I understand the characteristics of the Sector OZ and the Cylinder OZ,
and for my badge flights, I would prefer to use the Sector OZ. An RAS thread back in 2000 (before I started flying) seems to indicate that Cambridge FRs are "hard wired" to the Cylinder OZ. I have a 302A CFR. Does that mean I'm stuck with Cylinder OZ's, or can you "declare" intent to use Sector OZs in some way when making badge flights? TIA Jim |
There are a couple of threads on this topic...from
a few years ago. I went through them looking for the same information you are. Unless something has changed recently...you have to get into the sector...which means flying past the cylinder. This technique was described by a couple of different pilots in these old threads. Googling should dig out these old posts. Good luck. |
On Jul 19, 11:22 am, Stewart Kissel
wrote: Unless something has changed recently...you have to get into the sector...which means flying past the cylinder. Slight correction in wording might be in order. This may be totally obvious. A Cyclinder is centered over the turn point. The Sector is beyond the turn point (from the direction of the previous turn point). So "flying past the cyclinder" will work if you go all the way around the cyclinder. However, you only need to get into the Sector, not all the way around the cyclinder. To define the Sector, draw a line from turnpoint A to turnpoint B. Draw another line from turnpoint B to turnpoint C. Draw another line from turnpoint C back to turnpoint A. Make sure to draw the lines so that they extend past the turnpoint. The tails of the lines that are beyond the turnpoints define the sector which basically goes on forever as a ever expanding pie wedge. When going for a distance badge (versus a contest) there is no sense going too far into the Sector as the distance measure is only to the turn point, not beyond. In contests the extra distance can count for something (depends) but not in badge flying. |
There is a lot to be said for trying to round each turnpoint so it can
later be counted as either a cylinder or sector turnpoint. It might save your flight if you make a small error on one of the turnpoints or finish. It did for my gold distance - and that was a tough flight involving a near landout and ridge soaring for a while to get out of a hole, so I really wanted it to count. Darryl On Jul 19, 9:24 am, Marc Ramsey wrote: wrote: I understand the characteristics of the Sector OZ and the Cylinder OZ, and for my badge flights, I would prefer to use the Sector OZ. An RAS thread back in 2000 (before I started flying) seems to indicate that Cambridge FRs are "hard wired" to the Cylinder OZ. I have a 302A CFR. Does that mean I'm stuck with Cylinder OZ's, or can you "declare" intent to use Sector OZs in some way when making badge flights? Nothing is "hard wired" into the flight recorder itself. The determination whether you were using cylinder or sector OZs occurs during post-flight analysis of the IGC file. What can cause confusion is that some flight recorders will provide a signal during flight indicating that one has "arrived" or entered an OZ. The GPS-NAV display provides this signal when one passes within a pre-determined distance of the currently selected turnpoint, which is why some believe that Cambridge flight recorders only support cylinders. If you have moving map software that is driven by the 302A, just fly through the displayed sector OZ, and you should be fine. In any case, a little practice will help make sure that you don't manage to miss an OZ on your big day... Marc |
On Jul 19, 11:01 am, wrote:
I understand the characteristics of the Sector OZ and the Cylinder OZ, and for my badge flights, I would prefer to use the Sector OZ. An RAS thread back in 2000 (before I started flying) seems to indicate that Cambridge FRs are "hard wired" to the Cylinder OZ. I have a 302A CFR. Does that mean I'm stuck with Cylinder OZ's, or can you "declare" intent to use Sector OZs in some way when making badge flights? TIA Jim My 302/303 will indicate sector entry when a task is active. I believe it's a feature of the 303 only, but can't be sure. Although based on the documentation for the 303, it is not compatible with the 302A. So you might be out of luck. You could contact the folks at Cambridge to find out for sure. Dave |
Hi Dave,
Your 303 can indicate when you fly into a cylinder, but not when you fly into a "photo sector". Paul Remde wrote in message ups.com... On Jul 19, 11:01 am, wrote: I understand the characteristics of the Sector OZ and the Cylinder OZ, and for my badge flights, I would prefer to use the Sector OZ. An RAS thread back in 2000 (before I started flying) seems to indicate that Cambridge FRs are "hard wired" to the Cylinder OZ. I have a 302A CFR. Does that mean I'm stuck with Cylinder OZ's, or can you "declare" intent to use Sector OZs in some way when making badge flights? TIA Jim My 302/303 will indicate sector entry when a task is active. I believe it's a feature of the 303 only, but can't be sure. Although based on the documentation for the 303, it is not compatible with the 302A. So you might be out of luck. You could contact the folks at Cambridge to find out for sure. Dave |
