In rec.aviation.piloting Tim Ward wrote:
wrote in message ... The advantage from the electric engine at cruise is that it uses zero energy. Snippage -- Jim Pennino Remove .spam.sux to reply. You want to support this, somehow? Tim Ward At cruise the electric motor is turned off. The only energy used is some slight bearing friction. The electric motor is only turned on when more power than the gas engine can provide is needed. -- Jim Pennino Remove .spam.sux to reply. |
In rec.aviation.piloting Charles Vincent wrote:
wrote: In rec.aviation.piloting Tim Ward wrote: wrote in message ... The advantage from the electric engine at cruise is that it uses zero energy. Snippage -- Jim Pennino Remove .spam.sux to reply. You want to support this, somehow? Tim Ward At cruise the electric motor is turned off. The only energy used is some slight bearing friction. The electric motor is only turned on when more power than the gas engine can provide is needed. To carry more weight at the same speed and altitude takes more power, so you have to account for the energy expended kiting you deadweight electric takeoff system around the sky as well. Sizing an engine for cruise has been done, if only backwards. Think JATO. Most JATO's are actually RATO (rocket assisted takeoff). I expect RATO would beat an electric system based on energy density and the fact that when it is done you have reduced your weight by the fuel. I also suspect for a given amount of thrust the rocket will be lighter than an electric motor and associated clutches and gearing. In my opinion, at this point in time it is just as practical for a homebuilt as well as in not. Well, that's true enough, but the above was about hybrid cars. -- Jim Pennino Remove .spam.sux to reply. |
In rec.aviation.piloting cavelamb himself wrote: wrote: To carry more weight at the same speed and altitude takes more power, so you have to account for the energy expended kiting you deadweight electric takeoff system around the sky as well. Sizing an engine for cruise has been done, if only backwards. Think JATO. Most JATO's are actually RATO (rocket assisted takeoff). I expect RATO would beat an electric system based on energy density and the fact that when it is done you have reduced your weight by the fuel. I also suspect for a given amount of thrust the rocket will be lighter than an electric motor and associated clutches and gearing. In my opinion, at this point in time it is just as practical for a homebuilt as well as in not. Well, that's true enough, but the above was about hybrid cars. No, it's not true enough. To carry more weight at the same speed and altitude requires more LIFT. A higher CL - and/or more wing area. THEN, to overcome the increased drag, THEN you need more power. But more power by itself won't satisfy the constraints... So if I add 1 pound to a 2400 pound gross aircraft loaded to 2300 pounds, it would be impossible to cruise at the same speed and altitude without the 1 pound unless I added wing area? How about 50 pounds? No. You can increase the angle of attack, which increases the lift ( to a limit) and also increases the drag, which must be overcome with more power. If your speed drops, so does the lift. If you could increase your aspect ratio, you could get more lift at the same speed at the same power I think. So I guess Richard is flying a swing wing texas parasol.;') For the rest of us, we have to add power to carry more weight at the same speed and altitude. Since most planes lose weight while in flight in the real world, you actually have the opposite issue. Charles |
wrote: In rec.aviation.piloting cavelamb himself wrote: wrote: To carry more weight at the same speed and altitude takes more power, so you have to account for the energy expended kiting you deadweight electric takeoff system around the sky as well. Sizing an engine for cruise has been done, if only backwards. Think JATO. Most JATO's are actually RATO (rocket assisted takeoff). I expect RATO would beat an electric system based on energy density and the fact that when it is done you have reduced your weight by the fuel. I also suspect for a given amount of thrust the rocket will be lighter than an electric motor and associated clutches and gearing. In my opinion, at this point in time it is just as practical for a homebuilt as well as in not. Well, that's true enough, but the above was about hybrid cars. No, it's not true enough. To carry more weight at the same speed and altitude requires more LIFT. A higher CL - and/or more wing area. THEN, to overcome the increased drag, THEN you need more power. But more power by itself won't satisfy the constraints... So if I add 1 pound to a 2400 pound gross aircraft loaded to 2300 pounds, it would be impossible to cruise at the same speed and altitude without the 1 pound unless I added wing area? How about 50 pounds? No. You can increase the angle of attack, which increases the lift ( to a limit) and also increases the drag, which must be overcome with more power. If your speed drops, so does the lift. If you could increase your aspect ratio, you could get more lift at the same speed at the same power I think. So I guess Richard is flying a swing wing texas parasol.;') For the rest of us, we have to add power to carry more weight at the same speed and altitude. Since most planes lose weight while in flight in the real world, you actually have the opposite issue. Gee, you mean all I gotta do is tweek the trim and throttle a bit? Who'd have guessed it? :-) -- Jim Pennino Remove .spam.sux to reply. |
