. net... Here's a good set of photos of the accident showing a different perspective than the video we've seen. Scott Wilson http://flickr.com/photos/lscan/sets/72157601065523576/ In the video, it really looked like the situation had already deteriorated more than a quarter mile out, and then it just continued to get worse. (And the assumptions which I initially made are now in serious doubt.) That further amplifies a question that I have for Dudley: You mentioned a distinction military and civilain pilots; and I can think of several possible reasons: the civilians pilots are usually older, less experienced in type, and formation flying is not part of their primary occupation--but I suspect that there is something even more basic that I am leaving out. Peter |
![]() Peter Dohm wrote: wrote in message . net... Here's a good set of photos of the accident showing a different perspective than the video we've seen. Scott Wilson http://flickr.com/photos/lscan/sets/72157601065523576/ In the video, it really looked like the situation had already deteriorated more than a quarter mile out, and then it just continued to get worse. (And the assumptions which I initially made are now in serious doubt.) That further amplifies a question that I have for Dudley: You mentioned a distinction military and civilain pilots; and I can think of several possible reasons: the civilians pilots are usually older, less experienced in type, and formation flying is not part of their primary occupation--but I suspect that there is something even more basic that I am leaving out. Peter Yes. It's so basic it has a tendency to lose itself in analysis. The military was just as aware as everyone else about the hazzards associated with section landings. Putting multiple airplanes on the same runway landing at the same time has obvious risks. If lead for example blows a tire on the side the trailer is landing on, the resulting swerve could be a real issue. Judgment and unforseen incursions on the runway are also considerations. The list of possible issues is indeed long and filled with pot holes that could spoil your day. The military however has a problem we as civilians don't have. They have a situation that involves time. In combat, there is always the issue of getting multiple aircraft on the ground quickly and turned around, rearmed and refueled and back into the air again. Also, there is the issue of vulnerability. Fighters slowed down to pattern speeds and dirty are duck soup for attacking enemy fighters. For the reasons I've stated above, the 360 overhead approach was initiated by the military. The objective of this type of approach is to space close in and tight, keep the pattern speeds up, and get the birds down as quickly as possible. Section landings became an integral part of this scenario and was accepted and is accepted even today as a reasonable risk factor considering extensive flight training and awareness of the pilots doing this work. It is worthy of note that even in the military, landing prop tailwheel fighters this way was considered a far greater risk factor than landing high performance nose wheel jet fighters; the reason being the loss of visual cues for the wingman landing next to his element lead. Now enter civilians with a few bucks and flying P51 Mustangs and you have a situation where the time factor is no longer present in the section landing equation. The powers that be who set up training schedules for these pilots in these aircraft know quite well the dangers of section landings in prop fighters. For this reason, organizations like Warbirds of America and EAA and the T34 Formation Training Syllabus specifically note that section landings in P51's are NOT considered to be safe enough to warrant the risk factor. So this is basically how it works. If you own a P51 and you have taken the trouble to seek out and take the suggested training given by people who know what they are doing, you don't attempt section landings in P51 aircraft. There is no law however that MAKES the P51 owner attend these classes. The result I believe, we have seen with this latest accident at Oshkosh. Both of these pilots were good sticks in these airplanes. It saddens me to know that this accident was so damn preventable simply by following basic information and training readily available for pilots flying P51 Mustangs, and in play as we speak. Dudley Henriques |
