VOR approach SMO
Old July 26th 07, 11:15 PM posted to rec.aviation.piloting,rec.aviation.ifr
Robert M. Gary
Default VOR approach SMO
On Jul 26, 11:14 am, B A R R Y wrote:
Robert M. Gary wrote:
See, it even fooled you. You cannot go to 680 until after CULVE but I
can see how it mislead you.
Can I have cheese on that crow?
Hey, its not just you. I was questioning it myself after Karl's posts.
I guess the thing to take away from this to me is that the plan view
does not necessarily present the MDA. The MDA (presented in teh box
below) *only* applies after the FAF and that the plan view may not
show that. Luckily I knew that when I flew it in IMC last weekend
-Robert
  #112
Old July 27th 07, 01:03 AM posted to rec.aviation.piloting,rec.aviation.ifr
B A R R Y
On Thu, 26 Jul 2007 11:27:01 -0700, Hamish Reid
I dunno -- this has been one of the few Usenet threads I've participated
in over the decades where posters in the wrong have actually not only
admitted it but apologised for it. Which makes it something special in
Usenet terms :-).
Sometimes, you step in crap. When it happens, you can discretely
scrape it off outside. Or, you can pretend it wasn't you, and get it
all over the carpet.
I have too much respect for the experience of this group to not go
back outside and scrape it off. G
My home airport has a constantly NOTAM'd OOS localizer, so the only
way back in is a VOR approach. I should know better about step down
fixes. Once I "ghost flew" the approach at my desk, I realized how
wrong I was. It took Robert's "you would have crashed" message for me
to actually do the "ghost approach", and realize that I really _would_
have crashed.
Barry
  #113
Old July 27th 07, 11:39 PM posted to rec.aviation.piloting,rec.aviation.ifr
TakeFlight
Just for kicks I flew this approach in MS FSX with the CRJ700. I set
the wx to 800 & 3 (no wind) and figured I'd see what kind of
acrobatics I would have to do. I crossed CULVE at 1100' with 130 kts
and flaps 45. I descended for 680 MDA at around 1800 fpm, which
surprisingly did not require any deploy of the spoilers. I broke out
of the clouds and continued this descent until reaching the VASI
glideslope at around 450' and 1/2 mile out. From here on it was a
normal descent and I was able to plop down on the aiming point
markers. For what it's worth, FSX had the threshold being at 0.9 DME.
I know FSX isn't the same as the real world, and I'm not sure I would
want to be dropping that fast at such a low altitude, but it seems
like it wouldn't be a stretch for that Gulfstream to make it in on the
numbers if they were on top of their game....
Erik
CFII, MEI
On Jul 23, 12:39 pm, "Robert M. Gary" wrote:
The other day I shot the VOR approach into SMO for the first time in
low actual. I've often looked at that approach as one of the most
difficult I've seen published so it was interesting to actually try
it. The weather was 008OVC with something like 3sm HZ. I touched down
about 3/4 down the runway and was able to stop without a problem.
However, while taxiing back, I noticed a Gulf Stream land right on the
numbers. There is no way you can tell me he properly flew the approach
and was able to touch on the numbers.
The approach is published as a circle to land (I assume because of the
extreme nature of the decent) but they certainly were not offering to
allow anyone to circle. In fact there was a steady line of jets coming
in, it would probably have been unlikely to get a circle approved.
Last night I departed. AWOS was reporting 005OVC. I took off right
around 21:10. There was a large Citation right behind me picking up
his clearance. I didn't ever hear him depart on approach frequency so
I'm assuming he missed his curfew and his execs got stranded.
-Robert
  #114
Old July 28th 07, 01:45 AM posted to rec.aviation.piloting,rec.aviation.ifr
Doug Semler
FWIW, I believe I remember reading an NTSB report of a Gulf crash (at
i believe Aspen). While it wasn't in the POH, the policy of the
charter company was that spoilers were not to be deployed when landing
gear or flaps were extended...It was mentioned in the report because
investigation revealed that the spoilers were extended on impact...
