Electrically Powered Ultralight Aircraft
Old August 7th 07, 03:21 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Larry Dighera
Default Electrically Powered Ultralight Aircraft
On Mon, 06 Aug 2007 18:22:41 -0700, James Sleeman
wrote in
.com:
On Aug 7, 3:39 am, Larry Dighera wrote:
Are external combustion engines as efficient as internal combustion
engines? Stirling engines are great for converting waste heat to
mechanical energy, but I'm not sure how appropriate they would be for
aircraft propulsion.
In theory, I think that stirling engines are quite well suited to
aircraft, all it needs is a source of "hot" and a source of "cold",
the cold is in abundance (stick a heatsink in the wind, higher you go,
colder it gets, more power the engine can deliver, directly the
opposite of IC), the hot could be provided with any number of
combustables (and some oxygen delivery system).
I see what you mean. Unfortunately, the highest power requirements of
aircraft engines are during the takeoff and climb phases of flight.
Power requirements are even greater when the ambient temperature rises
resulting in less air density or a higher density altitude. That is
when the most power is required for takeoff, but that would be a
situation where the Stirling engine would have its minimum power
production.
I would also like to see a comparison of the efficiencies of IC and EC
engines and their relative weight and size per horsepower compared.
Unlike electrical motors, that must be constructed with heavy iron, IC
and EC engines can be constructed of lighter materials like aluminum,
but electrical motors are usually 80% to 95% efficient. With the
Stirling aircraft engine there is a requirement for what I would
imagine would be a large heat sink or heat exchanger located in the
slip stream. The weight of this heat exchanger and its drag penalty
must also be considered.
I found yesterday after writing my initial post an article about
exactly this - http://www.qrmc.com/fourpartstirling.html "Why Aviation
Needs the Stirling Engine by Darryl Phillips" from 1993/1994.
Given what was said in the article, I'm kind of surprised that nobody
has come up with a working protoype actually.
The article is interesting; thank you for mentioning it. I am
e-mailing a copy of this followup article to the author Darryl
Phillips.
There might be one advantage to using Sterling external combustion
engines for aviation: the use of atomic energy as a fuel source if the
weight of the lead shielding were not too great. Imagine an aircraft
that effectively never runs out of fuel! There'd be no more fuel
exhaustion mishaps.
Old August 7th 07, 05:48 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Neil Gould
Recently, Larry Dighera posted:
wrote in
.com:
for aircraft propulsion.
go, colder it gets, more power the engine can deliver, directly the
production.
If an engine's minimum power production is greater than the power required
for takeoff, would it matter? It would seem that if this could be
achieved, the operating conditions of the Stirling engine would be mostly
understressed.
Why couldn't the heat exchanger be an integral part of the airframe? Wings
come to mind... ;-)
exhaustion mishaps.
One downside would be the hazardous materials that could be dispersed in a
crash. I'd like to see a prototype Stirling using conventional fuels
before exploring more exotic options.
Neil
Old August 7th 07, 06:08 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Larry Dighera
On Tue, 7 Aug 2007 11:48:50 -0500, "Neil Gould"
wrote in
[snip]
production.
Probably not, but it would mean you'd have significantly more power
available at altitude if the Sterling engine were sized to provide
takeoff power at high density altitudes.
What I was getting at was the author of the articles emphasis on
overcoming the reduced power output of IC engines at lower atmospheric
pressure overlooks its possibly anemic performance (due to minimal air
movement through the heat exchanger and higher ambient temperatures on
the ground) when it is needed most, at takeoff. I find it revealing
that the author failed to mention that point, and it reduces my
confidence in the assertions he made in that article.
It would seem that if this could be achieved, the operating conditions
of the Stirling engine would be mostly understressed.
I am unable to infer your meaning by that statement. Do you mean
under emphasized or less mechanical stress on the engine, or what?
come to mind... ;-)
I'm thinking there would be necessity for some means of conducting the
heat from the engine to a remote heat exchanger, and the resulting
complexity and weight increase would negatively impact the potential
advantages of a Stirling aviation engine. In any event, in addition
to the Stirling engine and its fuel, a heat exchanger of some type
needs to factored into the weight, cost, performance, and efficiency
equations.
exhaustion mishaps.
crash.