![]() "Dudley Henriques" wrote in message ... In the video, it really looked like the situation had already deteriorated more than a quarter mile out, and then it just continued to get worse. (And the assumptions which I initially made are now in serious doubt.) That further amplifies a question that I have for Dudley: You mentioned a distinction military and civilain pilots; and I can think of several possible reasons: the civilians pilots are usually older, less experienced in type, and formation flying is not part of their primary occupation--but I suspect that there is something even more basic that I am leaving out. Peter Yes. It's so basic it has a tendency to lose itself in analysis. The military was just as aware as everyone else about the hazzards associated with section landings. Putting multiple airplanes on the same runway landing at the same time has obvious risks. If lead for example blows a tire on the side the trailer is landing on, the resulting swerve could be a real issue. Judgment and unforseen incursions on the runway are also considerations. The list of possible issues is indeed long and filled with pot holes that could spoil your day. The military however has a problem we as civilians don't have. They have a situation that involves time. In combat, there is always the issue of getting multiple aircraft on the ground quickly and turned around, rearmed and refueled and back into the air again. Also, there is the issue of vulnerability. Fighters slowed down to pattern speeds and dirty are duck soup for attacking enemy fighters. For the reasons I've stated above, the 360 overhead approach was initiated by the military. The objective of this type of approach is to space close in and tight, keep the pattern speeds up, and get the birds down as quickly as possible. Section landings became an integral part of this scenario and was accepted and is accepted even today as a reasonable risk factor considering extensive flight training and awareness of the pilots doing this work. It is worthy of note that even in the military, landing prop tailwheel fighters this way was considered a far greater risk factor than landing high performance nose wheel jet fighters; the reason being the loss of visual cues for the wingman landing next to his element lead. Now enter civilians with a few bucks and flying P51 Mustangs and you have a situation where the time factor is no longer present in the section landing equation. The powers that be who set up training schedules for these pilots in these aircraft know quite well the dangers of section landings in prop fighters. For this reason, organizations like Warbirds of America and EAA and the T34 Formation Training Syllabus specifically note that section landings in P51's are NOT considered to be safe enough to warrant the risk factor. So this is basically how it works. If you own a P51 and you have taken the trouble to seek out and take the suggested training given by people who know what they are doing, you don't attempt section landings in P51 aircraft. There is no law however that MAKES the P51 owner attend these classes. The result I believe, we have seen with this latest accident at Oshkosh. Both of these pilots were good sticks in these airplanes. It saddens me to know that this accident was so damn preventable simply by following basic information and training readily available for pilots flying P51 Mustangs, and in play as we speak. Dudley Henriques That's almost the proverbial "elephant in the room" which has been present so long that it seems to dissappear. I did not even consider the need to get assets quickly inside a ground defense perimeter and on the ground with a minimun loss of speed; and then, if necessary, relaunch an air defense as rapidly as possible. Thanks again for the much needed observations. Peter |
My pleasure. Sorry it has to be under such bad circumstances.
DH Peter Dohm wrote: "Dudley Henriques" wrote in message ... In the video, it really looked like the situation had already deteriorated more than a quarter mile out, and then it just continued to get worse. (And the assumptions which I initially made are now in serious doubt.) That further amplifies a question that I have for Dudley: You mentioned a distinction military and civilain pilots; and I can think of several possible reasons: the civilians pilots are usually older, less experienced in type, and formation flying is not part of their primary occupation--but I suspect that there is something even more basic that I am leaving out. Peter Yes. It's so basic it has a tendency to lose itself in analysis. The military was just as aware as everyone else about the hazzards associated with section landings. Putting multiple airplanes on the same runway landing at the same time has obvious risks. If lead for example blows a tire on the side the trailer is landing on, the resulting swerve could be a real issue. Judgment and unforseen incursions on the runway are also considerations. The list of possible issues is indeed long and filled with pot holes that could spoil your day. The military however has a problem we as civilians don't have. They have a situation that involves time. In combat, there is always the issue of getting multiple aircraft on the ground quickly and turned around, rearmed and refueled and back into the air again. Also, there is the issue of vulnerability. Fighters slowed down to pattern speeds and dirty are duck soup for attacking enemy fighters. For the reasons I've stated above, the 360 overhead approach was initiated by the military. The objective of this type of approach is to space close in and tight, keep the pattern speeds up, and get the birds down as quickly as possible. Section landings became an integral part of this scenario and was accepted and is accepted even today as a reasonable risk