On 2007-07-14 18:09:32 -0700, Ron Rosenfeld said:
On Fri, 13 Jul 2007 07:36:28 -0700, C J Campbell wrote: It appears that I am having a little bit of trouble with my heart. It came on rather suddenly, as an EKG last December showed no problem at all. But apparently I have developed something called an atrial fibrillation. It doesn't look good for my flying status, but we shall see. If you're otherwise healthy, odds are that it will be controllable (drug therapy) or correctable (some reversible cause; conversion; or a procedure called ablation) and that you'll be able to fly. How long you won't be able to fly depends on too much information to glean here. I guess I find out more Monday. I suppose some of it depends on what caused the problem in the first place. -- Waddling Eagle World Famous Flight Instructor |
There are a series of heart symptoms listed in the FAR's that constitute
cause for 'self-grounding' (see 67.). AF is not listed as a condition that requires you to ground yourself. You can choose to, but if a cardiologist says you are OK, then I believe you can continue to fly. The problem comes with the next medical where you must declare the condition and your treatment. You should expect to have to do the following: 1. Go through a maximal stress test 2. Get a letter from cardiologist indicating his/her judgement of the state of your cardiac health as well as any and all medications. 3. Possibly produce the results of a Holter Monitor (24 hour EKG). 4. You MAY have to go the 'Special Issuance' route, which means you can plan on doing 1,2,3 every year. Not for AF, but I have been doing this process for the last 7 years. PITA, but I have my medical If you are a member, call AOPA "C J Campbell" wrote in message news:2007071419345350073-christophercampbell@hotmailcom... On 2007-07-14 18:09:32 -0700, Ron Rosenfeld said: On Fri, 13 Jul 2007 07:36:28 -0700, C J Campbell wrote: It appears that I am having a little bit of trouble with my heart. It came on rather suddenly, as an EKG last December showed no problem at all. But apparently I have developed something called an atrial fibrillation. It doesn't look good for my flying status, but we shall see. If you're otherwise healthy, odds are that it will be controllable (drug therapy) or correctable (some reversible cause; conversion; or a procedure called ablation) and that you'll be able to fly. How long you won't be able to fly depends on too much information to glean here. I guess I find out more Monday. I suppose some of it depends on what caused the problem in the first place. -- Waddling Eagle World Famous Flight Instructor |
On 2007-07-16 14:34:46 -0700, "pgbnh" said:
There are a series of heart symptoms listed in the FAR's that constitute cause for 'self-grounding' (see 67.). AF is not listed as a condition that requires you to ground yourself. You can choose to, but if a cardiologist says you are OK, then I believe you can continue to fly. The problem comes with the next medical where you must declare the condition and your treatment. You should expect to have to do the following: 1. Go through a maximal stress test 2. Get a letter from cardiologist indicating his/her judgement of the state of your cardiac health as well as any and all medications. 3. Possibly produce the results of a Holter Monitor (24 hour EKG). 4. You MAY have to go the 'Special Issuance' route, which means you can plan on doing 1,2,3 every year. Not for AF, but I have been doing this process for the last 7 years. PITA, but I have my medical If you are a member, call AOPA Thanks, everyone. You guys really are a great bunch. Now we shall see what the cardiologist says. -- Waddling Eagle World Famous Flight Instructor |
Where's my Purple Heart? | Jack | Military Aviation | 10 | July 15th 04 01:26 AM |
If you don't want to break your heart | HECTOP | Piloting | 19 | May 14th 04 09:53 PM |
The Purple Heart Registry | Otis Willie | Military Aviation | 1 | March 22nd 04 03:51 AM |
