![]() "Matt Whiting" wrote: The Arrow I now fly which has a 3-blade prop is much worse than my 182 in the glide ratio department. I can barely make a 180 power-off landing with it. You have to turn base as soon as you cut power abeam the landing spot or you'll never make it! As a CFI giving me a checkout in an Arrow put it: "You can cut the power and glide a Cessna in, but a Piper comes down like dropped car keys." -- Dan T-182T at BFM |
Dan Luke wrote:
"Matt Whiting" wrote: The Arrow I now fly which has a 3-blade prop is much worse than my 182 in the glide ratio department. I can barely make a 180 power-off landing with it. You have to turn base as soon as you cut power abeam the landing spot or you'll never make it! As a CFI giving me a checkout in an Arrow put it: "You can cut the power and glide a Cessna in, but a Piper comes down like dropped car keys." The Arrow wasn't all that bad with the original two-blade prop. But when the hub failed inspection requiring prop replacement, a decision was made to go with the 3-blade as it was cheaper (go figure). What a mistake. The 3-blade vibrates much more, doesn't perform any better on takeoff, climb or cruise, and performs MUCH worse during glide. Matt |
Matt Whiting wrote:
The Arrow wasn't all that bad with the original two-blade prop. But when the hub failed inspection requiring prop replacement, a decision was made to go with the 3-blade as it was cheaper (go figure). What a mistake. The 3-blade vibrates much more, doesn't perform any better on takeoff, climb or cruise, and performs MUCH worse during glide. I'd look into having the prop indexed (ie. moved one blade on the hub) to fix the vibration issue... With the 3 blade, climb should be better, cruise will suffer, takeoff noise should be reduced too... My neighbors Baron lost nearly 8 knots on cruise, he's alot quieter when taking off over the house, and climbs very well out of short strips though... |
On Thu, 12 Jul 2007 04:17:41 GMT, Darrel Toepfer
wrote: Matt Whiting wrote: The Arrow wasn't all that bad with the original two-blade prop. But when the hub failed inspection requiring prop replacement, a decision was made to go with the 3-blade as it was cheaper (go figure). What a mistake. The 3-blade vibrates much more, doesn't perform any better on takeoff, climb or cruise, and performs MUCH worse during glide. I'd look into having the prop indexed (ie. moved one blade on the hub) to fix the vibration issue... With the 3 blade, climb should be better, cruise will suffer, takeoff noise should be reduced too... My neighbors Baron lost nearly 8 knots on cruise, he's alot quieter when taking off over the house, and climbs very well out of short strips though... On the Deb I lost about 4 MPH on cruise and gained over 250 fpm on climb. It also made energy management and landings much easier. Now when ATC says "keep the speed up as long as praticable" it'll raise some eyebrows. :-)) Love it! |
On Tue, 10 Jul 2007 20:14:04 -0500, "Dan Luke"
wrote: "Matt Whiting" wrote: The Arrow I now fly which has a 3-blade prop is much worse than my 182 in the glide ratio department. I can barely make a 180 power-off landing with it. You have to turn base as soon as you cut power abeam the landing spot or you'll never make it! As a CFI giving me a checkout in an Arrow put it: "You can cut the power and glide a Cessna in, but a Piper comes down like dropped car keys." You can also dead stick a Cherokee 180 with a little practice. If you want steep try landing a Glasair III power off. It has a little bitty wing with nearly 30# per sq foot of wing loading. The Cherokee is about 17# (give or take depending on year and version) At best glide you are probably looking at descent greater than 2200 fpm yet you should be able to grease it on. Even a Bonanza power off with gear out and full flaps has an impressive rate of descent.OTOH with gear and flaps up best glide at roughly 120 MPH gives a rate of descent of only 500 to 600 fpm which gives a glide ratio between 17.6 and 21 to one. Engine out is gear up and no flaps until the runway is made. Then you hit the gear switch and flap switch to full. As you need to get rid of a LOT of speed it's a good idea to practice this so you know "when the runway is made" because if you wait until you are over the end of the runway you are going to use a LOT of it, probably over 3000 feet. OTOH a short filed landing will use less than 1200 and with a bit of practice you can shorten that. Of course, final for a short field is STEEP. Flaps are a good portion of the energy management. |
Cowl Flaps | N114RW | Home Built | 0 | June 27th 07 09:25 PM |
What are cowl flaps? | Mxsmanic | Piloting | 31 | October 27th 06 04:28 PM |
Fowler flaps? | TJ400 | Home Built | 20 | May 19th 06 02:15 AM |
FLAPS | skysailor | Soaring | 36 | September 7th 05 05:28 AM |
FLAPS-Caution | Steve Leonard | Soaring | 0 | August 27th 05 04:10 AM |
