Compressed air as fuel?
Old July 12th 07, 05:23 PM posted to rec.aviation.homebuilt
Dancing Fingers
Default Compressed air as fuel?
On Jun 26, 10:23 pm, Orval Fairbairn
In article .com,
Dancing Fingers wrote:
Hi Guys,
I remember years ago Kitplanes did a series on the potential for
batterry-powered aircraft. Recently, I watCHED Future Cars on the
Discovery channel and this guy had developed a car that ran on
compressed air. This seems like a more viable fuel for aircraft then
batteries. Has anybody looked into it?
just curious.
Chris
You ned either:
1. a very long hose attached to a compressor or
2. a filament-wound balonium/unobtanium air tank filled with air
compressed to 100,000,000 psi.
Otherwise, you just can't carry enough compressed air around to make a
practical vehicle.
The "Future Car" ranks right there along with Moller's "Skycar," in that
it is all vaporware.
I certainly don't think that compressed air would power a airliner but
it might be viable for small commutter flights. It seems like the
heat issue would only be an issue on the ground, during refueling,
although cabin heat would be a challenge. I was really wondering if
anyone had ever calculated the energy per cubic foot compressed air
can hold, relative to gasoline, diesel and hydrogen. There's a new
engine being developed, the Quasiturbine, that would be perfect for
this application.
For what it's worth.
Chris
Old July 12th 07, 06:02 PM posted to rec.aviation.homebuilt
cavelamb himself
this application.
Chris
The straight answer?
Not on this, or any other planet in this solar system...
Richard
Old July 12th 07, 11:21 PM posted to rec.aviation.homebuilt
Vaughn Simon
"Dancing Fingers" wrote in message
In article .com,
Hi Guys,
just curious.
Chris
You ned either:
practical vehicle.
Kindly compare energy densities for yourself.
Jet fuel 11,694 Wh/kg
Gasoline 12,200 Wh/kg
Compressed air 34 Wh/kg
For a given weight of fuel, your air-powered "commutter" aircraft would have to
somehow get by with less than 1% of the range that it would have with
conventional fuel.
Source: http://xtronics.com/reference/energy_density.htm
Of course, that is gravimetric density and you asked about volumetric density.
Volumetric density would probably be an even worse comparison, but would depend
greatly on the air storage pressure you wish to assume. Naturally, you must
design your "fuel tank" heavier and heavier as storage pressure increases.
Exotic materials would help, but not enough. Also, high pressure air tanks must
be round, but the space available to contain the tank will not be round, so much
potential storage capacity would be lost.
There's a new engine being developed, the Quasiturbine, that would be perfect
for
this application.
The type of engine would not matter. You just can't carry enough stored energy
to be practical.
It is worth nothing
Vaughn
Old July 13th 07, 03:45 AM posted to rec.aviation.homebuilt
Harry K
In article .com,
Hi Guys,
just curious.
Chris
You ned either:
practical vehicle.
this application.
Chris- Hide quoted text -
- Show quoted text -
You can put the "quasiturbine" right in the same category as the 'air
car" and "Moller's flying car" all of them are vapor ware. To
address the 'quasitubine' specifically, It has been "under
developement for at least 10 years and I think longer with no
progress. It is an extremely complicated design for a rotary engine
with little or no improvement over the original Mazda (IIRC) rotary
engine.
The heat problem is not in getting rid of it. The problem is that
that heat was produced while compressing the air and is then thrown
away. Right there should be a clue as one of the major reasons why
and "air engine" is not an economicaly viable design. That heat costs
money and represents energy that cannot be recovered.
Harry K
Old July 13th 07, 11:21 AM posted to rec.aviation.homebuilt
Vaughn Simon
"Harry K" wrote in message
s.com...
This was already explained to the OP, and seems to have made no impression.
Vaughn
Old July 14th 07, 05:43 AM posted to rec.aviation.homebuilt
Dan[_2_]
Harry K wrote:
snip
engine.
Wankel?
Dan, U.S. Air Force, retired
Old July 14th 07, 03:59 AM posted to rec.aviation.homebuilt
Ernest Christley
this application.
Chris
Not only is the energy density of the compressed air ridiculously low
and nearly impossible to utilize efficiently, but nearly all of the
alternative energy schemes require that the entire set of propellant be
carried. With traditional fuels, the oxidizer is collected as it is
used. Between 12 and 17 pounds of air is ingested for each pound of
fuel carried.
Fuel quality control standards for aircraft rental/fuel sales... [email protected] Owning 19 January 19th 05 04:12 AM
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve Bill Berle Aviation Marketplace 0 January 26th 04 07:48 AM
Pre-Rotator Powered by Compressed Air? nuke Home Built 8 July 30th 03 12:36 PM
Pre-Rotator Powered by Compressed Air? Gil G. Rotorcraft 9 July 30th 03 12:36 PM
Pre-Rotator Powered by Compressed Air? nuke Rotorcraft 0 July 28th 03 12:52 AM
