ANN coverage of the P-51 landing accident at OSH...
Old August 2nd 07, 05:37 AM posted to rec.aviation.piloting
Dudley Henriques[_2_]
Default ANN coverage of the P-51 landing accident at OSH...
Big John wrote:
Dudley
My back is also bad. I use "capsaicin", Pepper Juice. I tolerate it
well and can add additional applications as I need to control the
pain. I use it both at neck and lower back. If you haven't tried and
want to send me your mail address at my home e-mail address I'll send
you some. It can get warm like jock strap lotion.
Many thanks John, but I think my back issues are beyond the medication
stage. They've been my spine 3 times and the result is that I no longer
have the violent attacks of excruciating pain like I used to, but I now
have a low level constant pain in the lower back caused by nerve damage
that can't be repaired or medicated. I could if I chose, use a strong
pain med, but living like a zombie doesn't have much appeal for me, so I
just roll into and out of bed gently, try not to bend down so much, grit
my teeth, and keep on truckin :-)
My catract surgery is also giving me problems. Couple of months ago
said come back in 3 months. Want to get some decent eyes (20-10) back
to fly.
Sorry to hear that John. I sincerely hope that it works out for you.
Mine seems ok so far. I'm getting my new glasses in about a week. The
surgeon said my tests seem normal and I'll have a slight correction at
far range and I'm about 225 for reading up close. Right now on the
computer I'm wearing 150 reading cheapo's and I can see fine.
Dudley
Take care.
John
On Wed, 01 Aug 2007 10:48:55 -0400, Dudley Henriques
Health is hanging in there John; the back is a mess and I'm adjusting to
cataract surgery changes but aside from that I'm still able to put one
foot in front of the other :-)
You're right; my bird was lighter. I had no fuselage tank in the
airplane and tried as well to have the fuel in the mains balanced out at
about 50 gals maximum for demonstration work. If I was heavy I had to
compensate for that naturally.
I agree. We've beaten the 51 issue to death on what data is available.
I've looked at another angle of the crash and I totally agree with you
that the A slanted in and hit the D with the prop through the corner of
the stabilizer and sliced it nearly in half behind the cockpit.
The violent snap of the A at impact had to be a combination of control
input reflex and some extremely strong physical forces caused by the
prop impacting the D.
Anyway, as you say, even old hands like us are just guessing. The final
report will include the radio transmissions and that should fill in a
lot of blanks.
Take care. I'm glad you're hanging in health wise. Remember, to stay
young, "Climb High" "Fly Fast" :-)
Dudley
Big John wrote:
Dudley
OK show off )
We used between 300-350 mph as that was a good increase from our
cruise speed of 230-240. The Merlin at METO was certainly a sweet
sound )
Starting off the deck we probably got back up to 500-600 feet max in
pattern.
Of course we were not trying to put on an airshow. Lots of things you
could do in bird to impress the 'great unwashed masses' )
The thing I missed most was the "plop, plop, plop" of the Merlin at
idle in pattern before they stopped the full idle because it was
sucking cold air in and warping the valves.
Looking at the clip many more times you can see #2 angling in toward
#1 well prior to contact. Only way I can see that happening is that #2
lost sight of #1.
Transmissions will help NTSB sort that out.
I'm going to quit making surmises based on part of the data. The more
I look at clip the more I see that could be the root cause.
Think we have pretty well covered the basic P-51 flying. Am sure yours
was light and the ones I flew were heavier, always with ammo, full
fuel, etc. If I were doing an airshow I'd not put any fuel in fuselage
tank to keep the CG within proper limits and not have to burn tank
down. Could do more with a light bird vs a heavy one.
Hope your health is progressing in good shape. I started Omega 3, on
my own, for my heart and I got so dizzy I could hardly walk. Stopped
yesterday and feel much better today.
The very best.
