![]() "Morgans" wrote in message ... "Blueskies" wrote I forget which brand truck we were looking at (Ford?), but it had a sculpted shape to the top of the tailgate about 8" wide. The salesman said it helped to improve gas mileage... He was wrong. It is to provide extra clearance for people towing 5th wheel or gooseneck trailers. -- Jim in NC No, it was not a 5th wheel clearance thing. I did not describe it very clearly. Regular rectangular tailgate with a wide upper (top when closed) edge... |
Blueskies wrote:
"Morgans" wrote in message ... "Blueskies" wrote I forget which brand truck we were looking at (Ford?), but it had a sculpted shape to the top of the tailgate about 8" wide. The salesman said it helped to improve gas mileage... He was wrong. It is to provide extra clearance for people towing 5th wheel or gooseneck trailers. -- Jim in NC No, it was not a 5th wheel clearance thing. I did not describe it very clearly. Regular rectangular tailgate with a wide upper (top when closed) edge... You see it on a lot of trucks. It used to be that a box van was just that, a box. A decade or so ago, they started rounding the front edges of the box. Can you say "fairing". Some started rounding the back corners also. I've seen SUV's with what looks like reverse scoops that could have to catch the air passing over the top of the vehicle and blow it down the back. Counterintuitive until you realize that attached flow offers less drag. The thick tailgate with the rounded edge keeps the air in attached flow longer. Even a small amount, just a few inches, offers major improvements over the previous generations 90 degree chop offs. |
![]() You see it on a lot of trucks. It used to be that a box van was just that, a box. A decade or so ago, they started rounding the front edges of the box. Can you say "fairing". Some started rounding the back corners also. I've seen SUV's with what looks like reverse scoops that could have to catch the air passing over the top of the vehicle and blow it down the back. Counterintuitive until you realize that attached flow offers less drag. You have been tricked! The attached downward flow has nothing to do with drag; but is to keep exhaust and also road dirt away from the rear of the vehicle. Similar ducts became a standard feature of tull sized station wagons during the '60s and '70s. The thick tailgate with the rounded edge keeps the air in attached flow longer. Even a small amount, just a few inches, offers major improvements over the previous generations 90 degree chop offs. I have yet to examine the rounded tail gate, but have my doubts. Suffice it to say that some salesmen are even more creative than the brochure writers--so you might compare the company litterature to the salesman's assertion. Peter |
![]() "Ernest Christley" wrote I've seen SUV's with what looks like reverse scoops that could have to catch the air passing over the top of the vehicle and blow it down the back. Counterintuitive until you realize that attached flow offers less drag. That scoop helps drag, but more importantly, it prevents carbon monoxide from entering in the back window when it is open and driving at highway speeds. When a chopped off SUV has the window open, that low pressure area in the back gathers up the exhaust, and the swirling motion of the vortex allows some to enter in though the open window. Not good. The scoop supplies fresh air flowing down from the top, and keeps the bad air down lower than the open window. They have been doing that since the 60's, on old station wagons, before they cared about mileage and aerodynamics. -- Jim in NC |
You guys haven't mentioned the biggie - roof racks. Removing the cross bars
from my Grand Cherokee added 2MPG. Glider pilots look at roof racks and see open air brakes. I can't believe the number of vehicles I see in Denver with ski racks in July. Then, of course, you can park the truck. I understand that trucks have very low drag when parked. If the vehicle has a MPG computer, you can see what speed does to MPG. At 65, my Jeep gets 19MPG. At 55, it gets 24MPG. At 45, it gets 36MPG. If you do the numbers, saving two minutes by driving fast costs big time. Those are REALLY expensive minutes - more than the rental on some airplanes. Bill Daniels "Morgans" wrote in message ... "Ernest Christley" wrote I've seen SUV's with what looks like reverse scoops that could have to catch the air passing over the top of the vehicle and blow it down the back. Counterintuitive until you realize that attached flow offers less drag. That scoop helps drag, but more importantly, it prevents carbon monoxide from entering in the back window when it is open and driving at highway speeds. When a chopped off SUV has the window open, that low pressure area in the back gathers up the exhaust, and the swirling motion of the vortex allows some to enter in though the open window. Not good. The scoop supplies fresh air flowing down from the top, and keeps the bad air down lower than the open window. They have been doing that since the 60's, on old station wagons, before they cared about mileage and aerodynamics. -- Jim in NC |
