On Wed, 11 Jul 2007 17:38:09 +0000, Hilton wrote:
NOTE: If one or both of these conditions are not met, the aircraft would be considered unairworthy. What about an otherwise airworthy aircraft whose airworthiness certificate was destroyed in the laundry? Is that airplane airworthy? My understanding (not having researched this; just what I was told) is that it is not. That despite being itself in fine shape absent a paperwork problem. Not quite the same, but still not really TC or "condition for safe operation" issue: what about a perfectly fine airplane that's out of annual. Let's take it further, and say that it received a 100 hour inspection on Jan 31 and was out of annual on Feb 1. The only difference is the lack of an IA's signature. Unairworthy? - Andrew |
![]() "Roy Smith" wrote in message order. There is some logic in this. All the Cessna AFMs I've seen (i.e. for various flavors of their piston singles) have nice detailed performance charts showing how much runway you need to land with various combinations of weight, temperature, elevation, wind, and phase of moon, but the numbers always are for full flaps. There is NO data on how much runway you need without flaps, therefor there is no way you can comply with 91.103 which requires that you familiarize yourself with the takeoff and landing distances. Well, you certainly haven't seen all the Cessnas POHs. Mine has performance numbers for "SHORT FIELD" only. Normal landings can be conducted with ANY amount of flaps, per the FLAP LIMITATIONS section. Karl |
flaps | Kobra[_4_] | Piloting | 84 | July 16th 07 06:16 PM |
Flaps on take-off and landing | Mxsmanic | Piloting | 397 | September 22nd 06 09:02 AM |
Fowler flaps? | TJ400 | Home Built | 20 | May 19th 06 02:15 AM |
FLAPS | skysailor | Soaring | 36 | September 7th 05 05:28 AM |
FLAPS-Caution | Steve Leonard | Soaring | 0 | August 27th 05 04:10 AM |
