#41
#42
In rec.aviation.piloting Tim Ward wrote:
wrote in message ... The advantage from the electric engine at cruise is that it uses zero energy. Snippage -- Jim Pennino Remove .spam.sux to reply. You want to support this, somehow? Tim Ward At cruise the electric motor is turned off. The only energy used is some slight bearing friction. The electric motor is only turned on when more power than the gas engine can provide is needed. -- Jim Pennino Remove .spam.sux to reply. |
#43
Recently, Larry Dighera posted:
On Mon, 06 Aug 2007 18:22:41 -0700, James Sleeman wrote in .com: On Aug 7, 3:39 am, Larry Dighera wrote: Are external combustion engines as efficient as internal combustion engines? Stirling engines are great for converting waste heat to mechanical energy, but I'm not sure how appropriate they would be for aircraft propulsion. In theory, I think that stirling engines are quite well suited to aircraft, all it needs is a source of "hot" and a source of "cold", the cold is in abundance (stick a heatsink in the wind, higher you go, colder it gets, more power the engine can deliver, directly the opposite of IC), the hot could be provided with any number of combustables (and some oxygen delivery system). I see what you mean. Unfortunately, the highest power requirements of aircraft engines are during the takeoff and climb phases of flight. Power requirements are even greater when the ambient temperature rises resulting in less air density or a higher density altitude. That is when the most power is required for takeoff, but that would be a situation where the Stirling engine would have its minimum power production. If an engine's minimum power production is greater than the power required for takeoff, would it matter? It would seem that if this could be achieved, the operating conditions of the Stirling engine would be mostly understressed. I would also like to see a comparison of the efficiencies of IC and EC engines and their relative weight and size per horsepower compared. Unlike electrical motors, that must be constructed with heavy iron, IC and EC engines can be constructed of lighter materials like aluminum, but electrical motors are usually 80% to 95% efficient. With the Stirling aircraft engine there is a requirement for what I would imagine would be a large heat sink or heat exchanger located in the slip stream. The weight of this heat exchanger and its drag penalty must also be considered. Why couldn't the heat exchanger be an integral part of the airframe? Wings come to mind... ;-) There might be one advantage to using Sterling external combustion engines for aviation: the use of atomic energy as a fuel source if the weight of the lead shielding were not too great. Imagine an aircraft that effectively never runs out of fuel! There'd be no more fuel exhaustion mishaps. One downside would be the hazardous materials that could be dispersed in a crash. I'd like to see a prototype Stirling using conventional fuels before exploring more exotic options. Neil |
#44
On Tue, 7 Aug 2007 11:48:50 -0500, "Neil Gould"
wrote in : Recently, Larry Dighera posted: [snip] I see what you mean. Unfortunately, the highest power requirements of aircraft engines are during the takeoff and climb phases of flight. Power requirements are even greater when the ambient temperature rises resulting in less air density or a higher density altitude. That is when the most power is required for takeoff, but that would be a situation where the Stirling engine would have its minimum power production. If an engine's minimum power production is greater than the power required for takeoff, would it matter? Probably not, but it would mean you'd have significantly more power available at altitude if the Sterling engine were sized to provide takeoff power at high density altitudes. What I was getting at was the author of the articles emphasis on overcoming the reduced power output of IC engines at lower atmospheric pressure overlooks its possibly anemic performance (due to minimal air movement through the heat exchanger and higher ambient temperatures on the ground) when it is needed most, at takeoff. I find it revealing that the author failed to mention that point, and it reduces my confidence in the assertions he made in that article. It would seem that if this could be achieved, the operating conditions of the Stirling engine would be mostly understressed. I am unable to infer your meaning by that statement. Do you mean under emphasized or less mechanical stress on the engine, or what? I would also like to see a comparison of the efficiencies of IC and EC engines and their relative weight and size per horsepower compared. Unlike electrical motors, that must be constructed with heavy