The reason the F-22 won is based on the RCS part, they both were in the 5%
range on all factors except for one. but the truth is that the 22 was 6 feet smaller than the 23 and had more room for internal stores, it makes a big diffrence in operations. "Ron Monroe" wrote in message ink.net... What's ironic is the the YF-23 looks more like a Lockheed product than the YF-22 does. Ron "Bob Harrington" wrote in message ... "E.D." wrote in . net: I know I'm going get a lotta flack for this but I think the 23 was the best aircraft and that the 22 was a congress pay off to someone. The YF-23 sure wins the 'wicked looks' competion. The F-22 looks a tad waddle-ish from some angles... Bob ^,,^ |
I've heard stories about the RCS. It depends on what aspect you are using.
The F-22 certainly has more surfaces that counter a lower signature from certain aspects. I have also heard where the YF-23 was lower. Several of the engineers were even mad that they concentrated too much on a low RCS when the USAF seemed to dismiss it's importance when the selection was made. Then again, the production F-23A had different inlets to adress the lower RCS . Internal stores? I doubt it. The YF-23 had two huge bays. The claim I heard was that the F-22 was a little bit more maneuverable, due to it's extra surfaces. I wish I kept a copy of the report that came back from the USAF, after the selection was made, giving their reasons for their choice. The YF-23 was also much faster than the YF-22 in mil power, and able to accelerate to supersonic speeds without afterburner or going into a dive. This indicates it had less transonic drag, and would use less fuel over it's lifetime. Supercruise was a driving point of the RFP. And Northrop was just coming out of a period where they were not living up to their promises on past projects. Even Druyan (SP?) was giving Northrop a hard time, which didn't help politically. But, if the aircraft are close, they make the selection based on the aircraft they want, and then use the parameters they want, to justify their decision. We saw this decision making again with the CSAR competition. But, that was 14 years ago, and the YF-22 is finally going into service. I hope it always works well, and everyone will be happy with it, because it's really about the pilots. "Leroy Jackson" wrote in message ... The reason the F-22 won is based on the RCS part, they both were in the 5% range on all factors except for one. but the truth is that the 22 was 6 feet smaller than the 23 and had more room for internal stores, it makes a big diffrence in operations. "Ron Monroe" wrote in message ink.net... What's ironic is the the YF-23 looks more like a Lockheed product than the YF-22 does. Ron "Bob Harrington" wrote in message ... "E.D." wrote in . net: I know I'm going get a lotta flack for this but I think the 23 was the best aircraft and that the 22 was a congress pay off to someone. The YF-23 sure wins the 'wicked looks' competion. The F-22 looks a tad waddle-ish from some angles... Bob ^,,^ |
Leroy Jackson wrote:
The reason the F-22 won is based on the RCS part, they both were in the 5% range on all factors except for one. but the truth is that the 22 was 6 feet smaller than the 23 and had more room for internal stores, it makes a big diffrence in operations. "Ron Monroe" wrote in message ink.net... What's ironic is the the YF-23 looks more like a Lockheed product than the YF-22 does. Ron "Bob Harrington" wrote in message ... "E.D." wrote in gy.net: I know I'm going get a lotta flack for this but I think the 23 was the best aircraft and that the 22 was a congress pay off to someone. The YF-23 sure wins the 'wicked looks' competion. The F-22 looks a tad waddle-ish from some angles... Bob ^,,^ Well Here we go!! I liked the F-23 also. The best design doesn't always win. But anyway. The YF-22 and YF-23 were competing in the USAF's Advanced Tactical Fighter program. Conceived in the early 1980s, to specify a replacement for the F-15 Eagle, contracts for the two most promising designs were awarded in 1986, with the YF-23 delivered in 1989 and the evaluation concluded in 1991. The YF-23 was designed with all-aspect stealth as a high priority and drew on Northrop's experience with the F-18 Hornet and B-2 Spirit. The YF-23 was designed to meet USAF requirements for survivability, supersonic cruise (supercruise), stealth, and ease of maintenance. It introduced the novel feature of rear jet nozzle troughs lined with heat ablating tiles developed by Allison, which shielded the exhaust from IR detection from below. All the control surfaces were coupled together via the VMS to provide 'net effect' aerodynamic control. The wing flaps and ailerons deflected inversely on either side to provide yaw, while the tail provided pitch. Aerodynamic braking was achieved by deflecting the flaps and ailerons on both sides simultaneously. Athough possessing an advanced design, in order to reduce costs and development, a number of F-15 Eagle components were utilized including the standard F-15 nosewheel unit and the forward cockpit of the F-15E Strike Eagle. Two aircraft were built. PAV-1 was fitted with Pratt & Whitney YF119 engines, while PAV-2 was fitted with General Electric YF120 engines. The YF-23 was unofficially named "Black Widow II" by some crew members, due to a marking resembling the red underbelly marking of the black widow spider. The black widow marking was briefly seen under PAV-1 (and made the cover of Aviation Week & Space Technology) before being removed at the insistence of Northrop management. The aircraft was close to Northrop's original ATF concept from 1986. Both aircraft were furnished in the configuration specified before the requirement for thrust reversing was dropped, although there has never been any mention as to whether this feature was tested or not. The weapons bay was not configured for weapons launch and no missiles were carried, unlike Lockheed's demonstration aircraft. Northrop chose to demonstrate this capability using computer simulations. The configuation of the weapons bay has never publicly been revealed, although examination of the flight manual suggests that provision for two AIM-9 Sidewinder missiles was made possible on the weapons bay doors. There were tentative plans to fit a pallet inside the bay if the Northrop/McAir team had won, but this was never done. Indications are that the YF-23 weapons bay may have been less capacious and efficient than the YF-22 system. Although the precise results of the evaluation and the reasons justifying the final decision are not public knowledge and probably never will be due to commercial litigation issues, the USAF chose the winning team based on an awarded points system, which put the YF-22/PW F119 combination slightly ahead of the three other combinations. The reason given at the time was sanitised but suggested that this combination was less risky in terms of technology and project management as well as being slightly cheaper. It has been claimed that the YF-23 was slightly faster and stealthier than the F-22, but was inferior in terms of usable internal volume due to greater emphasis placed on area-ruling. It is also likely that the YF-23 was less representative of the final production configuation than the YF-22. Although the final results were apparently very close, the YF-22 was seen as a safer bet by the Air Force Evaluation Team than the YF-23, and it won the competition in April 1991. It has been speculated in the aviation press that the YF-22 was also seen as more adaptable to the Navy's Navalized Advanced Tactical Fighter (NATF), though as it turned out the US Navy abandoned NATF a few months later. After losing the competition, both YF-23 prototypes were transferred from Northrop to NASA's Dryden Flight Research Center, at Edwards AFB, California. The engines were removed. NASA had no plans to perform flight tests with the airframes, but a proposal was put forward to use one of the two aircraft to study strain gauge loads calibration techniques. The possible production configuration of the F-23A has never been publicly revealed. In the end, however, both aircraft remained in storage until the summer of 1996, when the aircraft were transferred to museums. Aircraft PAV-2 was in exhibit at the Western Museum of Flight in Hawthorne, California and PAV-1[verification needed] was recently moved to the National Museum of the United States Air Force near Dayton, Ohio, where it sits along side the Boeing X-32 in the Aircraft Restoration Hangar. Aircraft PAV-11 is now on display in an outdoor parking area at Northrop Grumman's production facility in El Segundo, California. |
