VOR approach SMO
Old July 25th 07, 03:25 AM posted to rec.aviation.piloting,rec.aviation.ifr
Doug Semler
Default VOR approach SMO
On Jul 24, 1:59 pm, "Robert M. Gary" wrote:
On Jul 24, 8:59 am, Doug Semler wrote:
On Jul 23, 8:31 pm, "Robert M. Gary" wrote:
On Jul 23, 4:08 pm, B wrote:
Right, dive to 1120 and drive to CULVE, then dive to 680.
So, the question is still, how does the GulfStream get from CULVE at
1120 down to 0 at the numbers. I was in IMC with gear and flaps down,
power at idle and in a slip and I was still about 3/4 down when I
touched. Does a GulfStream drop faster than a Mooney?
FWIW, my quick and dirty math shows ~5.5 degree slope from CULVE to
threshold @ 1120. If you keep that slope, you would have broken
through the clouds about 6500 ft from the threshold at 800 (625 agl).
The Gulf's approach speed is something like 120 or 130. Calling it
130, that's a 1300-1400fpm descent rate at that slope. If the gulf
can do that, then they could keep a nice steady path to the threshold
@ 5.5 degrees.
Now if you dive at a 6.5 degree slope at CULVE, you are decreasing
your final angle to 5 degrees while extending your distance to
threshold another 500 ft when breaking out.
Of course, this all assumes that you are actually at 1120 when at
culve g
And that your approach speed and threshold crossing speed are the same
(i,e. that you don't need additional room to slow down
Yes, I told you it was quick and dirty (I did it pretty much in my
head. there's *alot* of rounding in there g)
I did a search and can't find any performance characteristics of a
gulf on the web, except an accident report stating the probable cause
of an accident as the pilot's putting the plane in an unstabilized
2500fpm descent profile :-/
SDF Approach? A Guy Called Tyketto Piloting 9 April 18th 07 01:32 AM
First LPV approach Viperdoc[_4_] Instrument Flight Rules 0 March 5th 07 03:23 AM
ILS or LOC approach? Dan Wegman Instrument Flight Rules 17 May 9th 05 11:41 PM
No FAF on an ILS approach...? John Harper Instrument Flight Rules 7 December 24th 03 03:54 AM
Completing the Non-precision approach as a Visual Approach John Clonts Instrument Flight Rules 45 November 20th 03 05:20 AM