"Bill Daniels" bildan@comcast-dot-net wrote: You guys haven't mentioned the biggie - roof racks. Removing the cross bars from my Grand Cherokee added 2MPG. Glider pilots look at roof racks and see open air brakes. I can't believe the number of vehicles I see in Denver with ski racks in July. Then, of course, you can park the truck. I understand that trucks have very low drag when parked. If the vehicle has a MPG computer, you can see what speed does to MPG. At 65, my Jeep gets 19MPG. At 55, it gets 24MPG. At 45, it gets 36MPG. If you do the numbers, saving two minutes by driving fast costs big time. Those are REALLY expensive minutes - more than the rental on some airplanes. Real world case; let's use your figures for simplicity's sake: I want to drive from Vancouver to Kelowna. A little check with Google Maps tells us that that's a distance of... ....393 kilometers, or about 245 miles. At 65, that takes me about 3 hours, 45 minutes and I use about 13 gallons of gas. At 55, it takes 4 hours, 30 minutes and I use about 10 gallons of gas. Even at Canadian gas prices, those 10 litres of fuel cost me only about $11.50. Is that really too much to pay to save 45 minutes of my precious time? 25 cents a minute seem pretty cheap to me. Bill Daniels "Morgans" wrote in message ... "Ernest Christley" wrote I've seen SUV's with what looks like reverse scoops that could have to catch the air passing over the top of the vehicle and blow it down the back. Counterintuitive until you realize that attached flow offers less drag. That scoop helps drag, but more importantly, it prevents carbon monoxide from entering in the back window when it is open and driving at highway speeds. When a chopped off SUV has the window open, that low pressure area in the back gathers up the exhaust, and the swirling motion of the vortex allows some to enter in though the open window. Not good. The scoop supplies fresh air flowing down from the top, and keeps the bad air down lower than the open window. They have been doing that since the 60's, on old station wagons, before they cared about mileage and aerodynamics. -- Jim in NC -- Alan Baker Vancouver, British Columbia "If you raise the ceiling four feet, move the fireplace from that wall to that wall, you'll still only get the full stereophonic effect if you sit in the bottom of that cupboard." |
On Jul 27, 7:49 pm, Alan Baker wrote:
In article , "Bill Daniels" bildan@comcast-dot-net wrote: You guys haven't mentioned the biggie - roof racks. Removing the cross bars from my Grand Cherokee added 2MPG. Glider pilots look at roof racks and see open air brakes. I can't believe the number of vehicles I see in Denver with ski racks in July. Then, of course, you can park the truck. I understand that trucks have very low drag when parked. If the vehicle has a MPG computer, you can see what speed does to MPG. At 65, my Jeep gets 19MPG. At 55, it gets 24MPG. At 45, it gets 36MPG. If you do the numbers, saving two minutes by driving fast costs big time. Those are REALLY expensive minutes - more than the rental on some airplanes. Real world case; let's use your figures for simplicity's sake: I want to drive from Vancouver to Kelowna. A little check with Google Maps tells us that that's a distance of... ...393 kilometers, or about 245 miles. At 65, that takes me about 3 hours, 45 minutes and I use about 13 gallons of gas. At 55, it takes 4 hours, 30 minutes and I use about 10 gallons of gas. Even at Canadian gas prices, those 10 litres of fuel cost me only about $11.50. Is that really too much to pay to save 45 minutes of my precious time? 25 cents a minute seem pretty cheap to me. Bill Daniels "Morgans" wrote in message ... "Ernest Christley" wrote I've seen SUV's with what looks like reverse scoops that could have to catch the air passing over the top of the vehicle and blow it down the back. Counterintuitive until you realize that attached flow offers less drag. That scoop helps drag, but more importantly, it prevents carbon monoxide from entering in the back window when it is open and driving at highway speeds. When a chopped off SUV has the window open, that low pressure area in the back gathers up the exhaust, and the swirling motion of the vortex allows some to enter in though the open window. Not good. The scoop supplies fresh air flowing down from the top, and keeps the bad air down lower than the open window. They have been doing that since the 60's, on old station wagons, before they cared about mileage and aerodynamics. -- Jim in NC -- Alan Baker Vancouver, British Columbia "If you raise the ceiling four feet, move the fireplace from that wall to that wall, you'll still only get the full stereophonic effect if you sit in the bottom of that cupboard."- Hide quoted text - - Show quoted text - I think it will cost a bit more than that. From my experiences in the B.C. lakes region and the Coq the cops are a bit anal about the posted limits. It has been a few years but the Coq was posted 110 (about 62mph). Then there is that stretch from Merritt until you pick up the Eastern extension of the freeway that is posted 90. Then from Peachland to Kelowna is again max of 90 with stretches down to 80 (IIRC). You might be parked alongside the road a bit. ![]() I got a ticket in there "Exceeding speed limit while passing". Harry K |
In article . com,
