VOR approach SMO
Old July 23rd 07, 10:28 PM posted to rec.aviation.piloting,rec.aviation.ifr
karl gruber[_1_]
Default VOR approach SMO
You can cross CULVE at 680 because the chart says "CULVE DME/RADAR MINIMA*
680-1"
You can descend to 680 past BEVEY. Look at the chart...........that's how
it's read.
Karl
"Doug Semler" wrote in message
ps.com...
On Jul 23, 5:07 pm, "pgbnh" wrote:
I think all but one of the posters have missed the fact that the MDA is
not
1120 but 680. If indeed the vis was 3 miles, then the runway should have
been in sight from the MDA of 680 feet about a mile OUTSIDE of Culve.
(Remember what you can do once you have the runway in sight????) At
which
point it's not a particularly big deal to lose 500 feet to land on the
numbers. Maybe even crossing Culve at 3-400 feet agl
Please, tell me how you read the plate in a way that you can cross
CULVE below 1120 when you don't have the airport in sight?
Note I am not an IA pilot, but I really want to understand this. My
reading of the plate is:
Cross CULVE at or above 1120. If you are DME equipped and radar, you
can then descend to 680. Otherwise you gotta remain at 1120. If you
get to the VOR before seeing the airport, you execute missed.
Now if the conditions are 800 overcast 3mi, how can you see the
airport before hitting CULVE unless you are below the crossing
restriction?
Old July 23rd 07, 10:34 PM posted to rec.aviation.piloting,rec.aviation.ifr
Doug Semler
680-1"
it's read.
So, iff you have DME and RADAR, the _1120_ in profile view changes to
_680_, right?
That is a *bit* confusing.
Old July 23rd 07, 10:43 PM posted to rec.aviation.piloting,rec.aviation.ifr
karl gruber[_1_]
Correct. That's why there's a little * next to the 1120*.
Karl
MINIMA*
680-1"
it's read.
_680_, right?
Old July 24th 07, 12:04 AM posted to rec.aviation.piloting,rec.aviation.ifr
B
And, that little "*" (black ball number 1 on Jepp chart) means you can
descend to 680 ONCE PASSING CULVE.
Karl
MINIMA*
680-1"
it's read.
_680_, right?
Old July 24th 07, 12:33 AM posted to rec.aviation.piloting,rec.aviation.ifr
Doug Semler
Unless they changed the rules of footnoting on me, the only thing the
little * next to 1120 tells me is that DME is required when the tower
is closed. Presumably to identify CULVE.
Old July 24th 07, 12:43 AM posted to rec.aviation.piloting,rec.aviation.ifr
B
Correct, but the note is a bit ambiguous. DME is not required when the
tower is closed unless you want to identify CULVE and use the lower MDA.
Old July 24th 07, 12:49 AM posted to rec.aviation.piloting,rec.aviation.ifr
Doug Semler
You know, I kinda figured this; otherwise it would have been a VOR/DME
appch, right?
VOR approach SMO Robert M. Gary Piloting 124 August 3rd 07 02:17 AM
first approach in IMC G. Sylvester Instrument Flight Rules 10 July 12th 05 02:14 AM
No FAF on an ILS approach...? John Harper Instrument Flight Rules 7 December 24th 03 03:54 AM
Completing the Non-precision approach as a Visual Approach John Clonts Instrument Flight Rules 45 November 20th 03 05:20 AM
Brief an approach Ditch Instrument Flight Rules 11 October 14th 03 12:10 AM
