#91
On Fri, 20 Jul 2007 18:28:14 -0400, "Roger (K8RI)"
wrote: On Thu, 19 Jul 2007 10:04:46 -0600, RomeoMike wrote: Jay Honeck wrote: "Overall (farming, distillation), it takes 129,600 BTU to produce a gallon of EtOH (ethanol), but the energy value of a gallon of EtOH is only 76,000 BTU. In SI units [conversions in footnote 3]: it takes 45.7 MJ to produce a kilogram of EtOH, but the energy value of that kilogram of EtOH is 26.8 MJ." Does anyone know how much energy it takes to pump crude out of the ground, ship it to a refinery, and the refine it to make a gallon of gas? I don't, just asking for a comparison. It's surprisingly inefficient, but using the same stuff for power makes it relatively inexpensive. I looked it up a while back and as I recall it was "cost of producing alcohol compared to processing crude oil into gas" The biggest problem I found is there is so much conflicting information out there that it takes time (a lot of it) to filter out what is and is not both correct and up-to-date. Even where studies are undertaken you really need to know the criteria under which the studies were conducted. *Probably* one of the least expensive fuels is hydrogen produced by gasification of coal, but that process is not clean and produces a tremendous amount of CO2 as a byproduct. OTOH the byproducts and be recovered and sold while the CO2 can be sequestered. Interesting data point: "ChevronTexaco has installed a solar photovoltaic facility called Soalrmine to help power oil-field operations near Bakersfield, Calif. The grid-tie project comprises 4800 flexible, current-producing solar panels, each about 1.3 feet wide by 18 feet long, mounted on metal frames. "At 500 kW, Solarrmine is one of the largest photovoltaic installations in the U.S. and the largest array of flexible, amorphous-silicon solar technology in the world. Solarmine covers six acres, enabling it to take advantage of Uni-Solar's amorphous-manufacturing economies of scale. (ChevronTexaco owns 20% of Uni-Solar's parent company, ECD.) " That's from an article I wrote in 2004. I don't know the current status. Don |
#92
On Fri, 20 Jul 2007 17:11:54 -0700, Don Tuite
wrote: On Fri, 20 Jul 2007 18:28:14 -0400, "Roger (K8RI)" wrote: On Thu, 19 Jul 2007 10:04:46 -0600, RomeoMike wrote: Jay Honeck wrote: "Overall (farming, distillation), it takes 129,600 BTU to produce a gallon of EtOH (ethanol), but the energy value of a gallon of EtOH is only 76,000 BTU. In SI units [conversions in footnote 3]: it takes 45.7 MJ to produce a kilogram of EtOH, but the energy value of that kilogram of EtOH is 26.8 MJ." Does anyone know how much energy it takes to pump crude out of the ground, ship it to a refinery, and the refine it to make a gallon of gas? I don't, just asking for a comparison. It's surprisingly inefficient, but using the same stuff for power makes it relatively inexpensive. I looked it up a while back and as I recall it was "cost of producing alcohol compared to processing crude oil into gas" The biggest problem I found is there is so much conflicting information out there that it takes time (a lot of it) to filter out what is and is not both correct and up-to-date. Even where studies are undertaken you really need to know the criteria under which the studies were conducted. *Probably* one of the least expensive fuels is hydrogen produced by gasification of coal, but that process is not clean and produces a tremendous amount of CO2 as a byproduct. OTOH the byproducts and be recovered and sold while the CO2 can be sequestered. Interesting data point: "ChevronTexaco has installed a solar photovoltaic facility called Soalrmine to help power oil-field operations near Bakersfield, Calif. The grid-tie project comprises 4800 flexible, current-producing solar panels, each about 1.3 feet wide by 18 feet long, mounted on metal frames. "At 500 kW, Solarrmine is one of the largest photovoltaic installations in the U.S. and the largest array of flexible, amorphous-silicon solar technology in the world. Solarmine covers six Amorphous-Silicon in what configuration? Deposition on a substrate or polycrystalline? Hemlock Semiconductor Corporation (HSC), affectionately known around here as Hemi Semi...just finished up a major expansion program (they were the world's largest producer of polycrystalline Silicon well before that expansion) announced a one Billion Dollar expansion that should again double the plant's capacity. The problem for us using solar (active and passive) up here, contrary to many claims made by the state and tourist bureau, is lack of sun coupled low cost electricity. With electricity costing about 8 cents per KWH or 10 cents with all surcharges, being 43.37N, in a cloudy area, and no subsidy we aren't even on the pay-back charts. California OTOH with peak charges of just shy of 40 cents per KWH and a subsidy of near 50% last I heard, has a reasonable payback time. Up here an installation would run about twice the cost of one in California and we receive no subsidy. That makes the $30,000 to $50,000 for an installation just a tad steep. acres, enabling it to take advantage of Uni-Solar's amorphous-manufacturing economies of scale. (ChevronTexaco owns 20% of Uni-Solar's parent company, ECD.) " That's from an article I wrote in 2004. I don't know the current status. Don |