Big John
On Tue, 31 Jul 2007 17:45:21 -0400, Dudley Henriques
Hi John;
That approach is what we called a 360 Tactical overhead approach. I used
a variation of it as a finishing touch on my demonstration in the 51 and
also on arrival at a show site weather and ATC permitting :-)
I used 300 at 46 and 27 and pitched off the deck into a straight 45
climb line roll set. Neutralizing, I immediately initiated a 270 degree
roll to the opposite side of the downwind leg (pattern left/roll right)
I stopped the roll at 270 by stomping on the top rudder and holding in
firm forward stick. This stopped the airplane at the second knife edge
solidly. At that point I blended in back pressure using top rudder to
hold nose position through the transition from climbing knife edge into
the turn to downwind at 1500 feet AGL. The rest was your standard
circling close in turning approach in the 51 keeping the power up so as
not to foul the plugs.
If this approach was done just right, it was beautiful to watch from the
ground and was extremely good for maintaining visual cues in the cockpit
for me. Once I had things slowed down to 160 and had 20 degrees of flap
and the gear lights on the bird, the rest was just keeping it in close
and turning milking in the flaps until full down on final.
Over the fence at 120 or a bit less and tail low on the mains.
The main thing crowds liked with this approach aside from the roll was
the sound you always got with the 51 low, fast, and at METO.
Dudley Henriques
----clip----
Old August 3rd 07, 03:13 AM posted to rec.aviation.piloting
Big John
Dudley
The wild stories using Capsaisin are not unusual. They package it in
several strengths. I'm using the strongest 0.075 percent.
What I advise the first time users is to start on your arm just above
the wrist, and only apply a little. If you don't have any problems go
ahead and increase the amount and frequency. If it gets hot you can
easily wash it off with soap and water with the other hand.
If you, say, put it on the lower back at the belt level and it is hot
out side where you sweat then you will get the hot burning feeling and
it is hard to reach to get off behind your back.
A War Story. A good model pilot was one armed and had back pains. I
gave him some and he put on before going to bed. It took off and he
had to get his wife up and get in shower with her and scrub his back
like she did normally because of the one arm but at a better time of
day and night )
What I'm told how it works is that it stops the signals from being
sent over nerves from pain area to brain. It does not cure the
underlying problem.
In my case I have become accustomed to it and even working out side in
yard in summer I can stand the heat under the belt and it sure cuts
the problem big time. If you want I'll get a tube of 0.025 (the lowest
they make) and send to you. Need to order some shortly for me and will
be glad for you to give it a try.If it works for you like for me then
you will be home free )
I used to get a grease but found that I had to wash my hands with soap
and water after application. I now have found it in a role on and you
don't get on your hands and eventually into your eyes (
If you are going to go out in sun then don't put on or at least just a
single swipe until you establish your tolerance.
Think you gave me your address prior but for some reason I didn't
save.
Just got a new e-mail address. j*hnc*a*l*atcomcast.net. Use it to keep
some semblance of privacy to your USPS address. Think you know how to
modify to make correct address. Remove *'s and use symbol for at.
On eye's. I had right eye done 6 years ago and it was doing good. when
left eye started growing very dim. Has not turned out as what I
experienced with right.Should get the second new set or glasses this
month and hope they can make both eyes see the same one to another.
The best.
Big John
On Thu, 02 Aug 2007 00:37:43 -0400, Dudley Henriques
Big John wrote:
Dudley
to fly.
Dudley
Take care.
John
lot of blanks.
Dudley
Big John wrote:
Dudley
OK show off )
sound )
pattern.
lost sight of #1.
The very best.
Big John
Hi John;
Dudley Henriques
----clip----
Gear Up, pt 6 - P-51D from 353rd FG at Raydon has a landing accident.jpg (1/1) Mitchell Holman Aviation Photos 0 April 19th 07 03:31 AM
Mustangs of Old, concluded - P-51D from 353rd FG at Raydon has a landing accident.jpg (1/1) Mitchell Holman Aviation Photos 0 December 30th 06 03:52 AM
Six aboard USS Kitty Hawk injured in F/A 18 landing accident Otis Willie Naval Aviation 0 January 31st 05 10:50 PM
B-17 landing accident today, Van Nuys, Calif. Paul Hirose Military Aviation 21 May 17th 04 06:07 AM
C172S Landing accident Greg Esres Piloting 53 August 4th 03 03:44 PM
