ArtKramr wrote:
Subject: Aircrew casualities From: Guy Alcala Date: 9/16/03 9:09 PM Pacific Daylight Time Message-id: e (and thus less effective fire from the fighters, due to evasive action and longer firing ranges), and in the last resort, it being much easier to find and put on parachutes and then locate the Interesting.We never took evasive action against fighters.we jus tightened our formation, stayed on course and returned their fire. No, I meant the fighters taking evasive action on the run-in, and preparing to do so after the firing pass. At night, they could usually just cruise leisurely into position behind/under (with Schrage Musik) the bomber at very short range, aim for the fuel/oil tanks in the wings, and fire. 50-100 yd firing ranges weren't uncommon for the better pilots. We did take evasive action against flak. Find their parachutes??? We wore them from the ground up.Y'mean the Brits didn't??? If you got hit and didn't have your chute on it was often too late to put it on. The USAAF bomber crew didn't have backpack parachutes either for quite a while (it seems to have been late in 1943 that they started to come in). Normally it was a clip-on chest chute, and they were normally left off until needed as they made it difficult to move around in the a/c. Pilots got seat pack or backpack chutes (in some cases, from the Brits) first. That's another reason why ball turret gunners had such a high casualty rate; there was no room in the turret for them to have their chutes, so they had to first make it back up into the fuselage, get their chute and put it on before they could jump. The waist gunners had it far easier. Guy |
From: Guy Alcala Date: 9/18/03 11:53 AM Pacific Daylight Time Message-id: No, I meant the fighters taking evasive action on the run-in, and preparing to do Never saw that once. Thyey would drop tgheior inside wing and their nose would swing in toward us and we hten knew they had started their classic fighter approach. And once they set up constant bearing, they never swerved, changed course or took evasive action at all. They just bore in on their heading of constant bearing firing as they came. The USAAF bomber crew didn't have backpack parachutes either for quite a while (it seems to have been late in 1943 that they started to come in). Normally it was a The USAAF bomber crew didn't have backpack parachutes either for quite a while (it seems to have been late in 1943 that they started to come in). Normally it was a I wore a chestpack. The tail gunner and the top turrest gunners also had chestpacks and we wore them in our positions with no problem. We never ever flew missions with chutes off. And in 1943 both our pilot and copilot flew with backpacks, the rest of us wore chestpacks and once in the air never took them of except when I had to enter the bomb bays. I couldn't fit through the bombay access door with a chestpack on. Arthur Kramer 344th BG 494th BS England, France, Belgium, Holland, Germany Visit my WW II B-26 website at: http://www.coastcomp.com/artkramer |
From: "Gord Beaman" ) Date: 9/18/03 1:31 PM Pacific Daylight Time Message-id: (ArtKramr) wrote: I wore a chestpack. The tail gunner and the top turrest gunners also had chestpacks and we wore them in our positions with no problem. We never ever flew missions with chutes off. And in 1943 both our pilot and copilot flew with backpacks, the rest of us wore chestpacks and once in the air never took them of except when I had to enter the bomb bays. I couldn't fit through the bombay access door with a chestpack on. Arthur Kramer Art, I remember three or four days ago you mentioned that your escape route was through the bomb bay, here's what you said: In the B-26 we had no escape hatch at all. The bombardier had along path to creawl in front of the copilot then out the bombay. How did you work that?...or did I misunderstand something?. -- -Gord. Entering the bomb bay for two different purposes. When entering the bombay to do repaireslike kicking out a hung up bomb, I wore no chute at all, Nervious work with the bombay doors open. For bailout, unhook one side of the chest pack, step out, rehook it and bail out.But where possible go out the nosewheel well. It is a lot faster and a shorter trip. Luckily I never had to do either. Arthur Kramer 344th BG 494th BS England, France, Belgium, Holland, Germany Visit my WW II B-26 website at: http://www.coastcomp.com/artkramer |
