flaps
Old July 11th 07, 12:53 AM posted to rec.aviation.owning,rec.aviation.piloting
Peter Clark
Default flaps
On Tue, 10 Jul 2007 16:40:28 -0700, "Al G"
Basically, the lawyers have set it up so that Nav III aircraft have
stricter limits on what equipment is required than in the older
aircraft that you're used to by creating a KOEL (effectively a MEL).
The way it was explained to me is that just like a MEL, in these ones
(and I'm pretty sure the 172 Nav III has it as well but don't have a
POH or IM handy) since the flap motor and indicator are listed as
required by the table in the limitations section, they have to be
working or you're not in fact airworthy - regardless of the operation.
The POH has effectively removed the decision from you in an aircraft
with a MEL or KOEL.
So if the flap switch is inop, you're good to go?
If you can somehow prove it's the switch and not the motor without
being an A&P and re-rigging the electrical wiring to show the motor
and indicator are both working, I guess. The intent of the limitation
- flaps have to be working - is obvious. They don't say you have to
actually use them, but they do have to be in working order.
Old July 11th 07, 03:51 AM posted to rec.aviation.owning,rec.aviation.piloting
Roy Smith
Default flaps
Peter Clark wrote:
The intent of the limitation - flaps have to be working - is obvious.
They don't say you have to actually use them, but they do have to be in
working order.
There is some logic in this. All the Cessna AFMs I've seen (i.e. for
various flavors of their piston singles) have nice detailed performance
charts showing how much runway you need to land with various combinations
of weight, temperature, elevation, wind, and phase of moon, but the numbers
always are for full flaps. There is NO data on how much runway you need
without flaps, therefor there is no way you can comply with 91.103 which
requires that you familiarize yourself with the takeoff and landing
distances.
Now, you know, and I know, and every body hanging out in the airport coffee
shop knows that you can land a 172 with no flaps on a 2000 foot paved
runway without any problems (assuming you know what you're doing). But,
that doesn't count when it comes to determining if the airplane is
airworthy. Remember, airworthy is a state of paperwork, nothing more,
nothing less.
Old July 11th 07, 05:39 AM posted to rec.aviation.owning,rec.aviation.piloting
Marty Shapiro
Default flaps
Roy Smith wrote in
in working order.
performance charts showing how much runway you need to land with
various combinations of weight, temperature, elevation, wind, and
phase of moon, but the numbers always are for full flaps. There is NO
data on how much runway you need without flaps, therefor there is no
way you can comply with 91.103 which requires that you familiarize
yourself with the takeoff and landing distances.
coffee shop knows that you can land a 172 with no flaps on a 2000 foot
paved runway without any problems (assuming you know what you're
doing). But, that doesn't count when it comes to determining if the
airplane is airworthy. Remember, airworthy is a state of paperwork,
nothing more, nothing less.
The POH for the 1977 C172N Skyhawk (D1082-13-RPC-1000-9/89) has
exactly one landing table, on page 5-21, marked "Short Field". This table
ONLY shows landing distance based on max weight of 2300 lbs. In Section 4
"Normal Procedures" on page 4-19, under "Normal Landing", the POH states
"Normal landing approaches can be made with power-on or power-off with any
flap setting desired."
An interpretation of 91.103 requiring that you know how much runway
you need to land or your not airworthy combined with the information
provided in this POH implies that you can never legally land a 1977 C172N
uless you are at max weight, doing a short field landing, full flaps, and
have the capability of inflight refueling (or some other means of ensuring
fuel burn doesn't reduce your weight below max) during the landing!
I guess no one has ever landed an airworthy 1977 C172N!
Marty Shapiro
Silicon Rallye Inc.
(remove SPAMNOT to email me)
Old July 11th 07, 09:54 PM posted to rec.aviation.owning,rec.aviation.piloting
karl gruber[_1_]
Default flaps
"Marty Shapiro" wrote in message
Landing an unairworthy airplane is not the question.
It's knowingly taking off with an unairworthy airplane that is not only
illegal but stupid.
