On Jul 22, 11:47 am, Danny Deger wrote:
On Jul 22, 11:10 am, wrote: snip I won't say that it was wrong of your flight lead to fly an aggressive final turn. Good pilots can get away with that. I won't say that it was wrong of you to follow your lead through that turn. A good wingman can get away with that too. My suggestion to you was to rethink your view that your flight lead was wrong. That your flight lead tried to kill you. Where in the heck did I say he wanted to kill me? Please don't put words in my mouth. I only said he wanted to embarrass me by flying a turn tighter than I could. He did not know, and I did not know the consequences of flying into his jet wash. If I had known, I certainly would not have. If he had known, he certainly would not have flown such a tight turn that I had to follow. Here is the section of my book in question. I clearly say I think lead may have been trying to embarass me. There is no mention of him attempting to kill me. The normal way to land is what is called the overhead break. The number 2 plane is put on the side opposite of the break and the formation flies down the runway at about 1,500 feet altitude. As the formation passes over the runway lead breaks and number 2 stays level for a few seconds. After the delay, number 2 breaks. One of the rules was number 2 can not fly a pattern further from the runway than lead. One day this almost killed me. Lead did a very aggressive break. By this I mean he makes a small/tight turn. I followed. If you are too close to the runway, you can't make the turn and you overshoot. I knew I was closer than I ever had been in my life, and I was going to have to make a maximum performance turn to final. At the proper time, I started a turn at the optimum Angle Of Attack, AOA. The F-4 had an audio feed back on AOA and had a nice solid tone in the head set when on the optimum AOA. I was inside lead's turn to start off with, so I am out of his wake turbulence. But, I must go right into the center of his wake turbulence to line up on the runway. Wake turbulence is like small horizontal tornadoes that can cause huge roll rates if you get into one. Normally, a fighter can fly into another fighter's wake turbulence without any big problems. But lead was doing a more aggressive turn than usual which made his wake stronger. Then I was at a higher than normal angle of attack with decreased my aileron effectiveness. The end result was when I hit his wake turbulence, I rolled instantly about 120 degrees to the left. I knew I was in big trouble. Fortunately my training and instincts kicked in. At a high angle of attack, the F-4 does not roll well. I needed to get the AOA down. To do this I pushed the stick full forward until it hit its stop. At the same time I gave the plane full right rudder. About the time my controls become effective, I left my lead's wake turbulence and rolled quickly back to the right. I overshot the roll a lot and ended up in about 90 degrees of roll to the right. The AOA was down by now, so the ailerons start to work. With left aileron and left rudder I brought the plane back to level flight and actually made a good landing without having to go around. The roll excursions lasted a second or two at the most and I was still on glide slope and on the centerline of the runway. My WSO told me after landing he was reaching for the ejection handle as I was fighting for control. Before he could pull the handle, I had the plane back under control. I am glad he didn't have time. At our altitude and roll angles, we probably would not have had time for the chutes could open before we hit the ground. What was strange for me at the time was the lack of interest in what happened. We were well trained to avoid the wake of heavy airplanes, but the general thought was the wake turbulence of another F-4 was not dangerous. I asked that the Tactical Air Command safety organization be brought in to get the word out that if the pattern is flown too aggressively, lead's wake turbulence could be deadly. My request was denied. I requested the topic be brought up at the next wing safety briefing. Again my request was denied. I didn't at the time understand why loosing control in the traffic pattern would not be of interest to the F-4 safety community. Now I think I know why. Leads are not supposed to fly such a tight pattern. He was very likely attempting to embarrass me by flying a pattern tighter than he thought I could. Even if his overly aggressive pattern was not meant to embarrass me, he was at fault for the near miss. It wasn't my favorite lead, John "Lips" Fraley, but it was a respected flight lead of the squadron. If you are part of the in crowd, you can screw up and not be called on the mistake. If you are not in the in crowd, every tiny issue is blown out of proportion and used to further damage your reputation. Being in a fighter squadron was just like being back in junior high. Danny Deger |
Houston Hobby? | dlevy | Piloting | 16 | April 28th 06 06:46 PM |
GA in Houston | [email protected] | Piloting | 40 | April 1st 05 03:12 PM |
Houston Instructor? | John Westerlage | Aerobatics | 2 | March 1st 05 03:12 AM |
Houston crashes | Big John | Piloting | 0 | December 11th 03 04:27 PM |
