A New Lawn Chair Pilot
Old July 10th 07, 05:01 PM posted to rec.aviation.piloting
Dallas
Default A New Lawn Chair Pilot
On Tue, 10 Jul 2007 07:32:04 -0700, RL Anderson wrote:
http://www.komotv.com/news/local/8399237.html
Does someone trying something like this need a lighter-than-air category
free balloon class rating certificate to be legal?
Dallas
Old July 10th 07, 05:41 PM posted to rec.aviation.piloting
texasflyer
He's flying under Part 103 regs, wherein an "unpowered" ultralight
aircraft has a max of 155 lbs "dry" weight. Ballast weight is excluded
from that 155lbs in the case of a free-balloon type aircraft.
Old July 10th 07, 05:46 PM posted to rec.aviation.piloting
Jim Logajan
If the whole contraption weighs less than 254 pounds empty (excluding his
parachute), then Part 103 applies and no certificate is needed either for
the pilot or the craft.
Old July 10th 07, 05:55 PM posted to rec.aviation.piloting
texasflyer
The 254 lb limit is for "powered" ultralight aircraft (i.e.
airplanes, rotorcraft, airships) that use some kind of motor for
forward propulsion.
Unpowered ultralight aircraft (gliders, ballons, etc) have to weight
under 155 lbs, and any fuel needed onboard to create lift (i.e.
propane for a burner) or ballast needed to control buoyancy is not
included in that 155 lbs.
Believe it or not, there have been a lot more people flying helium
balloon lawnchairs (cluster balloons) around than you hear about in
the media.
See http://www.clusterballoon.org
Old July 10th 07, 07:50 PM posted to rec.aviation.piloting
Jim Logajan
his parachute), then Part 103 applies and no certificate is needed
either for the pilot or the craft.
forward propulsion.
Oops! Thanks for the gentle correction.
the media.
Yup - There is also a related single-envelope hot-air type known as
"cloudhoppers":
http://www.cloudhoppers.org/
"Lawn Chair, Two O'Clock, One Mile..." quietguy Piloting 27 May 27th 07 01:55 PM
Pull up a chair and hear me out: Vaughn Aviation Marketplace 0 February 2nd 06 02:04 AM
OSH - the chair thing Montblack Owning 9 July 24th 03 08:19 PM
OSH - the chair thing Montblack Piloting 9 July 24th 03 08:19 PM
