"Ed Rasimus" wrote
Don't know where you were in the food chain of aircrew training, but if it was installed in the planes every single day, you can bet we knew how to use it. If it were mission essential or mission critical we got trained in it, refreshed in it, tested in it, and briefed on every single mission with regard to employment of it. Well... OK... One thing that fighter/bomber crews never seemed to understand was Mode-4 IFF, and wide-band secure voice. In Iceland the mission was to intercept and escort any unidentified aircraft through the defense zone. What that meant in real life was that if the IFF gave you problems, you shut it off. If you couldn't talk to AWACS, or the Shack on secure, then you switched to clear. Billions in hardware in the off position. Finally in 1986 the Air Force started getting serious, and they made the bean count on those two items as painful as possible. What we found, was that the crews just didn't understand the poorly designed fault indicators, and since there was no incentive to operate the equipment, they just shut it off. 1) The Soviets know we're there, 2) The Soviets understand how NATO intercepts are conducted, and 3) By doing the intercepts in the clear, the Soviets weren't surprised when fighters and tankers, and P-3's, etc, all pounced on them for escort. All of which HQ decided was too damned non-mil to continue. The Army finally came along in the early 90's after the highly trained USAF pilots and AWACS controllers splashed their non-participants in Iraq. Today, I think the radio is a completely different tool than it was before 1986. The use of wide and narrow secure when it's even necessary, is the favored position (especially satcom). I listened to some of the Air/Air recordings from a strike near Hanoi by a flight of 105's when I went to a technical seminar, and it pretty much defined the word Clint Eastwood had about Clusters... I can see where crews might have training/operational problems with gadgets even more complex than the IFF and Wide-Band panels. |
On Sun, 21 Sep 2003 17:38:44 GMT, "Gene Storey"
wrote: "Ed Rasimus" wrote Don't know where you were in the food chain of aircrew training, but if it was installed in the planes every single day, you can bet we knew how to use it. If it were mission essential or mission critical we got trained in it, refreshed in it, tested in it, and briefed on every single mission with regard to employment of it. Well... OK... One thing that fighter/bomber crews never seemed to understand was Mode-4 IFF, and wide-band secure voice. In Iceland the mission was to intercept and escort any unidentified aircraft through the defense zone. What that meant in real life was that if the IFF gave you problems, you shut it off. If you couldn't talk to AWACS, or the Shack on secure, then you switched to clear. Billions in hardware in the off position. Foggy memory trying to recall things. Best I recollect (although I might be wrong) was that the IFF/SIF had cockpit control of modes 1, 2, 3 and C. Don't recall that Mode-4 was cockpit controllable. In the F-4 the coding was done in the nosegear well on the ground with a plunger-like device. If you're talking peace-time air defense intercept, and you've got 1,2,3 and C so that AWACS/GCI can control you, then I'd have to agree with the decision to go. In combat, interdiction, across the fence, then I'd say the prudent choice would be no-go. As for secure, again, if you are an interceptor and (as you stated the situation), you can't talk to AWACS, etc. secure, you still go and acknowledge that you're degraded. The option is to not go and be penetrated. As for your final statement, "billions in hardware in the off position"--I'd say maybe millions if all the force wasn't using those two sub-systems, and I'd say that you didn't indicate that all the force wasn't using the systems--you simply provided a couple of examples of "if the IFF gave you problems" and "if you couldn't talk secure". Seems like you're describing a choice of mission accomplishment or not, in limited situations. Today, I think the radio is a completely different tool than it was before 1986. The use of wide and narrow secure when it's even necessary, is the favored position (especially satcom). I listened to some of the Air/Air recordings from a strike near Hanoi by a flight of 105's when I went to a technical seminar, and it pretty much defined the word Clint Eastwood had about Clusters... Well, it depends on when during the conflict the radio recording you heard was made. There was no Have Quick or later version of secure voice. Depending upon the training of the crews (see my comments in this forum in the past or in WTR for re-qual of various types in fighters), the mission de jour, the weather, the defenses, etc. etc. it could indeed be an example of remarkable incompetence. But, that certainly can't be an example to support your argument regarding what the crews "understand". Understanding the purpose, operation, etc of equipment is a whole lot different depending upon the mission circumstances, and quite obviously, the equipment availability or existence. |
"Ed Rasimus" wrote
Foggy memory trying to recall things. Best I recollect (although I might be wrong) was that the IFF/SIF had cockpit control of modes 1, 2, 3 and C. Don't recall that Mode-4 was cockpit controllable. In the F-4 the coding was done in the nosegear well on the ground with a plunger-like device. Trivia alert Probably had a "zero, a/b, hold switch", and a caution lite. there was two codes a-today b-tomorrow, and the hold kept your plunger data on a hot turn, while the caution lite blinked when someone interrogated you, but your box couldn't decode it, and it stayed on solid if you lost your crypto (plunger data) or the computer went TU. Usually the blinking lite is the worst, because it means the Patriot battery is now trying to figure out a second way to ID you |
Making your own canopy | c hinds | Home Built | 6 | November 22nd 04 09:10 AM |
Why is a standard hold right turns? | Roy Smith | Instrument Flight Rules | 51 | August 28th 04 06:09 PM |
need advice with composite for making glare shield | bubba | Home Built | 1 | July 7th 04 05:44 AM |
Making my landing gear | Lou Parker | Home Built | 8 | March 31st 04 10:34 PM |
Air Force launches rocket with secret military payload from Cape Canaveral | Otis Willie | Military Aviation | 0 | September 9th 03 09:07 PM |