There are a lot of down sides to atomic power, but NASA uses it to
power Stirling engines in space.
Here's some information about what NASA successfully has accomplished
with nuclear power:
http://www.grc.nasa.gov/WWW/tmsb/index.html
The Thermo-Mechanical Systems Branch (5490) is responsible for
planning, conducting and directing research and technology
development to advance the state-of-the-art in a variety of
thermal systems for space, aerospace, as well as non-aerospace
applications. The systems of interest include thermal energy
conversion for power systems and solar thermal propulsion systems.
The effort involves working at the component level to develop the
technology, the subsystem level to verify the performance of the
technology, and the system level to ensure that the appropriate
system level impact is achieved with the integrated technology.
System analysis is used to identify high-impact technology areas,
define the critical aspects of the technology that need to be
developed, and characterize the system level impact of the
technology. Specific technology areas of interest include:
Dynamic Power Systems: Brayton, Rankine and Stirling Convertors,
Solar Receivers and Thermal Energy Storage
Primary Solar Concentrators: Thin film, SRP and Rigid
Secondary Solar Concentrators: Refractive and Reflective
Thermal Management: Radiators, Electronics Packaging, and Heat
Pipe Technology
http://www.grc.nasa.gov/WWW/tmsb/stirling.html
Animation of a 55 We Stirling TDC
(click on image to view)
http://www.grc.nasa.gov/WWW/tmsb/sti...adisotope.html
AVAILABLE TODAY FOR TOMORROW'S NEEDS
NASA Glenn Research Center and the Department of Energy (DOE) are
developing a Stirling convertor for an advanced radioisotope power
system to provide spacecraft on-board electric power for NASA deep
space missions. Stirling is being evaluated as an alternative to
replace Radioisotope Thermoelectric Generators (RTGs) with a
high-efficiency power source. The efficiency of the Stirling
system, in excess of 20%, will reduce the necessary isotope
inventory by a factor of at least 3 compared to RTGs. Stirling is
the most developed convertor option of the advanced power concepts
under consideration [1,2].
http://www.grc.nasa.gov/WWW/tmsb/sti...ng_bckgrd.html
However, about this time NASA became interested in development of
free-piston Stirling engines for space power applications. These
engines use helium as the working fluid, drive linear alternators
to produce electricity and are hermetically sealed. These 12.5 kWe
per cylinder engines were intended for use with a nuclear reactor
power system; the Space Demonstrator Engine (or SPDE) was the
earliest 12.5 kWe per cylinder engine that was designed, built and
tested by MTI. A later engine of this size, the Component Test
Power Convertor (or CTPC), used a "Starfish" heat-pipe heater
head, instead of the pumped-loop used by the SPDE. Recently, in
the 1992-93 time period, this work was terminated due to the
termination of the related SP-100 nuclear power system work and
NASA's new emphasis on "better, faster, cheaper" systems and
missions.
http://www.spacedaily.com/news/outerplanets-00a2.html
Europa Orbiter was replanned to use a new "Sterling" nuclear
generator design which would use less plutonium
http://www.cndyorks.gn.apc.org/yspac...heed_offer.htm
Boeing, Lockheed Offer NASA Two Choices for Nuclear Power
Old August 7th 07, 06:51 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Neil Gould
[snip]
of aircraft engines are during the takeoff and climb phases of
flight. Power requirements are even greater when the ambient
temperature rises resulting in less air density or a higher density
altitude. That is when the most power is required for takeoff, but
that would be a situation where the Stirling engine would have its
minimum power production.
required for takeoff, would it matter?
Exactly, but I don't see that as a negative... ;-)
I understand your perspective, which is what prompted my reply. If there
is sufficient power to take off, then the issue should be moot, unless I'm
overlooking something. It should be reasonable to presume that any
practical aircraft engine would have sufficient power to take off, right?
conditions of the Stirling engine would be mostly understressed.
Less mechanical stress due to operating well below maximum power settings
under normal cruise. That should provide plenty of reserve power at
altitude and increase the fuel efficiency as well.
EC engines and their relative weight and size per horsepower
compared.
IC and EC engines can be constructed of lighter materials like
aluminum, but electrical motors are usually 80% to 95% efficient.
With the Stirling aircraft engine there is a requirement for what I
would imagine would be a large heat sink or heat exchanger located
in the slip stream. The weight of this heat exchanger and its drag
penalty must also be considered.
