430W doubling in cost?
Old August 4th 07, 01:16 AM posted to rec.aviation.owning
Frank Ch. Eigler
Default 430W doubling in cost?
"John T." writes:
Remember that there are likely additional charges to the $1495. A
new antenna to receive the WAAS and possibly a new RF antenna cable
with lower loss will need to be installed.
Indeed. My local avionics shop estimated more like $4000 for the
whole deal.
Much new hardware inside (for whatever that is worth)
Addition of a decent terrain warning map
(That was already available for about 1 AMU as a separate upgrade for
430/530's.)
Much faster updates to track (maybe 5 Hz)
This last one might be of use in IMC with gyro problems.
Dunno. Digital numbers won't be readable at 5 changes per second.
Analog outputs are basically just CDI/VDI's, whose super-rapid updates
may help only during the tail end of an approach.
- FChE
Old August 16th 07, 06:09 PM posted to rec.aviation.owning
Andrew Gideon
On Fri, 03 Aug 2007 20:16:54 -0400, Frank Ch. Eigler wrote:
Indeed. My local avionics shop estimated more like $4000 for the whole
deal.
I was just quoted an expected maximum of $2500 (including the $1500 to
Garmin) per radio from my local shop.
Addition of a
That same shop told me that terrain is *not* a part of the W upgrade,
though still remains an available add-on.
Much faster updates to track (maybe 5 Hz) This last one might be of use
I think, if one is using track as a replacement for a failed DG for
example, that 5 updates a second would be quite manageable. A second
is a long time, in that sense. Say "Mississippi", for example, while
tapping your finger five times. Once you get the rhythm, it's not tough.
But I've not tried actually reading a display like this.
Also, consider that if you're spinning so fast that the ones digit is
illegible, you can still see the direction of your spin with the tens
digit. That's enough to slow the turn so as to render the ones digit
usable again (plus provide for some other benefits {8^).
- Andrew
Garmin 430W holding help? Paul kgyy Piloting 1 April 10th 07 11:36 PM
XM Wx Garmin 430/430W with Garmin GDL-69? [email protected] Instrument Flight Rules 4 March 5th 07 03:52 AM
Garmin 430W/530W first impressions Viperdoc[_4_] Instrument Flight Rules 9 February 27th 07 02:10 AM
GNS 430W vs GNS 480 Ron Gordon Instrument Flight Rules 66 January 4th 07 06:45 PM
FBO (Mercury Air) doubling hanger rent to run off GA at BHM.......is this legal? TripFarmer Owning 37 August 11th 03 05:31 AM