factor considering extensive flight training and awareness of the pilots doing this work. It is worthy of note that even in the military, landing prop tailwheel fighters this way was considered a far greater risk factor than landing high performance nose wheel jet fighters; the reason being the loss of visual cues for the wingman landing next to his element lead. Now enter civilians with a few bucks and flying P51 Mustangs and you have a situation where the time factor is no longer present in the section landing equation. The powers that be who set up training schedules for these pilots in these aircraft know quite well the dangers of section landings in prop fighters. For this reason, organizations like Warbirds of America and EAA and the T34 Formation Training Syllabus specifically note that section landings in P51's are NOT considered to be safe enough to warrant the risk factor. So this is basically how it works. If you own a P51 and you have taken the trouble to seek out and take the suggested training given by people who know what they are doing, you don't attempt section landings in P51 aircraft. There is no law however that MAKES the P51 owner attend these classes. The result I believe, we have seen with this latest accident at Oshkosh. Both of these pilots were good sticks in these airplanes. It saddens me to know that this accident was so damn preventable simply by following basic information and training readily available for pilots flying P51 Mustangs, and in play as we speak. Dudley Henriques That's almost the proverbial "elephant in the room" which has been present so long that it seems to dissappear. I did not even consider the need to get assets quickly inside a ground defense perimeter and on the ground with a minimun loss of speed; and then, if necessary, relaunch an air defense as rapidly as possible. Thanks again for the much needed observations. Peter |
Dudley
Our pilots used to catch the German fighters (and jets) in pattern and run their score up. Shooting fish in a barrel. Never flew an overhead pattern until after the War that I can remember. The pitch off the deck was the procedure used until after War and the accident rate doing that became excessive and they changed to the overhead. An off the deck pitch let you make a touch down after about only 15 seconds from the pitch 350 mph on approach. Throttle idle on pitch and pull up TIGHT in turn to bleed off airspeed. After 180 degrees of climbing turn your airspeed was down to where you could put down full flaps and drop gear, continuing the last 180 degrees of turn to align with runway and then touch down at normal touch down speed. A pitch up almost killed me. Came back to base just after take off with a leaking fuel cap. Made the normal tight pitch up (forgot I was heavy with fuel) and bird stalled in last 90 degrees of turn. I rudder walked the bird down and hit on right main gear and right aileron. Took around and was much more cautious next landing. If I haven't been a good and LUCKY pilot would not be here today ![]() Nice dry day here in Houston today. Big John ******************************************* On Tue, 31 Jul 2007 11:24:02 -0400, Dudley Henriques wrote: Peter Dohm wrote: wrote in message . net... Here's a good set of photos of the accident showing a different perspective than the video we've seen. Scott Wilson http://flickr.com/photos/lscan/sets/72157601065523576/ In the video, it really looked like the situation had already deteriorated more than a quarter mile out, and then it just continued to get worse. (And the assumptions which I initially made are now in serious doubt.) That further amplifies a question that I have for Dudley: You mentioned a distinction military and civilain pilots; and I can think of several possible reasons: the civilians pilots are usually older, less experienced in type, and formation flying is not part of their primary occupation--but I suspect that there is something even more basic that I am leaving out. Peter Yes. It's so basic it has a tendency to lose itself in analysis. The military was just as aware as everyone else about the hazzards associated with section landings. Putting multiple airplanes on the same runway landing at the same time has obvious risks. If lead for example blows a tire on the side the trailer is landing on, the resulting swerve could be a real issue. Judgment and unforseen incursions on the runway are also considerations. The list of possible issues is indeed long and filled with pot holes that could spoil your day. The military however has a problem we as civilians don't have. They have a situation that involves time. In combat, there is always the issue of getting multiple aircraft on the ground quickly and turned around, rearmed and refueled and back into the air again. Also, there is the issue of vulnerability. Fighters slowed down to pattern speeds and dirty are duck soup for attacking enemy fighters. For the reasons I've stated above, the 360 overhead approach was initiated by the military. The objective of this type of approach is to space close in and tight, keep the pattern speeds up, and