From the 303 Manual:
If a Task is active, the 303-NAV gives an additional message when the glider enters the FAI Photo Sector for the Active Task Turnpoint. Three loud, short beeps are accompanied by the message “In Sector” on the 303 HOME screen. The “In Sector” message takes priority over both the “Approaching” and “Arrival!” messages. The outer boundary of the DDV “FAI Sector” is at the “Approaching” radius. So it will give you messages for both "beer can" and "photo sector", and you don't even have to choose ahead of time which you like! Paul Remde wrote: Hi Dave, Your 303 can indicate when you fly into a cylinder, but not when you fly into a "photo sector". Paul Remde wrote in message ups.com... On Jul 19, 11:01 am, wrote: I understand the characteristics of the Sector OZ and the Cylinder OZ, and for my badge flights, I would prefer to use the Sector OZ. An RAS thread back in 2000 (before I started flying) seems to indicate that Cambridge FRs are "hard wired" to the Cylinder OZ. I have a 302A CFR. Does that mean I'm stuck with Cylinder OZ's, or can you "declare" intent to use Sector OZs in some way when making badge flights? TIA Jim My 302/303 will indicate sector entry when a task is active. I believe it's a feature of the 303 only, but can't be sure. Although based on the documentation for the 303, it is not compatible with the 302A. So you might be out of luck. You could contact the folks at Cambridge to find out for sure. Dave |
On Jul 19, 8:38 pm, "Paul Remde" wrote:
Hi Dave, Your 303 can indicate when you fly into a cylinder, but not when you fly into a "photo sector". Paul Remde wrote in message ups.com... On Jul 19, 11:01 am, wrote: I understand the characteristics of the Sector OZ and the Cylinder OZ, and for my badge flights, I would prefer to use the Sector OZ. An RAS thread back in 2000 (before I started flying) seems to indicate that Cambridge FRs are "hard wired" to the Cylinder OZ. I have a 302A CFR. Does that mean I'm stuck with Cylinder OZ's, or can you "declare" intent to use Sector OZs in some way when making badge flights? TIA Jim My 302/303 will indicate sector entry when a task is active. I believe it's a feature of the 303 only, but can't be sure. Although based on the documentation for the 303, it is not compatible with the 302A. So you might be out of luck. You could contact the folks at Cambridge to find out for sure. Dave- Hide quoted text - - Show quoted text - Paul, See ZL's post a few messages up. The 303 gives a message when entering the FAI photo sector when a task is active. |
On Jul 19, 10:01 am, wrote:
Cambridge FRs are "hard wired" to the Cylinder OZ. I have a 302A CFR. Does that mean I'm stuck with Cylinder OZ's, or can you "declare" intent to use Sector OZs in some way when making badge flights? There is no need to declare the type of OZ to use. Just be sure that all your TP approaches are of the same type. Are you using a PDA to navigate from the data stream provided by the 302A? Then the PDA map will get you to the right place. I don't recall whether the 302 can be set up to beep when within a predefined distance to the TP (I have a 302, but use the PDA to navigate, so never bothered to see if that was possible). If it can, then you could use it to fly a cylinder OZ type task. If you want to fly a sector OZ type task, then you must have at least a display that provides bearing to the TP that will help you get to the right place. If you have no display, then your TPs had better be easily identifiable places, and you must be very sure you are in the OZ before changing course. If you are using a different source of GPS info, perhaps a handheld, to navigate, then you must again be sure not to barely clip the OZ, as the two GPS devices could be off by a few hundred feet. So even though the handheld unit claims you were barely within the OZ, the IGC FR may still be showing a position outside the OZ. -Tom |
LHR Sector for Tracon for Windows | peteduggan35 | Simulators | 0 | February 3rd 06 10:49 AM |
Badges ? ... We don't need no stinkin' badges | Doug Snyder | Soaring | 36 | September 21st 05 08:26 AM |
"First private-sector spaceship rockets into history" | Mike | Military Aviation | 7 | June 24th 04 02:47 AM |
"First private-sector spaceship rockets into history" | Mike | General Aviation | 0 | June 22nd 04 04:37 PM |
Cambridge GPSNAV20 photo-sector display | Pat Russell | Soaring | 2 | July 9th 03 11:49 PM |
