VOR approach SMO
Old July 24th 07, 01:31 AM posted to rec.aviation.piloting,rec.aviation.ifr
Robert M. Gary
Default VOR approach SMO
On Jul 23, 4:08 pm, B wrote:
Right, dive to 1120 and drive to CULVE, then dive to 680.
So, the question is still, how does the GulfStream get from CULVE at
1120 down to 0 at the numbers. I was in IMC with gear and flaps down,
power at idle and in a slip and I was still about 3/4 down when I
touched. Does a GulfStream drop faster than a Mooney?
-Robert
Old July 24th 07, 01:41 AM posted to rec.aviation.piloting,rec.aviation.ifr
Doug Semler
I wouldn't be surprised...doesn't NASA use Gulfstreams albiet
modified) to train Shuttle pilots to be able to land the "flying
brick?" g
Old July 24th 07, 02:03 AM posted to rec.aviation.piloting,rec.aviation.ifr
Robert M. Gary
brick?" g
Yea, with thrust reverses in the descent!
-Robert
Old July 24th 07, 02:07 AM posted to rec.aviation.piloting,rec.aviation.ifr
Doug Semler
brick?" g
There's your answer... Guy behind you is a former shuttle pilot big
grin
Old July 24th 07, 02:47 AM posted to rec.aviation.piloting,rec.aviation.ifr
John R. Copeland
"Robert M. Gary" wrote in message ups.com...
-Robert
Reminds me of a story told me by a friend in school for his King Air.
A classmate asked if he could reverse the prop pitch in flight.
The instructor replied: "Yes, you can.
And if you do, you will fall out of the sky like a typewriter."
Old July 24th 07, 04:59 PM posted to rec.aviation.piloting,rec.aviation.ifr
Doug Semler
FWIW, my quick and dirty math shows ~5.5 degree slope from CULVE to
threshold @ 1120. If you keep that slope, you would have broken
through the clouds about 6500 ft from the threshold at 800 (625 agl).
The Gulf's approach speed is something like 120 or 130. Calling it
130, that's a 1300-1400fpm descent rate at that slope. If the gulf
can do that, then they could keep a nice steady path to the threshold
@ 5.5 degrees.
Now if you dive at a 6.5 degree slope at CULVE, you are decreasing
your final angle to 5 degrees while extending your distance to
threshold another 500 ft when breaking out.
Of course, this all assumes that you are actually at 1120 when at
culve g
Old July 24th 07, 06:59 PM posted to rec.aviation.piloting,rec.aviation.ifr
Robert M. Gary
@ 5.5 degrees.
culve g
And that your approach speed and threshold crossing speed are the same
(i,e. that you don't need additional room to slow down).
Old July 25th 07, 03:25 AM posted to rec.aviation.piloting,rec.aviation.ifr
Doug Semler
@ 5.5 degrees.
culve g
Yes, I told you it was quick and dirty (I did it pretty much in my
head. there's *alot* of rounding in there g)
I did a search and can't find any performance characteristics of a
gulf on the web, except an accident report stating the probable cause
of an accident as the pilot's putting the plane in an unstabilized
2500fpm descent profile :-/
Old July 30th 07, 06:38 PM posted to rec.aviation.piloting,rec.aviation.ifr
Dave Butler
There's no reason they can't be the same, e.g. 70 knots, if that's what
you need to make the descent angle.
DB
VOR approach SMO Robert M. Gary Piloting 124 August 3rd 07 02:17 AM
first approach in IMC G. Sylvester Instrument Flight Rules 10 July 12th 05 02:14 AM
No FAF on an ILS approach...? John Harper Instrument Flight Rules 7 December 24th 03 03:54 AM
Completing the Non-precision approach as a Visual Approach John Clonts Instrument Flight Rules 45 November 20th 03 05:20 AM
Brief an approach Ditch Instrument Flight Rules 11 October 14th 03 12:10 AM