get the birds down as quickly as possible. Section landings became an integral part of this scenario and was accepted and is accepted even today as a reasonable risk factor considering extensive flight training and awareness of the pilots doing this work. It is worthy of note that even in the military, landing prop tailwheel fighters this way was considered a far greater risk factor than landing high performance nose wheel jet fighters; the reason being the loss of visual cues for the wingman landing next to his element lead. Now enter civilians with a few bucks and flying P51 Mustangs and you have a situation where the time factor is no longer present in the section landing equation. The powers that be who set up training schedules for these pilots in these aircraft know quite well the dangers of section landings in prop fighters. For this reason, organizations like Warbirds of America and EAA and the T34 Formation Training Syllabus specifically note that section landings in P51's are NOT considered to be safe enough to warrant the risk factor. So this is basically how it works. If you own a P51 and you have taken the trouble to seek out and take the suggested training given by people who know what they are doing, you don't attempt section landings in P51 aircraft. There is no law however that MAKES the P51 owner attend these classes. The result I believe, we have seen with this latest accident at Oshkosh. Both of these pilots were good sticks in these airplanes. It saddens me to know that this accident was so damn preventable simply by following basic information and training readily available for pilots flying P51 Mustangs, and in play as we speak. Dudley Henriques |
Hi John;
That approach is what we called a 360 Tactical overhead approach. I used a variation of it as a finishing touch on my demonstration in the 51 and also on arrival at a show site weather and ATC permitting :-) I used 300 at 46 and 27 and pitched off the deck into a straight 45 climb line roll set. Neutralizing, I immediately initiated a 270 degree roll to the opposite side of the downwind leg (pattern left/roll right) I stopped the roll at 270 by stomping on the top rudder and holding in firm forward stick. This stopped the airplane at the second knife edge solidly. At that point I blended in back pressure using top rudder to hold nose position through the transition from climbing knife edge into the turn to downwind at 1500 feet AGL. The rest was your standard circling close in turning approach in the 51 keeping the power up so as not to foul the plugs. If this approach was done just right, it was beautiful to watch from the ground and was extremely good for maintaining visual cues in the cockpit for me. Once I had things slowed down to 160 and had 20 degrees of flap and the gear lights on the bird, the rest was just keeping it in close and turning milking in the flaps until full down on final. Over the fence at 120 or a bit less and tail low on the mains. The main thing crowds liked with this approach aside from the roll was the sound you always got with the 51 low, fast, and at METO. Dudley Henriques Big John wrote: Dudley Our pilots used to catch the German fighters (and jets) in pattern and run their score up. Shooting fish in a barrel. Never flew an overhead pattern until after the War that I can remember. The pitch off the deck was the procedure used until after War and the accident rate doing that became excessive and they changed to the overhead. An off the deck pitch let you make a touch down after about only 15 seconds from the pitch 350 mph on approach. Throttle idle on pitch and pull up TIGHT in turn to bleed off airspeed. After 180 degrees of climbing turn your airspeed was down to where you could put down full flaps and drop gear, continuing the last 180 degrees of turn to align with runway and then touch down at normal touch down speed. A pitch up almost killed me. Came back to base just after take off with a leaking fuel cap. Made the normal tight pitch up (forgot I was heavy with fuel) and bird stalled in last 90 degrees of turn. I rudder walked the bird down and hit on right main gear and right aileron. Took around and was much more cautious next landing. If I haven't been a good and LUCKY pilot would not be here today ![]() Nice dry day here in Houston today. Big John ******************************************* On Tue, 31 Jul 2007 11:24:02 -0400, Dudley Henriques wrote: Peter Dohm wrote: wrote in message . net... Here's a good set of photos of the accident showing a different perspective than the video we've seen. Scott Wilson http://flickr.com/photos/lscan/sets/72157601065523576/ In the video, it really looked like the situation had already deteriorated more than a quarter mile out, and then it just continued to get worse. (And the assumptions which I initially made are now in serious doubt.) That further amplifies a question that I have for Dudley: You mentioned a distinction military and civilain pilots; and I can think of several possible reasons: the civilians pilots are usually older, less experienced in type, and formation flying is not