#93
Current prices of $3.20 per bu. are relatively high but not at historic
highs, in fact corn has lost about $1 per bushel in the last 2 weeks. In 1996 when the average yearly price for the US hit $3.55, we sold corn as high as $4.90 and some neighbors got over $5.00. Inflationary periods are evident from the charts... 1983 and 1984 avg prices were at or above $3.00 and I'm not sure, but I think the 1974 average price of $2.92 was when the US made a trade deal with China. It's interesting to compare the % increases of milk to corn over the last 40 years. http://www.farmdoc.uiuc.edu/manage/u...ry/USPrice.asp Jim "Roger (K8RI)" wrote in message ... On Fri, 20 Jul 2007 15:14:06 -0700, C J Campbell wrote: On 2007-07-19 08:31:40 -0700, Jay Honeck said: As gas -- and corn -- prices creep ever higher, everyone in my great State of Iowa is all ablush with talk of riches pouring in, thanks to ethanol production. They can barely contain their glee at this remarkable turn of economic fortune. (Remember, just a few years ago farmers here had one foot in the grave, and the other on a banana peel...) There have already been riots in Mexico because of the corn shortage. But you will have about as much luck fighting "Big Corn" as you did "Big Oil." What a revelation:-)) The game's the same, only the faces change. |
#94
On Fri, 20 Jul 2007 00:14:08 -0500, "Maxwell" wrote:
"Whata Fool" wrote in message .. . Regardless, ethanol production is needed, and the more the better. What do you consider to be the "pros" of ethanol? For the US, it reduces oil imports, billions of gallons per year. It will provide the means to do away with farm subsidies, if only congress has the brains to make it happen. It is much cleaner burning, and with the engine tuned for it, it has more power, check Indy 500 for details. It is carbon neutral, as is all animal and human emissions of CO2. The Indy use alcohol because of gasoline fire, but check that out too. When oil becomes too expensive and in short supply, ethanol is one of the biofuels that is easy to make. There is nothing bad about ethanol, although because it has an oxygen atom in the molecule, it needs less air, so a bigger tank may be needed for the same miles per tank. (Miles Per Gallon is not a criteria for different fuels, Miles Per Dollar is the important factor). |
#95
On Fri, 20 Jul 2007 07:11:50 -0500, "Dan Luke"
wrote: The theory of anthropogenic climate change has reached a stage where it is generally accepted among the world scientific community as valid. You were careful not to say "global warming", weren't you ding dong? Research continues over many points still in contention, such as feedback influences. As if all the cooling processes of water vapor could be categorized by one or more parameters of "feedback". That does not mean that there is any considerable doubt in the scientific community that ACC is real. Maybe about the same as doubt in cold fusion? Those wishing to "shoot the messenger" often resort to cherry picking facts from the various mini-controversies within the overall research to cast doubt on the theory itself. There is an obvious, very large, factor due to clouds that has never been mentioned, who will be the first to think of what it is? |
#96
C J Campbell wrote:
There have already been riots in Mexico because of the corn shortage. But you will have about as much luck fighting "Big Corn" as you did "Big Oil." It may be worth noting that corn growers are getting NO federal crop subsidies, since the price is currently high. Not as high as it's been in adjusted dollars in the past, but high enough that the capitalist system responded in admirable fashion, inspiring growers to announce plans to plant a record number of acres in corn. Guess Mexican farmers would be free to do that too, wouldn't they? |
#97
On Fri, 20 Jul 2007 19:32:47 -0400, "Roger (K8RI)"