Harry K wrote: On Jul 27, 7:49 pm, Alan Baker wrote: In article , "Bill Daniels" bildan@comcast-dot-net wrote: You guys haven't mentioned the biggie - roof racks. Removing the cross bars from my Grand Cherokee added 2MPG. Glider pilots look at roof racks and see open air brakes. I can't believe the number of vehicles I see in Denver with ski racks in July. Then, of course, you can park the truck. I understand that trucks have very low drag when parked. If the vehicle has a MPG computer, you can see what speed does to MPG. At 65, my Jeep gets 19MPG. At 55, it gets 24MPG. At 45, it gets 36MPG. If you do the numbers, saving two minutes by driving fast costs big time. Those are REALLY expensive minutes - more than the rental on some airplanes. Real world case; let's use your figures for simplicity's sake: I want to drive from Vancouver to Kelowna. A little check with Google Maps tells us that that's a distance of... ...393 kilometers, or about 245 miles. At 65, that takes me about 3 hours, 45 minutes and I use about 13 gallons of gas. At 55, it takes 4 hours, 30 minutes and I use about 10 gallons of gas. Even at Canadian gas prices, those 10 litres of fuel cost me only about $11.50. Is that really too much to pay to save 45 minutes of my precious time? 25 cents a minute seem pretty cheap to me. Bill Daniels "Morgans" wrote in message ... "Ernest Christley" wrote I've seen SUV's with what looks like reverse scoops that could have to catch the air passing over the top of the vehicle and blow it down the back. Counterintuitive until you realize that attached flow offers less drag. That scoop helps drag, but more importantly, it prevents carbon monoxide from entering in the back window when it is open and driving at highway speeds. When a chopped off SUV has the window open, that low pressure area in the back gathers up the exhaust, and the swirling motion of the vortex allows some to enter in though the open window. Not good. The scoop supplies fresh air flowing down from the top, and keeps the bad air down lower than the open window. They have been doing that since the 60's, on old station wagons, before they cared about mileage and aerodynamics. -- Jim in NC -- Alan Baker Vancouver, British Columbia "If you raise the ceiling four feet, move the fireplace from that wall to that wall, you'll still only get the full stereophonic effect if you sit in the bottom of that cupboard."- Hide quoted text - - Show quoted text - I think it will cost a bit more than that. From my experiences in the B.C. lakes region and the Coq the cops are a bit anal about the posted limits. It has been a few years but the Coq was posted 110 (about 62mph). Then there is that stretch from Merritt until you pick up the Eastern extension of the freeway that is posted 90. Then from Peachland to Kelowna is again max of 90 with stretches down to 80 (IIRC). You might be parked alongside the road a bit. ![]() I got a ticket in there "Exceeding speed limit while passing". Harry K Sorry, Harry, but I can't agree. Stay below about 20 klicks over the limit and you won't ever get stopped. If you're truly nervous, limit yourself to 15 over. -- Alan Baker Vancouver, British Columbia "If you raise the ceiling four feet, move the fireplace from that wall to that wall, you'll still only get the full stereophonic effect if you sit in the bottom of that cupboard." |
On Jul 27, 8:49 pm, Alan Baker wrote:
In article , "Bill Daniels" bildan@comcast-dot-net wrote: If the vehicle has a MPG computer, you can see what speed does to MPG. At 65, my Jeep gets 19MPG. At 55, it gets 24MPG. At 45, it gets 36MPG. If you do the numbers, saving two minutes by driving fast costs big time. Those are REALLY expensive minutes - more than the rental on some airplanes. At about $4.25 per US gallon around here (Alberta, Canada) 65 MPH and 19 MPG is $14.54 an hour for fuel. At 45 MPH and 36 MPG it comes to $5.31 per hour. The savings come to $9.23 per hour. I'd like to know what airplane--even an ultralight--that would go for under $10 per hour? Even my little old homebuilt with its 65 hp engine costs me about $20 per hour for fuel. Our Cessna 172s rent for $127 per hour, which is fairly typical. Dan |
Bill Daniels wrote:
You guys haven't mentioned the biggie - roof racks. Removing the cross bars from my Grand Cherokee added 2MPG. Glider pilots look at roof racks and see open air brakes. I can't believe the number of vehicles I see in Denver with ski racks in July. Then, of course, you can park the truck. I understand that trucks have very low drag when parked. If the vehicle has a MPG computer, you can see what speed does to MPG. At 65, my Jeep gets 19MPG. At 55, it gets 24MPG. At 45, it gets 36MPG. If you do the numbers, saving two minutes by driving fast costs big time. Those are REALLY expensive minutes - more than the rental on some airplanes. Bill Daniels Can't argue against the open drag brake idea. I have a nice pair on my Blazer. My impression is that they are there to enhance roll-over protection. I don't have the MPG computer, but I just drove down to Centerville last weekend. 120 miles alnost exactly. V6 4 speed automatic - with highay gearing, it's NOT a tow truck. (and when I hook the boat on the back the Blazer whines and whimpers) 22 MPG going down at 75-85 mph. 26 coming back ar 65. But about 18 around town... Bringing the boat home from Khema - in stop and go Houston traffic - climbing the ovepasses from a standing stop - first 100 miles at 10 to 25 MPH took 10 gallons. After that, at about 50 MPH I got more like 15-16 MPG. (The boat is 18 ft long, but over 1500 pounds - plus a heavy trailer) As they say, YMMV. Sometimes a LOT... Richard |
Myth: 1 G barrel rolls are impossible. | Jim Logajan | Piloting | 244 | June 22nd 07 04:33 AM |
Dispelling the Myth: Hillary Clinton and the Purple Heart | Otis Willie | Naval Aviation | 0 | February 21st 06 05:41 AM |
dam busters | Hamisha3 | Military Aviation | 48 | February 26th 04 11:17 PM |
cheap, durable, homebuilt aircrafts- myth or truth? | -=:|SAJAN|:=- | Home Built | 27 | January 8th 04 09:05 AM |
The myth that won't die. | Roger Long | Piloting | 7 | December 19th 03 06:15 PM |