No. You can increase the angle of attack, which increases the lift ( to a limit) and also increases the drag, which must be overcome with more power. If your speed drops, so does the lift. If you could increase your aspect ratio, you could get more lift at the same speed at the same power I think. So I guess Richard is flying a swing wing texas parasol.;') For the rest of us, we have to add power to carry more weight at the same speed and altitude. Since most planes lose weight while in flight in the real world, you actually have the opposite issue. Charles Don't be snotty, Charles. Since the subject is an electrically powered aircraft, the weight issue is not trivial. That's been my issue with this thread from the start. The constraints given here were to fly at the same speed and altitude but at a higher weright. You can increase lift via increased angle of attack only as far as CLmax. No Farther. (You seem to have that part right) Beyond that any increased weight will require increased wing area. Aspect ratio alone won't answer is most cases. And - an electric powered plane would NOT lose weight in flight. No electrons are "consumed" - no change in battery weight. |
wrote: To carry more weight at the same speed and altitude takes more power, so you have to account for the energy expended kiting you deadweight electric takeoff system around the sky as well. Sizing an engine for cruise has been done, if only backwards. Think JATO. Most JATO's are actually RATO (rocket assisted takeoff). I expect RATO would beat an electric system based on energy density and the fact that when it is done you have reduced your weight by the fuel. I also suspect for a given amount of thrust the rocket will be lighter than an electric motor and associated clutches and gearing. In my opinion, at this point in time it is just as practical for a homebuilt as well as in not. Well, that's true enough, but the above was about hybrid cars. No, it's not true enough. To carry more weight at the same speed and altitude requires more LIFT. A higher CL - and/or more wing area. THEN, to overcome the increased drag, THEN you need more power. But more power by itself won't satisfy the constraints... The original remark said "To carry more weight at the same speed and altitude takes more power" -- which you have now taken the time to substantiate with more detail. It never said it was the only factor, and didn't need to, to rebut the earlier claim. I do not understand how you arrive at it not being true. Frankly, I would expect any one engaged in building or flying an airplane to understand those relationships, and based on the FAA's published pilot exam questions and other materials, it seems they agree. Charles |
In rec.aviation.piloting Charles Vincent wrote: wrote: In rec.aviation.piloting Tim Ward wrote: wrote in message ... The advantage from the electric engine at cruise is that it uses zero energy. Snippage -- Jim Pennino Remove .spam.sux to reply. You want to support this, somehow? Tim Ward At cruise the electric motor is turned off. The only energy used is some slight bearing friction. The electric motor is only turned on when more power than the gas engine can provide is needed. To carry more weight at the same speed and altitude takes more power, so you have to account for the energy expended kiting you deadweight electric takeoff system around the sky as well. Sizing an engine for cruise has been done, if only backwards. Think JATO. Most JATO's are actually RATO (rocket assisted takeoff). I expect RATO would beat an electric system based on energy density and the fact that when it is done you have reduced your weight by the fuel. I also suspect for a given amount of thrust the rocket will be lighter than an electric motor and associated clutches and gearing. In my opinion, at this point in time it is just as practical for a homebuilt as well as in not. Well, that's true enough, but the above was about hybrid cars. Well in cruise in a car, more weight does not increase your aerodynamic drag like it does on an airplane, but it does increase your rolling resistance in the real world, so there is no free lunch. Different tradeoffs for different missions. I guess that is why cheetahs and sparrows look so different. Charles |
Electrically Powered Ultralight Aircraft | Larry Dighera | Piloting | 178 | December 31st 07 08:53 PM |
Solar powered aircraft. Was: Can Aircraft Be Far Behind? | Jim Logajan | Piloting | 4 | February 9th 07 01:11 PM |
World's First Certified Electrically Propelled Aircraft? | Larry Dighera | Piloting | 2 | September 22nd 06 01:50 AM |
Powered gliders = powered aircraft for 91.205 | Mark James Boyd | Soaring | 2 | December 12th 04 03:28 AM |
Help! 2motors propelled ultralight aircraft | [email protected] | Home Built | 3 | July 9th 03 01:02 AM |