part of their primary occupation--but I suspect that there is something even more basic that I am leaving out. Peter Yes. It's so basic it has a tendency to lose itself in analysis. The military was just as aware as everyone else about the hazzards associated with section landings. Putting multiple airplanes on the same runway landing at the same time has obvious risks. If lead for example blows a tire on the side the trailer is landing on, the resulting swerve could be a real issue. Judgment and unforseen incursions on the runway are also considerations. The list of possible issues is indeed long and filled with pot holes that could spoil your day. The military however has a problem we as civilians don't have. They have a situation that involves time. In combat, there is always the issue of getting multiple aircraft on the ground quickly and turned around, rearmed and refueled and back into the air again. Also, there is the issue of vulnerability. Fighters slowed down to pattern speeds and dirty are duck soup for attacking enemy fighters. For the reasons I've stated above, the 360 overhead approach was initiated by the military. The objective of this type of approach is to space close in and tight, keep the pattern speeds up, and get the birds down as quickly as possible. Section landings became an integral part of this scenario and was accepted and is accepted even today as a reasonable risk factor considering extensive flight training and awareness of the pilots doing this work. It is worthy of note that even in the military, landing prop tailwheel fighters this way was considered a far greater risk factor than landing high performance nose wheel jet fighters; the reason being the loss of visual cues for the wingman landing next to his element lead. Now enter civilians with a few bucks and flying P51 Mustangs and you have a situation where the time factor is no longer present in the section landing equation. The powers that be who set up training schedules for these pilots in these aircraft know quite well the dangers of section landings in prop fighters. For this reason, organizations like Warbirds of America and EAA and the T34 Formation Training Syllabus specifically note that section landings in P51's are NOT considered to be safe enough to warrant the risk factor. So this is basically how it works. If you own a P51 and you have taken the trouble to seek out and take the suggested training given by people who know what they are doing, you don't attempt section landings in P51 aircraft. There is no law however that MAKES the P51 owner attend these classes. The result I believe, we have seen with this latest accident at Oshkosh. Both of these pilots were good sticks in these airplanes. It saddens me to know that this accident was so damn preventable simply by following basic information and training readily available for pilots flying P51 Mustangs, and in play as we speak. Dudley Henriques |
Dudley
OK show off ![]() We used between 300-350 mph as that was a good increase from our cruise speed of 230-240. The Merlin at METO was certainly a sweet sound ![]() Starting off the deck we probably got back up to 500-600 feet max in pattern. Of course we were not trying to put on an airshow. Lots of things you could do in bird to impress the 'great unwashed masses' ![]() The thing I missed most was the "plop, plop, plop" of the Merlin at idle in pattern before they stopped the full idle because it was sucking cold air in and warping the valves. Looking at the clip many more times you can see #2 angling in toward #1 well prior to contact. Only way I can see that happening is that #2 lost sight of #1. Transmissions will help NTSB sort that out. I'm going to quit making surmises based on part of the data. The more I look at clip the more I see that could be the root cause. Think we have pretty well covered the basic P-51 flying. Am sure yours was light and the ones I flew were heavier, always with ammo, full fuel, etc. If I were doing an airshow I'd not put any fuel in fuselage tank to keep the CG within proper limits and not have to burn tank down. Could do more with a light bird vs a heavy one. Hope your health is progressing in good shape. I started Omega 3, on my own, for my heart and I got so dizzy I could hardly walk. Stopped yesterday and feel much better today. The very best. Big John ************************************************** ****** On Tue, 31 Jul 2007 17:45:21 -0400, Dudley Henriques wrote: Hi John; That approach is what we called a 360 Tactical overhead approach. I used a variation of it as a finishing touch on my demonstration in the 51 and also on arrival at a show site weather and ATC permitting :-) I used 300 at 46 and 27 and pitched off the deck into a straight 45 climb line roll set. Neutralizing, I immediately initiated a 270 degree roll to the opposite side of the downwind leg (pattern left/roll right) I stopped the roll at 270 by stomping on the top rudder and holding in firm forward stick. This stopped the airplane at the second knife edge solidly. At that point I blended in back pressure using top rudder to hold nose