"karl gruber" wrote: No. You can be 6.7 miles out at 680/DME. Maybe I'm just thick, but that's not how I read the chart. After DARTS, you can descend to 2600. After BEVEY, you can descend to 1120. What happens after that depends on whether you can identify CULVE or not. If you can identify CULVE, once you reach it, you can descend to 680. Without CULVE, you have to stay at 1120 until you have the runway in sight. Look at the plan view. There's a 863 tower at what looks like about 1/2 mile right of the FAC. I'm sure that's the controlling terrain for the 1120 MDA between BEVEY and CULVE. To identify CULVE, you need one of two things: either DME in the aircraft, or the tower has to be open AND you have to be in radar contact. It doesn't explicitly say so on the chart, but I assume the tower has a BRITE scope in the cab with CULVE marked on it and will call it for you on tower frequency. CULVE is 1.6 nm from the threshold. If you cross it at 1120, you're 945 feet AGL (referenced to the runway surface). So, to hit the numbers, you need to keep a 590 ft/nm descent gradient from CULVE to the runway. Looking at it another way, at 90 kts and no wind, you need an 885 ft/min descent rate. That's fast, but not outrageously so. It's about twice as steep as an ILS. It's certainly the kind of approach you need to brief ahead of time and know what you're going to need to do before you get there. |
Roy Smith wrote:
You're not thick, the Curator is. In article , "karl gruber" wrote: No. You can be 6.7 miles out at 680/DME. Maybe I'm just thick, but that's not how I read the chart. After DARTS, you can descend to 2600. After BEVEY, you can descend to 1120. What happens after that depends on whether you can identify CULVE or not. If you can identify CULVE, once you reach it, you can descend to 680. Without CULVE, you have to stay at 1120 until you have the runway in sight. Look at the plan view. There's a 863 tower at what looks like about 1/2 mile right of the FAC. I'm sure that's the controlling terrain for the 1120 MDA between BEVEY and CULVE. Actually, it is several very tall building in Century City. At 680 feet out there you die. To identify CULVE, you need one of two things: either DME in the aircraft, or the tower has to be open AND you have to be in radar contact. It doesn't explicitly say so on the chart, but I assume the tower has a BRITE scope in the cab with CULVE marked on it and will call it for you on tower frequency. CULVE is 1.6 nm from the threshold. If you cross it at 1120, you're 945 feet AGL (referenced to the runway surface). So, to hit the numbers, you need to keep a 590 ft/nm descent gradient from CULVE to the runway. Looking at it another way, at 90 kts and no wind, you need an 885 ft/min descent rate. That's fast, but not outrageously so. It's about twice as steep as an ILS. It's certainly the kind of approach you need to brief ahead of time and know what you're going to need to do before you get there. |
Roy Smith wrote: In article , "karl gruber" wrote: No. You can be 6.7 miles out at 680/DME. Maybe I'm just thick, but that's not how I read the chart. After DARTS, you can descend to 2600. After BEVEY, you can descend to 1120. What happens after that depends on whether you can identify CULVE or not. If you can identify CULVE, once you reach it, you can descend to 680. Without CULVE, you have to stay at 1120 until you have the runway in sight. That's my understanding as well -- the chart isn't particularly ambiguous on this, either... Look at the plan view. There's a 863 tower at what looks like about 1/2 mile right of the FAC. I'm sure that's the controlling terrain for the 1120 MDA between BEVEY and CULVE. Indeed. Having briefly worked in the building that that obstruction represents, I hope there aren't too many pilots out there in IMC dropping below 1120 before they're at least abeam that point... Hamish |
In article
, Hamish Reid wrote: Indeed. Having briefly worked in the building that that obstruction represents, I hope there aren't too many pilots out there in IMC dropping below 1120 before they're at least abeam that point... There's nothing that makes you appreciate the importance of the MDA like being part of the terrain :-) |
On Jul 23, 3:15 pm, Roy Smith wrote:
In article , CULVE is 1.6 nm from the threshold. If you cross it at 1120, you're 945 feet AGL (referenced to the runway surface). So, to hit the numbers, you need to keep a 590 ft/nm descent gradient from CULVE to the runway. Looking at it another way, at 90 kts and no wind, you need an 885 ft/min descent rate. That's fast, but not outrageously so. It's about twice as steep as an ILS. Maybe easy in a 172 but not in my Mooney. With gear and flaps out and power at idle I don't think I can do 885 ft/min without a lot of slipping. Even if I could there is still the issue of going from 90 knots approach speed down to 70 knots threshold crossing speed. This is why I was 3/4 down the runway. I'm still wondering how the GulfStream did that. -Robert |
In article . com,
"Robert M. Gary" wrote: On Jul 23, 3:15 pm, Roy Smith wrote: In article , CULVE is 1.6 nm from the threshold. If you cross it at 1120, you're 945 feet AGL (referenced to the runway surface). So, to hit the numbers, you need to keep a 590 ft/nm descent gradient from CULVE to the runway. Looking at it another way, at 90 kts and no wind, you need an 885 ft/min descent rate. That's fast, but not outrageously so. It's about twice as steep as an ILS. Maybe easy in a 172 but not in my Mooney. With gear and flaps out and power at idle I don't think I can do 885 ft/min without a lot of slipping. Even if I could there is still the issue of going from 90 knots approach speed down to 70 knots threshold crossing speed. This is why I was 3/4 down the runway. I'm still wondering how the GulfStream did that. I've never flown a Mooney, so I can't speak for what it can or can't do. The charted procedure only promises that if you fly the specified course and altitudes, it'll keep you from hitting any terrain. There's nothing that promises that any particular aircraft has the required performance to land straight-in (or any other way, for that matter) out of any particular approach. Figuring that stuff out is all part of pre-flight planning. |