Wings come to mind... ;-)
equations.
Of course, but I don't see a lot of reason why that couldn't be
incorporated into the overall design. My point is that heat exchangers
need not be heavy, and could probably double as structural and/or
aerodynamic components, further reducing (and possibly enhancing) their
impact.
the weight of the lead shielding were not too great. Imagine an
aircraft that effectively never runs out of fuel! There'd be no
more fuel exhaustion mishaps.
dispersed in a crash.
Understandable, but their expectation is that catastrophic destruction
would disperse the nuclear material harmlessly. That can't be presumed for
light aircraft.
Neil
Old August 8th 07, 08:37 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Larry Dighera
On Tue, 07 Aug 2007 17:51:27 GMT, "Neil Gould"
wrote in
equations.
impact.
How would you get the heat from the Stirling engine to the heat sink?
If you use liquid coolant, it would be heavy and prone to leaks.
light aircraft.
If the rocket detonated in the atmosphere, it might not be so
harmless. I would guess the reactor is jacketed with sufficient
strength to preclude its destruction. Presumably, that could be done
for a Stirling aircraft engine also.
Old August 9th 07, 02:25 AM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Neil Gould
wrote in
the heat from the engine to a remote heat exchanger, and the
resulting complexity and weight increase would negatively impact
the potential advantages of a Stirling aviation engine. In any
event, in addition to the Stirling engine and its fuel, a heat
exchanger of some type needs to factored into the weight, cost,
performance, and efficiency equations.
exchangers need not be heavy, and could probably double as
structural and/or aerodynamic components, further reducing (and
possibly enhancing) their impact.
I'm not a Stirling engine designer, so I can't answer that factually. I
have been reading up on it a bit since the article was referenced in this
thread, but I haven't seen such things as the required rate of dissipation
for the engine to work efficiently. If the heat sink needs to be large and
close to the engine, perhaps a design where the engine is mounted on or
even incorporated into the wing is a way to go.
destruction would disperse the nuclear material harmlessly. That
can't be presumed for light aircraft.
harmless.
I don't see why it would be nearly as bad as a "dirty bomb" would be, as
the material would be dispersed over a pretty large area.
My guess is that NASA et al are just hoping for good fortune. Having a
reactor land from orbit intact in the middle of a city wouldn't be all
that desirable. ;-) So, my bet is on there being no good plan for
dealing with such a catastrophe *other* than wide dispersal of the nuclear
material or the luck of landing in the ocean. Not that *that* outcome is
desirable either...
Neil
Old August 8th 07, 05:42 AM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
James Sleeman
Hence why i was thinking more along the lines of a electric motor +
reasonable battery coupled to a stirling. The battery provides the
oompfh for takeoff (and other moments of urgency) from stored energy.
The stirling charges the battery, or passes current through to the
motor when the battery is at peak charge (hand waving the bajillion
technical details which I don't know), it doesn't matter that the
stirling doesn't run at peak efficiency at all times, in cruise mode
you'd want it to be at peak and providing more than enough current to
the motor with some spare to charge the battery.
The article I linked to was more along the lines of a direct-drive,
but I think hooking the output shaft from a stirling straight to a
gearbox/prop would not be a good idea, you are stuck with too many
disadvantages and it makes the engine design more complicated than
necessary.
The main advantage of the stirling+battery versus just battery, is
that you remove the requirement for major infrastructure change
(abundant charging points at airports), the stirling just needs some
fuel (which could be anything from mogas to radiant solar heat) and
that's it, no infrastructure change is necessary in the interim, and
minimal in the long term. As an added benefit, you get much better
cruise endurance than battery alone.
Electrically Powered Ultralight Aircraft Larry Dighera Piloting 178 December 31st 07 08:53 PM
Electrically Powered Ultralight Aircraft Larry Dighera Home Built 191 August 21st 07 12:29 AM
World's First Certified Electrically Propelled Aircraft? Larry Dighera Piloting 2 September 22nd 06 01:50 AM
Powered gliders = powered aircraft for 91.205 Mark James Boyd Soaring 2 December 12th 04 03:28 AM
Help! 2motors propelled ultralight aircraft [email protected] Home Built 3 July 9th 03 01:02 AM
