Ron Wanttaja wrote:
On Sun, 05 Aug 2007 10:27:25 -0700, quietguy wrote: Building to the plans doesn't guarantee accurate static pressure readings; the system is quite sensitive to tiny plane-to-plane variations. And the official calibration check with the airplane stationary wouldn't catch an in-flight static-pressure error. Yes, but: If the encoder and the altimeter are using the same static source, both should be in error the same amount. Kyle's problem is a split indication; the encoder is sensing a different altitude than the altimeter. This tends to argue that the problem is a leak related to the altimeter itself, not in the static system. Perhaps the altimeter has a leak that only manifests itself when it's being vibrated (i.e., the engine running). My Microair transponder gives me a readout of the altitude that's being sent to ATC. I can set the A/C altimeter to 29.92 and compare. That's how I discovered my encoder had gone south two months back; the altitude readout wasn't matching the altimeter. Ron Wanttaja Are your transponder and altimeter physically close to each other? (How far apart could they be in a Fly Baby??) In larger planes it's not uncommon for the encoder to be mounted behind the seats or such. Quite far from the altimeter - with a lot of extra hose between them. Just a thought... Richard |
Maybe some friction/hysteresis in the altimeter not showing up during the
altimiter check, but not likely. Maybe some strange internal pressure/vacuum in the cockpit in flight combined with a leaking static system, but you passed the static test you say. You should try and tie it down to which, if either, is right and wrong. Does the altimeter indicate field altitude when you set the Kollsman window to the ATIS altimeter setting? One way to get a pretty good altitude check if you can fly the glideslope with accuracy and if the plane is so equiped is to pass over the outer maker with the GS needle dead nuts centered and compare the crossing altitude with what is indicated on the approach plate. "Kyle Boatright" wrote in message ... I was using Flight Following yesterday and was reminded of a problem that my RV has displayed for a long time: The transponder and altimeter do not agree. In general, ATC sees my altitude as about 200' lower than what is shown on my altimeter. A couple of facts: - The transponder/encoder always pass their certification checks. - The pitot/static system is installed per plans. Any thoughts? KB |
![]() "Kyle Boatright" wrote in message ... I was using Flight Following yesterday and was reminded of a problem that my RV has displayed for a long time: The transponder and altimeter do not agree. In general, ATC sees my altitude as about 200' lower than what is shown on my altimeter. A couple of facts: - The transponder/encoder always pass their certification checks. - The pitot/static system is installed per plans. Any thoughts? KB An update on this thread... There are no apparent loose hoses, etc between the altimeter and encoder which would explain a discrepancy between the two. Also, the altimeter is 30' off (it reads low) on the ground which is well within limits. This 30' low reading is consistent in flight (to the best of my ability to gauge it during a low pass). Presumably, this means the encoder needs to be adjusted. Other thoughts? Oh, and by the way, climbing under the panel of an RV-6 to check this stuff ain't no fun... KB |
Kyle Boatright wrote:
"Kyle Boatright" wrote in message ... I was using Flight Following yesterday and was reminded of a problem that my RV has displayed for a long time: The transponder and altimeter do not agree. In general, ATC sees my altitude as about 200' lower than what is shown on my altimeter. A couple of facts: - The transponder/encoder always pass their certification checks. - The pitot/static system is installed per plans. Any thoughts? KB An update on this thread... There are no apparent loose hoses, etc between the altimeter and encoder which would explain a discrepancy between the two. Also, the altimeter is 30' off (it reads low) on the ground which is well within limits. This 30' low reading is consistent in flight (to the best of my ability to gauge it during a low pass). Presumably, this means the encoder needs to be adjusted. Other thoughts? Oh, and by the way, climbing under the panel of an RV-6 to check this stuff ain't no fun... KB At a minimum you need to have your altimeter and encoder correlated/adjusted by somebody rated to do that. In the mean time, turn off the alt reporting at the transponder. The adjustment can't be done without the proper equipment, sorry. The next question is why did the encoder drift off by so much and will it do it again? Since it's drifted that much, it might be worthwhile to get a new encoder. They're pretty cheap. The altimeter can only be legally adjusted by a certified repair station. It's a good idea to make sure the altimeter is accurate when a new encoder is installed. Dave www.craigmileaviation.com |
"Dave" wrote in message
... The altimeter can only be legally adjusted by a certified repair station. It's a good idea to make sure the altimeter is accurate when a new encoder is installed. Hmmm ........ Lessee. I'm just working off the cuff here, but if an altimeter isn't even a required piece of equipment, why would the above statement be true? In an experimental aircraft, couldn't I use a barometer and a wet string if I wanted? Rich (ducking and hiding) S. |
On Sat, 11 Aug 2007 15:47:46 -0700, "Rich S."
wrote: "Dave" wrote in message ... The altimeter can only be legally adjusted by a certified repair station. It's a good idea to make sure the altimeter is accurate when a new encoder is installed. Hmmm ........ Lessee. I'm just working off the cuff here, but if an altimeter isn't even a required piece of equipment, why would the above statement be true? In an experimental aircraft, couldn't I use a barometer and a wet string if I wanted? Actually, an altimeter *is* required for VFR. It's just that a "sensitive altimeter adjustable for barometric pressure" isn't required unless you're going IFR. That keeps all the one-armed Cub altimeters legal.... Ron Wanttaja |
"Ron Wanttaja" wrote in message
... Actually, an altimeter *is* required for VFR. It's just that a "sensitive altimeter adjustable for barometric pressure" isn't required unless you're going IFR. That keeps all the one-armed Cub altimeters legal.... So the barometer and wet string is okay? Rich ![]() |
On Sun, 5 Aug 2007 12:40:36 -0400, "Kyle Boatright"
wrote: I was using Flight Following yesterday and was reminded of a problem that my RV has displayed for a long time: The transponder and altimeter do not agree. In general, ATC sees my altitude as about 200' lower than what is shown on my altimeter. A couple of facts: - The transponder/encoder always pass their certification checks. - The pitot/static system is installed per plans. Any thoughts? Try it at a controled airport. Get an altimeter check while stationary. Make a low pass and get another to see how they vary. KB |
Connecting hoses to pitot/static tubes | Ernest Christley | Home Built | 9 | October 23rd 06 01:44 PM |
Pitot Static 411 413 followup post | A Lieberman | Owning | 12 | June 18th 05 04:00 PM |
Sharing static and pitot line | Istvan Csonka | Soaring | 13 | March 12th 05 03:00 AM |
pitot/static location | Ray Toews | Home Built | 2 | December 30th 03 12:52 AM |
Pitot and static couplings for a TTU-205 | B2431 | Home Built | 0 | August 15th 03 07:25 AM |
