props: tractor v pusher, q tip, ducted?
Old August 7th 07, 04:35 AM posted to rec.aviation.piloting
Charles Talleyrand
Default props: tractor v pusher, q tip, ducted?
On Aug 5, 11:46 pm, Bertie the Bunyip wrote:
That's for the early airplanes regarding the Skymasters. the loss was in
cooling drag, which Cessna improved. After that the SE ceiling cruise
and climb were virtually identical, but the reputation the rear engine
had for better SE performance never went away..
How can that be? The engine cowling has the same openings wether the
engine is turning or not. In other words, whatever the drag of the
front engine cowling, it should be the same whether the engine is
turning or not.
I'm assuming that the propeller does not effect airflow tooooo much
near the root, where it spins slowly and has a less aerodynamic shape
than near the tip, where most thrust is generated.
Old August 7th 07, 01:34 PM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Charles Talleyrand wrote in
ups.com:
in
engine
It doesn't
Same openings, different drag profile with the engines running.
In any case, it's a fact that the later Skymasters had virtually the
same performance with either engine out.
turning or not.
It isn't.
The drag is induced by the cooling itself.
Bertie.
Old August 8th 07, 01:49 AM posted to rec.aviation.piloting
Charles Talleyrand
How can the drag be induced by the cooling itself? If I understand
you, the same cowling with the same air flow shows significantly
different drag depending on whether the engine inside is hot or cold.
I honestly don't understand that.
Old August 8th 07, 03:37 AM posted to rec.aviation.piloting
Morgans[_2_]
"Charles Talleyrand" wrote in message
The air entering the engine compartment, and flowing past the running
engine's hot cooling fins expands at LEAST double.
That is why the exit opening is much larger than the intake.
That is why there have been claims that the P-51 has a positive cooling
drag, that is the heated air exiting actually gives more thrust than the
drag of air entering the radiator passage and going past the radiator.
Jim in NC
Old August 8th 07, 04:33 AM posted to rec.aviation.piloting
Kyle Boatright
"Morgans" wrote in message
Jim in NC
Double? Naah. It expands, but doesn't double. Boyle's law (PV=NRT) is
based on absolute temperature, which is measured in kelvin. Kelvin is
Celsius plus 273 degrees. Guessing now, if the air temp went from 300k to
350k (or about 80F/27C to about 160F/70C) you'd see volume increase by
(350/300 -1) = 1/6th = about 17%...
KB
Old August 8th 07, 06:29 AM posted to rec.aviation.piloting
"Kyle Boatright" wrote in
cold.
cooling drag, that is the heated air exiting actually gives more
thrust than the drag of air entering the radiator passage and going
past the radiator. --
Jim in NC
is based on absolute temperature, which is measured in kelvin. Kelvin
is Celsius plus 273 degrees. Guessing now, if the air temp went from
300k to 350k (or about 80F/27C to about 160F/70C) you'd see volume
increase by (350/300 -1) = 1/6th = about 17%...
KB
It's certainly standard practice, at least on airplanes where min
cooling drag is desired, that the outlet be conderably larger than the
inlet...
Bertie
Old August 8th 07, 08:25 AM posted to rec.aviation.piloting
Morgans[_2_]
OK. I have always heard the approximate rule for good cooling is double the
intake size for the exit size. Guess it doesn't transfer to expansion.
Jim in NC
Old August 8th 07, 04:57 PM posted to rec.aviation.piloting
Danny Deger
the intake size for the exit size. Guess it doesn't transfer to
expansion.
Maybe the velocity of the exit gasses are less. This would cause them to
need more area.
Danny Deger
Old August 8th 07, 07:06 PM posted to rec.aviation.piloting
Jon Woellhaf
expansion.
Did you mean to write, "... double the exit size for the intake size?" If
not, you lost me.
Old August 9th 07, 01:08 AM posted to rec.aviation.piloting
Danny Deger
expansion.
Thanks for the info on the air expanding. Does this translate into more
drag if the engine is running?
Danny Deger
monitoring pusher props Ernest Christley Home Built 11 May 17th 06 12:53 AM
Pusher props for WW I fighters John Bailey Military Aviation 3 September 11th 04 11:18 AM
Interested in Tractor vs. Pusher Gyroplane Dunewood Truglia, Esq. Rotorcraft 1 July 2nd 04 05:26 PM
1/2 VW and a shrouded/ducted propeller? BllFs6 Home Built 9 May 6th 04 06:33 AM
Ducted Fan Design David Home Built 5 February 7th 04 07:15 AM