I broke out
markers.
Out of curiosity, what was your "speed" at 1800 fpm? I thought SMO
had a PAPI on 21 but it is FSX...
Sounds about right (maybe a bit long...)
  #115
Old July 28th 07, 01:51 PM posted to rec.aviation.piloting,rec.aviation.ifr
TakeFlight
I was able to hold 130 kts all the way down. My intent was to pin the
speed and see what kind of descent rate I would get (and need) to pull
it off. I wasn't expecting to get that much without dropping the
spoilers at least 1/4, but I was at idle, which probably isn't
SOP...In all fairness, I've never flown a "real" jet, unless the 737
sim at UAL counts
You're right about the lights...it is a PAPI in FSX.
  #116
Old July 30th 07, 06:23 PM posted to rec.aviation.piloting,rec.aviation.ifr
Dave Butler
Maybe easy in a 172 but not in my Mooney. With gear and flaps out and
power at idle I don't think I can do 885 ft/min without a lot of
slipping. Even if I could there is still the issue of going from 90
knots approach speed down to 70 knots threshold crossing speed.
Go ahead and slow to 70 earlier. Your angle of descent is steeper at 70
than at 90.
DB
  #117
Old July 30th 07, 06:37 PM posted to rec.aviation.piloting,rec.aviation.ifr
Dave Butler
Of course I came in high and fast. That's really the point of this
thread, that the approach requires you to be high and fast (my minimum
IFR approach speed is 90 knots) and of course I was 1120 about 2 miles
from the end of the runway as required by the approach.
What's the rationale for the minimum IFR approach speed of 90 knots? A
slower approach speed will get you the required descent angle.
Try flying approaches at different speeds in VMC and see what you get.
DB
  #118
Old July 30th 07, 06:38 PM posted to rec.aviation.piloting,rec.aviation.ifr
Dave Butler
And that your approach speed and threshold crossing speed are the same
(i,e. that you don't need additional room to slow down).
There's no reason they can't be the same, e.g. 70 knots, if that's what
you need to make the descent angle.
DB
  #119
Old July 30th 07, 06:42 PM posted to rec.aviation.piloting,rec.aviation.ifr
Dave Butler
karl gruber wrote:
I have never used NACO charts, ever.
From the NACO chart I downloaded, there are four identical asterisks. It is
very easy to read the chart as I did, as one of the asterisk points to
crossing at the lower altitude. Another poster read it that way as well.
The Jeppesen charts show no such ambiguity.
I agree, Karl. With the benefit of all this discussion and sitting
comfortably at my workstation, the chart is unambiguous. If I were
prepping the approach while trying to fly the airplane (which *does*
happen sometimes) I'm not sure I couldn't have been similarly misled. I
think NACO could find a better way to convey the correct information.
DB
  #120
Old July 30th 07, 07:13 PM posted to rec.aviation.piloting,rec.aviation.ifr
Hamish Reid
As a long-time NACO chart user, I found it unambiguous, but that wasn't
the point I was concentrating on the later parts of this thread, which
was: didn't *anyone* who advocated going below 1120 immediately after
BEVEY notice the obstructions? Doesn't anyone else look at things like
that as well as the bare minimums? Unlike Karl, I'm no ATP, but it's
typically one of the first things I look at with an unfamiliar
approach...
Hamish
SDF Approach? A Guy Called Tyketto Piloting 9 April 18th 07 01:32 AM
First LPV approach Viperdoc[_4_] Instrument Flight Rules 0 March 5th 07 03:23 AM
ILS or LOC approach? Dan Wegman Instrument Flight Rules 17 May 9th 05 11:41 PM
No FAF on an ILS approach...? John Harper Instrument Flight Rules 7 December 24th 03 03:54 AM
Completing the Non-precision approach as a Visual Approach John Clonts Instrument Flight Rules 45 November 20th 03 05:20 AM