From: "Gord Beaman" ) Date: 9/18/03 6:10 PM Pacific Daylight Time Message-id: (ArtKramr) wrote: Entering the bomb bay for two different purposes. When entering the bombay to do repaireslike kicking out a hung up bomb, I wore no chute at all, Nervious work with the bombay doors open. For bailout, unhook one side of the chest pack, step out, rehook it and bail out.But where possible go out the nosewheel well. It is a lot faster and a shorter trip. Luckily I never had to do either. Arthur Kramer I see...thank you. -- -Gord. One more point. With certain types of battle damage you may not be able to lower the wheels so that last option may not be available. Arthur Kramer 344th BG 494th BS England, France, Belgium, Holland, Germany Visit my WW II B-26 website at: http://www.coastcomp.com/artkramer |
ArtKramr wrote:
Subject: Aircrew casualities From: Guy Alcala Date: 9/18/03 11:53 AM Pacific Daylight Time Message-id: No, I meant the fighters taking evasive action on the run-in, and preparing to do Never saw that once. Thyey would drop tgheior inside wing and their nose would swing in toward us and we hten knew they had started their classic fighter approach. And once they set up constant bearing, they never swerved, changed course or took evasive action at all. They just bore in on their heading of constant bearing firing as they came. "Evasive action' was a poor choice of words on my part; involuntary flinching before the breakaway, and doing the breakaway early for fear of collision/gunfire, was more what I meant. The USAAF bomber crew didn't have backpack parachutes either for quite a while (it seems to have been late in 1943 that they started to come in). Normally it was a The USAAF bomber crew didn't have backpack parachutes either for quite a while (it seems to have been late in 1943 that they started to come in). Normally it was a I wore a chestpack. The tail gunner and the top turrest gunners also had chestpacks and we wore them in our positions with no problem. We never ever flew missions with chutes off. And in 1943 both our pilot and copilot flew with backpacks, the rest of us wore chestpacks and once in the air never took them of except when I had to enter the bomb bays. I couldn't fit through the bombay access door with a chestpack on. Then it must have been 8th AF practice not to wear them, as numerous accounts exist of crews trying to buckle theirs on in a hurry. The RAF bomber crews didn't normally wear theirs either, aside from the pilots and the tail gunner. Guy |
From: Guy Alcala Date: 9/22/03 2:51 PM Pacific Daylight Time Message-id: 3F6F6FE0.3067CB20@junkpo Then it must have been 8th AF practice not to wear them, as numerous accounts exist of crews trying to buckle theirs on in a hurry. The RAF bomber crews didn't normally wear theirs either, aside from the pilots and the tail gunner. Guy The mind boggles (sheesh) Arthur Kramer 344th BG 494th BS England, France, Belgium, Holland, Germany Visit my WW II B-26 website at: http://www.coastcomp.com/artkramer |
From: Guy Alcala Date: 9/22/03 2:51 PM Pacific Daylight Time Message-id: "Evasive action' was a poor choice of words on my part; involuntary flinching before the breakaway, and doing the breakaway early for fear of collision/gunfire, was more what I meant. I never once saw that. It would be a foolish thing for the pilot to do. If he bore in and came out the other side it was a clean getaway, But if he flinched and turned away before he got to us he would expose his belly and vastly increase his chance of being shot down by the bomber's gunners. I guess young inexperienced pilots scared to death might do that. But not the old hands. Anyway. if you are a gunner in a bomber and a fighter comes at you don't count on his tuning way before his run is done. Arthur Kramer 344th BG 494th BS England, France, Belgium, Holland, Germany Visit my WW II B-26 website at: http://www.coastcomp.com/artkramer |
USCG enlisted aircrew wings | C Knowles | Military Aviation | 0 | August 17th 03 12:30 AM |
ADF aircrew with basal cell carcinoma removed | BCC Pilot | Military Aviation | 0 | July 10th 03 12:59 PM |