position through the transition from climbing knife edge into the turn to downwind at 1500 feet AGL. The rest was your standard circling close in turning approach in the 51 keeping the power up so as not to foul the plugs. If this approach was done just right, it was beautiful to watch from the ground and was extremely good for maintaining visual cues in the cockpit for me. Once I had things slowed down to 160 and had 20 degrees of flap and the gear lights on the bird, the rest was just keeping it in close and turning milking in the flaps until full down on final. Over the fence at 120 or a bit less and tail low on the mains. The main thing crowds liked with this approach aside from the roll was the sound you always got with the 51 low, fast, and at METO. Dudley Henriques ----clip---- |
Health is hanging in there John; the back is a mess and I'm adjusting to
cataract surgery changes but aside from that I'm still able to put one foot in front of the other :-) You're right; my bird was lighter. I had no fuselage tank in the airplane and tried as well to have the fuel in the mains balanced out at about 50 gals maximum for demonstration work. If I was heavy I had to compensate for that naturally. I agree. We've beaten the 51 issue to death on what data is available. I've looked at another angle of the crash and I totally agree with you that the A slanted in and hit the D with the prop through the corner of the stabilizer and sliced it nearly in half behind the cockpit. The violent snap of the A at impact had to be a combination of control input reflex and some extremely strong physical forces caused by the prop impacting the D. Anyway, as you say, even old hands like us are just guessing. The final report will include the radio transmissions and that should fill in a lot of blanks. Take care. I'm glad you're hanging in health wise. Remember, to stay young, "Climb High" "Fly Fast" :-) Dudley Big John wrote: Dudley OK show off ![]() We used between 300-350 mph as that was a good increase from our cruise speed of 230-240. The Merlin at METO was certainly a sweet sound ![]() Starting off the deck we probably got back up to 500-600 feet max in pattern. Of course we were not trying to put on an airshow. Lots of things you could do in bird to impress the 'great unwashed masses' ![]() The thing I missed most was the "plop, plop, plop" of the Merlin at idle in pattern before they stopped the full idle because it was sucking cold air in and warping the valves. Looking at the clip many more times you can see #2 angling in toward #1 well prior to contact. Only way I can see that happening is that #2 lost sight of #1. Transmissions will help NTSB sort that out. I'm going to quit making surmises based on part of the data. The more I look at clip the more I see that could be the root cause. Think we have pretty well covered the basic P-51 flying. Am sure yours was light and the ones I flew were heavier, always with ammo, full fuel, etc. If I were doing an airshow I'd not put any fuel in fuselage tank to keep the CG within proper limits and not have to burn tank down. Could do more with a light bird vs a heavy one. Hope your health is progressing in good shape. I started Omega 3, on my own, for my heart and I got so dizzy I could hardly walk. Stopped yesterday and feel much better today. The very best. Big John ************************************************** ****** On Tue, 31 Jul 2007 17:45:21 -0400, Dudley Henriques wrote: Hi John; That approach is what we called a 360 Tactical overhead approach. I used a variation of it as a finishing touch on my demonstration in the 51 and also on arrival at a show site weather and ATC permitting :-) I used 300 at 46 and 27 and pitched off the deck into a straight 45 climb line roll set. Neutralizing, I immediately initiated a 270 degree roll to the opposite side of the downwind leg (pattern left/roll right) I stopped the roll at 270 by stomping on the top rudder and holding in firm forward stick. This stopped the airplane at the second knife edge solidly. At that point I blended in back pressure using top rudder to hold nose position through the transition from climbing knife edge into the turn to downwind at 1500 feet AGL. The rest was your standard circling close in turning approach in the 51 keeping the power up so as not to foul the plugs. If this approach was done just right, it was beautiful to watch from the ground and was extremely good for maintaining visual cues in the cockpit for me. Once I had things slowed down to 160 and had 20 degrees of flap and the gear lights on the bird, the rest was just keeping it in close and turning milking in the flaps until full down on final. Over the fence at 120 or a bit less and tail low on the mains. The main thing crowds liked with this approach aside from the roll was the sound you always got with the 51 low, fast, and at METO. Dudley Henriques ----clip---- |
Dudley
