 40 degrees of flaps. The flaps don't
land the airplane.
A 182 with full flaps still glides just fine. The Arrow I now fly which
has a 3-blade prop is much worse than my 182 in the glide ratio
department. I can barely make a 180 power-off landing with it. You
have to turn base as soon as you cut power abeam the landing spot or
you'll never make it!
Matt
Old July 11th 07, 02:14 AM posted to rec.aviation.owning,rec.aviation.piloting
Dan Luke[_2_]
Default flaps
"Matt Whiting" wrote:
The Arrow I now fly which has a 3-blade prop is much worse than my 182 in
the glide ratio department. I can barely make a 180 power-off landing with
it. You have to turn base as soon as you cut power abeam the landing spot
or you'll never make it!
As a CFI giving me a checkout in an Arrow put it: "You can cut the power and
glide a Cessna in, but a Piper comes down like dropped car keys."
Dan
T-182T at BFM
Old July 11th 07, 09:38 PM posted to rec.aviation.owning,rec.aviation.piloting
karl gruber[_1_]
Default flaps
Landing with less than full flaps is CERTAINLY not "Beating up the
airplane." Where do you come up with such rubbish.
My Cessna's POH specifically states:
FLAP LIMITATIONS:
Approved Landing Range. 0--40
Not being able to select the proper flap for landing conditions is a serious
training flaw. Full flap all the time is ridiculous.
Karl
"Blueskies" wrote in message
et...
my airplane.
field.
'emergency' landing. The airplane has a landing configuration and the
Old July 11th 07, 10:34 PM posted to rec.aviation.owning,rec.aviation.piloting
Thomas Borchert
Default flaps
Karl,
That the POH doesn't say ;-)
Thomas Borchert (EDDH)
Old July 10th 07, 01:51 PM posted to rec.aviation.owning,rec.aviation.piloting
Roy Smith
Default flaps
"Kobra" wrote:
On base at Williamsburg I noticed that the airspeed was really high. I
raised the nose and pulled some power. I had 20 degrees of flaps in and
that is what I usually land with. On final the airspeed was just coming out
of the green and touching the white arc with only 15 inches manifold
pressure. On short final I dropped the last 10 degrees, but despite that,
man I came across the threshold like a bat-out-of-hell.
Then you should have gone around. Plan every approach to be a go-around,
and only make the decision to land when you get to the threshold and
everything is good.
10 kts too fast over the threshold is pretty significant. I don't fly the
177RG, but I found a checklist on the net that lists normal landing speeds
at 60-70 kts and Vfe (top of the white arc, which is what you said you were
doing on final) as 95. That's 25-35 kts too fast to land. I'm amazed you
managed to get it stopped in 3000 feet. In fact, I can't believe you were
really going that fast over the threshold, it's just not possible.
The runway was only 3000 feet, but somehow I got it down and stopped after
heavy brake burning. I just figured I used some really bad technique or
picked up a tailwind.
A tailwind will increase your groundspeed, but not your airspeed.
Now I had to get home. I called my mechanic and he said it could be many
things (it wasn't the breaker). He also said I was a complete wimp (he used
a different word that began with a p) if I couldn't land that plane without
the flaps on our 3,500 feet of runway.
From a strictly legal point of view, if you knew the flaps were broken, the
plane was not airworthy. From a safety point of view, however, I'd say you
did the right thing by consulting a mechanic to get an experienced opinion.
Technically, you needed a ferry permit to take off again, and your mechanic
using the p-word on the phone doesn't quite qualify. But I digress.
I took off and started to ponder the situation:
The pondering should have happened before you took off. Once you're in the
air, you can ponder all you want, but you still need to land the airplane.
No flaps
No daylight with 3 miles vis. in haze and mist (ASOS said 10 miles but no
way could you see more than 3 miles)
No landing light (it burned out two weeks ago)
No wind (so no headwind to help slow the airplane's ground speed on landing)
and I've done a grand total of two no-flap landings in my life. One with my
primary CFI and one during my check out when I bought the plane. Both
during the day with a headwind.
From a pure performance point of view, your mechanic was right. With
proper technique, landing a 177RG on 3500 feet without flaps and zero wind
should be a no-brainer. Even on a hot a muggy summer day like it was this
weekend, there's plenty of performance margin to make it a non-event if you
know how to do it.
But, at night, in poor visibility, with no landing light to help you judge
your height above the runway, and having never practiced them seems like
the wrong time to be learning. None of these things are serious by
themselves, but it sounds like it all adds up to a case of get-home-itis to
me.
I used runway 19 because runway 1 has trees on the approach and I wanted to
come in as flat as possible.
That sounds like a good decision.
Anyway...how many different things can cause this? Where should I start
looking?
Piper and Cessna took interesting divergent paths when they designed their
airplanes. Piper decided they were going to use electric trim and manual
flaps. Cessna decided on electric flaps and manual trim. In both cases,
each manufacturer added one totally unnecessary electric system and thus
saddled their owners with forever pouring money into fixing them. Maybe
the high-wing design made it difficult to engineer a manual flap control
linkage? In any case, if it's not the breaker, if could be the actuator
switch, the motor, one of the micro-switches that limit movement, or any of
the wiring in between. Just bring it to your mechanic with your checkbook
and let him put another kid through college :-)
I also recommend that everyone do some no flap landings each year.
Indeed. If you fly something with electric flaps where flap failures are a
way of life, maybe a lot more often than that. With practice, no-flaps
landings in a 177 should be a piece of cake. Slips help, so practice those
too.
Old July 10th 07, 02:37 PM posted to rec.aviation.owning,rec.aviation.piloting
Tina
Default flaps
It also seems you planned a nighttime arrivial with a known burned out
landing light.
Little mistakes have a way of compounding themselves. You may want to
sit in a quiet place and think about your go - no go criteria for a
while. The two best outcomes of all of this is you made a safe trip,
and you have an opportunigy to make future trips safer.
flaps Kobra[_4_] Piloting 84 July 16th 07 06:16 PM
Flaps on take-off and landing Mxsmanic Piloting 397 September 22nd 06 09:02 AM
Fowler flaps? TJ400 Home Built 20 May 19th 06 02:15 AM
FLAPS skysailor Soaring 36 September 7th 05 05:28 AM
FLAPS-Caution Steve Leonard Soaring 0 August 27th 05 04:10 AM
