don't know anything about the cited incident but. Ever watch an older
mooney doing the gearup dip on takeoff? pulling that johnson bar takes your attention off the flight attitude. "john smith" wrote in message ... DESCRIPTION AIRCRAFT ON TAKEOFF, SANK DOWN ONTO RUNWAY WITH GEAR RETRACTED, FORT LAUDERDALE, FL Is this an example of putting the gear lever up before advancing the throttle for takeoff? |
On Wed, 18 Jul 2007 14:26:45 +0000, john hawkins wrote:
don't know anything about the cited incident but. Ever watch an older mooney doing the gearup dip on takeoff? pulling that johnson bar takes your attention off the flight attitude. Cessna gear (ie. an R182) folds under in such a way that drag is increased during the retraction (or extension) beyond the level of drag with the gear extended (or retracted, of course {8^). I've never thought it that much that it would cause an altitude loss, but perhaps under the right circumstances...? - Andrew |
![]() "Andrew Gideon" wrote in message news ![]() On Wed, 18 Jul 2007 14:26:45 +0000, john hawkins wrote: don't know anything about the cited incident but. Ever watch an older mooney doing the gearup dip on takeoff? pulling that johnson bar takes your attention off the flight attitude. Cessna gear (ie. an R182) folds under in such a way that drag is increased during the retraction (or extension) beyond the level of drag with the gear extended (or retracted, of course {8^). I've never thought it that much that it would cause an altitude loss, but perhaps under the right circumstances...? - Andrew The old 210's and skymasters were the same way. Once all of those doors start opening, there is a slew of new drag. An Ex-Boss of mine was demonstrating the squat switch to a prospective buyer, when he retracted the 210 nose gear while sitting firmly on the ground. Al G |
On Jul 18, 2:51 pm, "Al G" wrote:
"Andrew Gideon" wrote in message news ![]() On Wed, 18 Jul 2007 14:26:45 +0000, john hawkins wrote: don't know anything about the cited incident but. Ever watch an older mooney doing the gearup dip on takeoff? pulling that johnson bar takes your attention off the flight attitude. Cessna gear (ie. an R182) folds under in such a way that drag is increased during the retraction (or extension) beyond the level of drag with the gear extended (or retracted, of course {8^). I've never thought it that much that it would cause an altitude loss, but perhaps under the right circumstances...? - Andrew The old 210's and skymasters were the same way. Once all of those doors start opening, there is a slew of new drag. An Ex-Boss of mine was demonstrating the squat switch to a prospective buyer, when he retracted the 210 nose gear while sitting firmly on the ground. Al G We have an R182. The gear retracting will bring the nose up as the weight of the mains shifts back. The altitude doesn't want to change much with the gear in transit. The main wheels are small- diameter, wider 15 x 6.00-6's, and they don't have much more drag sideways than they do edge-on. The nosewheel has the squat switch. The mains, being spring-steel tubes, don't have any movement to fire a squat switch. This is a distinct disadvantage, becuase the nosegear has to be collapsed a little to open the switch, and in the landing roll the strut can remain extended until brakes are applied. Add to that the often-sticky oleo setup on these things, and you have a switch that might remain closed until tiedown. A decent pilot will use aerodynamic braking and will be careful not to slam the nose onto the runway, so that silly squat switch is closed for a long time after touchdown and if he has the habit of grabbing the flap switch in the rollout he'll sooner or later select gear-up instead and get a nasty surprise. We nearly had it happen once during an evaluation of another pilot. Dan |
John, my husband used to fly a Mooney Ranger with the manually
retracted gear, and he always added a little forward pressure on the yoke when pulling them up to reduce the force on the Joe bar. The 'dip' was on purpose. He had enough air under him when he did it, though. What he says is, the gear stays down until you're sure you're not going to need it, and that means being pretty high when operating off a 5000 foot runway. Does anyone know if the wheels on those Mooneys were interlocked to prevent someone from pulling on the Jor bar while the wheels still carried weight? |
Gear Up, pt 4 - Crashed He 111 with balloon cable cutting gear - July 1940.jpg (1/1) | Mitchell Holman | Aviation Photos | 0 | April 13th 07 01:50 PM |
Crashing on takeoff... how odd | [email protected] | Piloting | 165 | August 31st 06 04:30 AM |
seaplane takeoff | Lets Fly | Owning | 1 | December 5th 05 10:18 PM |
Takeoff with a problem? | Rocky | Piloting | 14 | January 23rd 04 02:26 PM |
Jet takeoff performance | karl gruber | Piloting | 6 | November 21st 03 05:59 PM |