iron, IC and EC engines can be constructed of lighter materials like aluminum, but electrical motors are usually 80% to 95% efficient. With the Stirling aircraft engine there is a requirement for what I would imagine would be a large heat sink or heat exchanger located in the slip stream. The weight of this heat exchanger and its drag penalty must also be considered. Why couldn't the heat exchanger be an integral part of the airframe? Wings come to mind... ;-) I'm thinking there would be necessity for some means of conducting the heat from the engine to a remote heat exchanger, and the resulting complexity and weight increase would negatively impact the potential advantages of a Stirling aviation engine. In any event, in addition to the Stirling engine and its fuel, a heat exchanger of some type needs to factored into the weight, cost, performance, and efficiency equations. There might be one advantage to using Sterling external combustion engines for aviation: the use of atomic energy as a fuel source if the weight of the lead shielding were not too great. Imagine an aircraft that effectively never runs out of fuel! There'd be no more fuel exhaustion mishaps. One downside would be the hazardous materials that could be dispersed in a crash. There are a lot of down sides to atomic power, but NASA uses it to power Stirling engines in space. Here's some information about what NASA successfully has accomplished with nuclear power: http://www.grc.nasa.gov/WWW/tmsb/index.html The Thermo-Mechanical Systems Branch (5490) is responsible for planning, conducting and directing research and technology development to advance the state-of-the-art in a variety of thermal systems for space, aerospace, as well as non-aerospace applications. The systems of interest include thermal energy conversion for power systems and solar thermal propulsion systems. The effort involves working at the component level to develop the technology, the subsystem level to verify the performance of the technology, and the system level to ensure that the appropriate system level impact is achieved with the integrated technology. System analysis is used to identify high-impact technology areas, define the critical aspects of the technology that need to be developed, and characterize the system level impact of the technology. Specific technology areas of interest include: Dynamic Power Systems: Brayton, Rankine and Stirling Convertors, Solar Receivers and Thermal Energy Storage Primary Solar Concentrators: Thin film, SRP and Rigid Secondary Solar Concentrators: Refractive and Reflective Thermal Management: Radiators, Electronics Packaging, and Heat Pipe Technology http://www.grc.nasa.gov/WWW/tmsb/stirling.html Animation of a 55 We Stirling TDC (click on image to view) http://www.grc.nasa.gov/WWW/tmsb/sti...adisotope.html AVAILABLE TODAY FOR TOMORROW'S NEEDS NASA Glenn Research Center and the Department of Energy (DOE) are developing a Stirling convertor for an advanced radioisotope power system to provide spacecraft on-board electric power for NASA deep space missions. Stirling is being evaluated as an alternative to replace Radioisotope Thermoelectric Generators (RTGs) with a high-efficiency power source. The efficiency of the Stirling system, in excess of 20%, will reduce the necessary isotope inventory by a factor of at least 3 compared to RTGs. Stirling is the most developed convertor option of the advanced power concepts under consideration [1,2]. http://www.grc.nasa.gov/WWW/tmsb/sti...ng_bckgrd.html However, about this time NASA became interested in development of free-piston Stirling engines for space power applications. These engines use helium as the working fluid, drive linear alternators to produce electricity and are hermetically sealed. These 12.5 kWe per cylinder engines were intended for use with a nuclear reactor power system; the Space Demonstrator Engine (or SPDE) was the earliest 12.5 kWe per cylinder engine that was designed, built and tested by MTI. A later engine of this size, the Component Test Power Convertor (or CTPC), used a "Starfish" heat-pipe heater head, instead of the pumped-loop used by the SPDE. Recently, in the 1992-93 time period, this work was terminated due to the termination of the related SP-100 nuclear power system work and NASA's new emphasis on "better, faster, cheaper" systems and missions. http://www.spacedaily.com/news/outerplanets-00a2.html Europa Orbiter was replanned to use a new "Sterling" nuclear generator design which would use less plutonium http://www.cndyorks.gn.apc.org/yspac...heed_offer.htm Boeing, Lockheed Offer NASA Two Choices for Nuclear Power |
#45