wrote: On Fri, 20 Jul 2007 17:12:30 -0900, Whata Fool wrote: On Fri, 20 Jul 2007 00:14:08 -0500, "Maxwell" wrote: "Whata Fool" wrote in message ... Regardless, ethanol production is needed, and the more the better. What do you consider to be the "pros" of ethanol? For the US, it reduces oil imports, billions of gallons per year. First, when compared to gas none of my statements are negative against alcohol. There is nothing wrong with ethanol, it is a great opportunity for farmers and small business. It might, not does and even pushing the implementation to the limits predictions are it will only be able to take care of the increased demand for fuels over time. It will provide the means to do away with farm subsidies, if only congress has the brains to make it happen. It might It is much cleaner burning, and with the engine tuned for it, it has more power, check Indy 500 for details. Cleaner burning, yes. More power, not a chance. Alcohol only contains 60 of the energy of gas. In Indy they get more power by burning more. Not true, they may not get the miles per gallon, but during the race I heard something about _smaller_ tanks. Ethanol has more like 80 percent the energy of gasoline, but cars on the road are detuned to use low octane unleaded. A lot more and under more pressure. They are also running very expensive engines at very high RPM and expected to last for one race. I don't think superchargers are allowed, and all cars use the same engine. Again, it is not the miles per gallon, or how much energy per gallon, the important thing is more miles per dollar. It is carbon neutral, as is all animal and human emissions of CO2. It could be if the growing chain also used it rather than fossil fuels. The only reason to use fossil fuels is the availability, most farm machinery is diesel. The Indy use alcohol because of gasoline fire, but check that out too. When oil becomes too expensive and in short supply, ethanol is one of the biofuels that is easy to make. And expensive although the price is currently hidden in subsidies rather than showing up at the pump. Ethanol made from sugar or other crops should be cheaper than gasoline, and it must be, that is why there is an import tax. There is nothing bad about ethanol, although because it has an oxygen atom in the molecule, it needs less air, so a bigger tank may be needed for the same miles per tank. (Miles Per Gallon is not a criteria for different fuels, Miles Per Dollar is the important factor). Time we get done alcohol will be at least as expensive as the highest price we've seen for gas so far. It will get cheaper relatively as time passes, ethanol can be made out of almost any hydrocarbon (organic). |
#98
On Fri, 20 Jul 2007 10:37:41 -0500, "Dan Luke"
wrote: Indeed not. I have spent a good deal of time examining such objections, and have not found any that are destructive to the case made in IPCC 4AR. The fact that the CO2 PPMV does not coincide with the known production added is a clue that the case is not closed. The fact that CO2 exists in such a small proportion to the real greenhouse gas water vapor is a big clue. The fact that the mass of all the CO2 in the atmosphere is not enough to capture the amount of thermal energy involved is a bigger clue. The fact that evaporation cools many times more than any possible IR radiation from the atmosphere. The fact that clouds block incoming radiation causes any energy budget accounting to be inadequate for the task. And the fact that some near all time record lows for the month of July are occurring suggests there is a move toward a cooling trend. |
#99
Stella Starr wrote: It may be worth noting that corn growers are getting NO federal crop subsidies, since the price is currently high. Not as high as it's been in adjusted dollars in the past, but high enough that the capitalist system responded in admirable fashion, inspiring growers to announce plans to plant a record number of acres in corn. Yes, but just for information, what would have been the "admirable capitalist response" of all parties involved -- here in the U.S., I mean -- if the price had instead gone way down? [This is a question . . ] |
#100
![]() "Bertie the Bunyip" wrote: Just in case you didn't know, Graham is a known net-kook. I didn't, but it was becoming obvious. -- Dan "Almost all the matter that came out of the Big Bang was two specific sorts; hydrogen and stupidity." -Robert Carnegie in talk.origins |
buy your sailplane scam? | [email protected] | Soaring | 23 | December 13th 05 06:13 PM |
SCAM | [email protected] | Soaring | 0 | August 26th 05 12:26 AM |
web scam ? | Chip Fitzpatrick | Soaring | 0 | August 10th 04 11:54 AM |
Scam Y/N ? | Stuart King | Instrument Flight Rules | 6 | November 13th 03 10:52 PM |