My back is also bad. I use "capsaicin", Pepper Juice. I tolerate it well and can add additional applications as I need to control the pain. I use it both at neck and lower back. If you haven't tried and want to send me your mail address at my home e-mail address I'll send you some. It can get warm like jock strap lotion. My catract surgery is also giving me problems. Couple of months ago said come back in 3 months. Want to get some decent eyes (20-10) back to fly. Take care. John ************************************************** * On Wed, 01 Aug 2007 10:48:55 -0400, Dudley Henriques wrote: Health is hanging in there John; the back is a mess and I'm adjusting to cataract surgery changes but aside from that I'm still able to put one foot in front of the other :-) You're right; my bird was lighter. I had no fuselage tank in the airplane and tried as well to have the fuel in the mains balanced out at about 50 gals maximum for demonstration work. If I was heavy I had to compensate for that naturally. I agree. We've beaten the 51 issue to death on what data is available. I've looked at another angle of the crash and I totally agree with you that the A slanted in and hit the D with the prop through the corner of the stabilizer and sliced it nearly in half behind the cockpit. The violent snap of the A at impact had to be a combination of control input reflex and some extremely strong physical forces caused by the prop impacting the D. Anyway, as you say, even old hands like us are just guessing. The final report will include the radio transmissions and that should fill in a lot of blanks. Take care. I'm glad you're hanging in health wise. Remember, to stay young, "Climb High" "Fly Fast" :-) Dudley Big John wrote: Dudley OK show off ![]() We used between 300-350 mph as that was a good increase from our cruise speed of 230-240. The Merlin at METO was certainly a sweet sound ![]() Starting off the deck we probably got back up to 500-600 feet max in pattern. Of course we were not trying to put on an airshow. Lots of things you could do in bird to impress the 'great unwashed masses' ![]() The thing I missed most was the "plop, plop, plop" of the Merlin at idle in pattern before they stopped the full idle because it was sucking cold air in and warping the valves. Looking at the clip many more times you can see #2 angling in toward #1 well prior to contact. Only way I can see that happening is that #2 lost sight of #1. Transmissions will help NTSB sort that out. I'm going to quit making surmises based on part of the data. The more I look at clip the more I see that could be the root cause. Think we have pretty well covered the basic P-51 flying. Am sure yours was light and the ones I flew were heavier, always with ammo, full fuel, etc. If I were doing an airshow I'd not put any fuel in fuselage tank to keep the CG within proper limits and not have to burn tank down. Could do more with a light bird vs a heavy one. Hope your health is progressing in good shape. I started Omega 3, on my own, for my heart and I got so dizzy I could hardly walk. Stopped yesterday and feel much better today. The very best. Big John ************************************************** ****** On Tue, 31 Jul 2007 17:45:21 -0400, Dudley Henriques wrote: Hi John; That approach is what we called a 360 Tactical overhead approach. I used a variation of it as a finishing touch on my demonstration in the 51 and also on arrival at a show site weather and ATC permitting :-) I used 300 at 46 and 27 and pitched off the deck into a straight 45 climb line roll set. Neutralizing, I immediately initiated a 270 degree roll to the opposite side of the downwind leg (pattern left/roll right) I stopped the roll at 270 by stomping on the top rudder and holding in firm forward stick. This stopped the airplane at the second knife edge solidly. At that point I blended in back pressure using top rudder to hold nose position through the transition from climbing knife edge into the turn to downwind at 1500 feet AGL. The rest was your standard circling close in turning approach in the 51 keeping the power up so as not to foul the plugs. If this approach was done just right, it was beautiful to watch from the ground and was extremely good for maintaining visual cues in the cockpit for me. Once I had things slowed down to 160 and had 20 degrees of flap and the gear lights on the bird, the rest was just keeping it in close and turning milking in the flaps until full down on final. Over the fence at 120 or a bit less and tail low on the mains. The main thing crowds liked with this approach aside from the roll was the sound you always got with the 51 low, fast, and at METO. Dudley Henriques ----clip---- |
Gear Up, pt 6 - P-51D from 353rd FG at Raydon has a landing accident.jpg (1/1) | Mitchell Holman | Aviation Photos | 0 | April 19th 07 03:31 AM |
Mustangs of Old, concluded - P-51D from 353rd FG at Raydon has a landing accident.jpg (1/1) | Mitchell Holman | Aviation Photos | 0 | December 30th 06 03:52 AM |
Six aboard USS Kitty Hawk injured in F/A 18 landing accident | Otis Willie | Naval Aviation | 0 | January 31st 05 10:50 PM |
B-17 landing accident today, Van Nuys, Calif. | Paul Hirose | Military Aviation | 21 | May 17th 04 06:07 AM |
C172S Landing accident | Greg Esres | Piloting | 53 | August 4th 03 03:44 PM |