![]() "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote in message ... Do me a favor Gattman. What is the weight of the most effeicent battery that could power an automobile at highway speed and how long will it do so and how long to recharge? Well, if I tried to answer that I'd sound like mx. I don't know what the "most efficient" battery is for that purpose. It's a hell of a lot heavier than the 250-250 pound machines I worked with. I think 4-6 SLAs--possibly the least efficient--would pull a vehicle, but I doubt it would make highway speed and if if it did it wouldn't be for more than a few minutes. Charge time for each battery would probably be a couple of hours, maybe longer. I bet it would weigh a hell of a lot more than a Rotax. Internal combustion is still the most bang for the buck this side of nuclear. I think the most realistic use of an electric motor in an aircraft would be in the context of something like a glider, for maintaining altitude or finding a thermal or just getting home. It would be fun to fly an ultralight around the pattern under electrical power, but I wouldn't stray very far. -c |
#46
On Tue, 7 Aug 2007 11:48:50 -0500, "Neil Gould" wrote: Recently, Larry Dighera posted: [snip] I see what you mean. Unfortunately, the highest power requirements of aircraft engines are during the takeoff and climb phases of flight. Power requirements are even greater when the ambient temperature rises resulting in less air density or a higher density altitude. That is when the most power is required for takeoff, but that would be a situation where the Stirling engine would have its minimum power production. If an engine's minimum power production is greater than the power required for takeoff, would it matter? Probably not, but it would mean you'd have significantly more power available at altitude if the Sterling engine were sized to provide takeoff power at high density altitudes. Exactly, but I don't see that as a negative... ;-) What I was getting at was the author of the articles emphasis on overcoming the reduced power output of IC engines at lower atmospheric pressure overlooks its possibly anemic performance (due to minimal air movement through the heat exchanger and higher ambient temperatures on the ground) when it is needed most, at takeoff. I find it revealing that the author failed to mention that point, and it reduces my confidence in the assertions he made in that article. I understand your perspective, which is what prompted my reply. If there is sufficient power to take off, then the issue should be moot, unless I'm overlooking something. It should be reasonable to presume that any practical aircraft engine would have sufficient power to take off, right? ;-) It would seem that if this could be achieved, the operating conditions of the Stirling engine would be mostly understressed. I am unable to infer your meaning by that statement. Do you mean under emphasized or less mechanical stress on the engine, or what? Less mechanical stress due to operating well below maximum power settings under normal cruise. That should provide plenty of reserve power at altitude and increase the fuel efficiency as well. I would also like to see a comparison of the efficiencies of IC and EC engines and their relative weight and size per horsepower compared. Unlike electrical motors, that must be constructed with heavy iron, IC and EC engines can be constructed of lighter materials like aluminum, but electrical motors are usually 80% to 95% efficient. With the Stirling aircraft engine there is a requirement for what I would imagine would be a large heat sink or heat exchanger located in the slip stream. The weight of this heat exchanger and its drag penalty must also be considered. Why couldn't the heat exchanger be an integral part of the airframe? Wings come to mind... ;-) I'm thinking there would be necessity for some means of conducting the heat from the engine to a remote heat exchanger, and the resulting complexity and weight increase would negatively impact the potential advantages of a Stirling aviation engine. In any event, in addition to the Stirling engine and its fuel, a heat exchanger of some type needs to factored into the weight, cost, performance, and efficiency equations. Of course, but I don't see a lot of reason why that couldn't be incorporated into the overall design. My point is that heat exchangers need not be heavy, and could probably double as structural and/or aerodynamic components, further reducing (and possibly enhancing) their impact. There might be one advantage to using Sterling external combustion engines for aviation: the use of atomic energy as a fuel source if the weight of the lead shielding were not too great. Imagine an aircraft that effectively never runs out of fuel! There'd be no more fuel exhaustion mishaps. One downside would be the hazardous materials that could be dispersed in a crash. There are a lot of down sides to atomic power, but NASA uses it to power Stirling engines in space. Understandable, but their expectation is that catastrophic destruction would disperse the nuclear material harmlessly. That can't be presumed for light aircraft. Neil |