Karl
Old July 11th 07, 05:47 AM posted to rec.aviation.owning,rec.aviation.piloting
Jim Carter[_1_]
Default flaps
"Roy Smith" wrote in message
working order.
numbers
distances.
coffee
nothing less.
Since the '60s, '70s, and '80s models showed no flap landing data, and flaps
were considered optional this question really boils down to what the POH
says for the particular aircraft being flown. Students learning at busy
commercial airports almost never used flaps as a normal procedure.
Of course we taught recovery from fully developed spins to instructors back
then also. Isn't it interesting that some modern aircraft could be
considered out-of-service for inop flaps, but only a few years ago they were
very optional. I imagine that today a DER or FSDO inspector would have a
stroke if we used all 60 degrees we had on the old O-1s or rolled on a wheel
landing with them at zero.
Jim Carter
Rogers, Arkansas
Old July 11th 07, 04:25 PM posted to rec.aviation.owning,rec.aviation.piloting
Al G[_2_]
Default flaps
working order.
numbers
distances.
coffee
airworthy.
Well said Roy. I can see Cessna adding it to the "Operating Limits",
after all the charts
for that aircraft using specify their use, hence the KOEL. The 1967 172H
manual I'm looking at has a single page limitations section, with no mention
of flaps. Just the Day/Night/VFR, with instruments, IFR, normal category.
The landing chart is a single line assuming short field over an obstacle,
with 40 degrees of flap.
Remember, airworthy is a state of paperwork, nothing more, nothing less.
Interesting concept, what would Orville, Wilbur, or Dudley think? You
don't happen to have an "FAA" definition of airworthy do you?
Al G
Old July 11th 07, 06:38 PM posted to rec.aviation.owning,rec.aviation.piloting
Hilton
Default flaps
I do.
A review of case law relating to airworthiness reveals two conditions that
must
be met for an aircraft to be considered "airworthy." 49 U.S.C. § 44704(c)
and 14 CFR § 21.183(a), (b),
and (c) state that the two conditions necessary for issuance of an
airworthiness certificate:
a. The aircraft must conform to its TC. Conformity to type design is
considered attained when the
aircraft configuration and the components installed are consistent with the
drawings, specifications,
and other data that are part of the TC, which includes any supplemental type
certificate (STC) and
field approved alterations incorporated into the aircraft.
b. The aircraft must be in a condition for safe operation. This refers to
the condition of the
aircraft relative to wear and deterioration, for example, skin corrosion,
window delamination/crazing,
fluid leaks, and tire wear.
NOTE: If one or both of these conditions are not met, the aircraft would be
considered unairworthy.
Hilton
Old July 11th 07, 10:36 PM posted to rec.aviation.owning,rec.aviation.piloting
Andrew Gideon
Default flaps
be considered unairworthy.
What about an otherwise airworthy aircraft whose airworthiness certificate
was destroyed in the laundry? Is that airplane airworthy?
My understanding (not having researched this; just what I was told) is
that it is not. That despite being itself in fine shape absent a
paperwork problem.
Not quite the same, but still not really TC or "condition for safe
operation" issue: what about a perfectly fine airplane that's out of
annual. Let's take it further, and say that it received a 100 hour
inspection on Jan 31 and was out of annual on Feb 1.
The only difference is the lack of an IA's signature. Unairworthy?
- Andrew
Old July 12th 07, 07:54 AM posted to rec.aviation.owning,rec.aviation.piloting
Hilton
Default flaps
Andrew,
Airworthy is not the same as flyable or safe for flight etc.
Hilton
"Andrew Gideon" wrote in message
news
paperwork problem.
- Andrew
Old July 12th 07, 03:31 PM posted to rec.aviation.owning,rec.aviation.piloting
Andrew Gideon
Default flaps
Yes, that is my point.
- Andrew
Cowl Flaps N114RW Home Built 0 June 27th 07 09:25 PM
What are cowl flaps? Mxsmanic Piloting 31 October 27th 06 04:28 PM
Fowler flaps? TJ400 Home Built 20 May 19th 06 02:15 AM
FLAPS skysailor Soaring 36 September 7th 05 05:28 AM
FLAPS-Caution Steve Leonard Soaring 0 August 27th 05 04:10 AM