On Mon, 23 Jul 2007 21:22:27 -0400, Roy Smith wrote:
In article . com, "Robert M. Gary" wrote: On Jul 23, 3:15 pm, Roy Smith wrote: In article , CULVE is 1.6 nm from the threshold. If you cross it at 1120, you're 945 feet AGL (referenced to the runway surface). So, to hit the numbers, you need to keep a 590 ft/nm descent gradient from CULVE to the runway. Looking at it another way, at 90 kts and no wind, you need an 885 ft/min descent rate. That's fast, but not outrageously so. It's about twice as steep as an ILS. Maybe easy in a 172 but not in my Mooney. With gear and flaps out and power at idle I don't think I can do 885 ft/min without a lot of slipping. Even if I could there is still the issue of going from 90 knots approach speed down to 70 knots threshold crossing speed. This is why I was 3/4 down the runway. I'm still wondering how the GulfStream did that. I've never flown a Mooney, so I can't speak for what it can or can't do. The charted procedure only promises that if you fly the specified course and altitudes, it'll keep you from hitting any terrain. There's nothing that promises that any particular aircraft has the required performance to land straight-in (or any other way, for that matter) out of any particular approach. Figuring that stuff out is all part of pre-flight planning. Come on guys, this IS a circling approach. If you feel stuffed in, you can always circle southeast, remain within 1 1/4 miles of the approach end of 21, and descend when appropriate for the pavement. |
On Jul 23, 6:22 pm, Roy Smith wrote:
In article . com, "Robert M. Gary" wrote: On Jul 23, 3:15 pm, Roy Smith wrote: In article , CULVE is 1.6 nm from the threshold. If you cross it at 1120, you're 945 feet AGL (referenced to the runway surface). So, to hit the numbers, you need to keep a 590 ft/nm descent gradient from CULVE to the runway. Looking at it another way, at 90 kts and no wind, you need an 885 ft/min descent rate. That's fast, but not outrageously so. It's about twice as steep as an ILS. Maybe easy in a 172 but not in my Mooney. With gear and flaps out and power at idle I don't think I can do 885 ft/min without a lot of slipping. Even if I could there is still the issue of going from 90 knots approach speed down to 70 knots threshold crossing speed. This is why I was 3/4 down the runway. I'm still wondering how the GulfStream did that. I've never flown a Mooney, so I can't speak for what it can or can't do. The charted procedure only promises that if you fly the specified course and altitudes, it'll keep you from hitting any terrain. There's nothing that promises that any particular aircraft has the required performance to land straight-in (or any other way, for that matter) out of any particular approach. Figuring that stuff out is all part of pre-flight planning. What is your point? That the GulfStream shouldn't have been able to touch down on the numbers or should have? You've lost me. -Robert |
In article . com,
"Robert M. Gary" wrote: On Jul 23, 6:22 pm, Roy Smith wrote: In article . com, "Robert M. Gary" wrote: On Jul 23, 3:15 pm, Roy Smith wrote: In article , CULVE is 1.6 nm from the threshold. If you cross it at 1120, you're 945 feet AGL (referenced to the runway surface). So, to hit the numbers, you need to keep a 590 ft/nm descent gradient from CULVE to the runway. Looking at it another way, at 90 kts and no wind, you need an 885 ft/min descent rate. That's fast, but not outrageously so. It's about twice as steep as an ILS. Maybe easy in a 172 but not in my Mooney. With gear and flaps out and power at idle I don't think I can do 885 ft/min without a lot of slipping. Even if I could there is still the issue of going from 90 knots approach speed down to 70 knots threshold crossing speed. This is why I was 3/4 down the runway. I'm still wondering how the GulfStream did that. I've never flown a Mooney, so I can't speak for what it can or can't do. The charted procedure only promises that if you fly the specified course and altitudes, it'll keep you from hitting any terrain. There's nothing that promises that any particular aircraft has the required performance to land straight-in (or any other way, for that matter) out of any particular approach. Figuring that stuff out is all part of pre-flight planning. What is your point? That the GulfStream shouldn't have been able to touch down on the numbers or should have? You've lost me. -Robert My point is that people should do pre-flight planning and not wait until three quarters of the the runway is behind them to start thinking about whether they can land on what's left. |
On Jul 23, 7:23 pm, Roy Smith wrote:
In article . com, My point is that people should do pre-flight planning and not wait until three quarters of the the runway is behind them to start thinking about whether they can land on what's left.- Hide quoted text - No, ****, but what are you refering to? Who was "start thinking about whether they can land on what's left"? Is that a reference to this thread or a different thread? I don't recall anyone being concerned that the runway was too short or that they couldn't land in the available runway. This thread concerns an IFR approach and the question of being able to hit the numbers from 1120 under 2 miles out. Maybe its a newsreader issue??? -Robert |
VOR approach SMO | Robert M. Gary | Piloting | 124 | August 3rd 07 02:17 AM |
first approach in IMC | G. Sylvester | Instrument Flight Rules | 10 | July 12th 05 02:14 AM |
No FAF on an ILS approach...? | John Harper | Instrument Flight Rules | 7 | December 24th 03 03:54 AM |
Completing the Non-precision approach as a Visual Approach | John Clonts | Instrument Flight Rules | 45 | November 20th 03 05:20 AM |
Brief an approach | Ditch | Instrument Flight Rules | 11 | October 14th 03 12:10 AM |