#47
Gattman wrote:
"Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote in message ... Do me a favor Gattman. What is the weight of the most effeicent battery that could power an automobile at highway speed and how long will it do so and how long to recharge? Well, if I tried to answer that I'd sound like mx. I don't know what the "most efficient" battery is for that purpose. It's a hell of a lot heavier than the 250-250 pound machines I worked with. I think 4-6 SLAs--possibly the least efficient--would pull a vehicle, but I doubt it would make highway speed and if if it did it wouldn't be for more than a few minutes. Charge time for each battery would probably be a couple of hours, maybe longer. I bet it would weigh a hell of a lot more than a Rotax. Internal combustion is still the most bang for the buck this side of nuclear. I think the most realistic use of an electric motor in an aircraft would be in the context of something like a glider, for maintaining altitude or finding a thermal or just getting home. It would be fun to fly an ultralight around the pattern under electrical power, but I wouldn't stray very far. -c I understand and thank you for not MXing us. But the point isn't the weight of the battery as compaired to a Rotax or any other engine. The issue I had been getting at is the weight of the battery in comparison to the weight of full load of gasoline. Let's take my 601XL. 2 aluminum 12 gallon tanks each tank ways let's say 10 pounds add in 145 lbs of fuel and you have 165 pounds of transportable energy that will produce ~100HP for about 4 hours. My question to anyone is what is the lightest battery that is capable of powering any motor that will produce the equivilent power for and equal amount of time? |
#48
check out the article on regenerative soaring at www.esoaring.com I
think I may have heard that Taras Kiceniuk will be giving a talk on this subject at Tehachapi this Labor Day. He's been working on this idea for a while... Bill |
#49
In rec.aviation.piloting Gig 601XL Builder wrDOTgiaconaATsuddenlink.net wrote:
Gattman wrote: "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote in message ... Do me a favor Gattman. What is the weight of the most effeicent battery that could power an automobile at highway speed and how long will it do so and how long to recharge? Well, if I tried to answer that I'd sound like mx. I don't know what the "most efficient" battery is for that purpose. It's a hell of a lot heavier than the 250-250 pound machines I worked with. I think 4-6 SLAs--possibly the least efficient--would pull a vehicle, but I doubt it would make highway speed and if if it did it wouldn't be for more than a few minutes. Charge time for each battery would probably be a couple of hours, maybe longer. I bet it would weigh a hell of a lot more than a Rotax. Internal combustion is still the most bang for the buck this side of nuclear. I think the most realistic use of an electric motor in an aircraft would be in the context of something like a glider, for maintaining altitude or finding a thermal or just getting home. It would be fun to fly an ultralight around the pattern under electrical power, but I wouldn't stray very far. -c I understand and thank you for not MXing us. But the point isn't the weight of the battery as compaired to a Rotax or any other engine. The issue I had been getting at is the weight of the battery in comparison to the weight of full load of gasoline. Let's take my 601XL. 2 aluminum 12 gallon tanks each tank ways let's say 10 pounds add in 145 lbs of fuel and you have 165 pounds of transportable energy that will produce ~100HP for about 4 hours. My question to anyone is what is the lightest battery that is capable of powering any motor that will produce the equivilent power for and equal amount of time? If you go to http://xtronics.com/reference/energy_density.htm you find the energy densities of a lot of things. Propane (liquid) 13,900 Wh/kg Diesel 13,762 Wh/kg gasoline 12,200 Wh/kg Ethanol 7,850 Wh/kg Methanol 6,400 Wh/kg Secondary Lithium - ion Polymer 130 - 1200 Wh/kg Primary Zinc-Air 300 Wh/kg Lead Acid Battery 25 Wh/kg So batteries have to improve by a factor of 10 to match gasoline. -- Jim Pennino Remove .spam.sux to reply. |
#50
![]() "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote in message ... Let's take my 601XL. 2 aluminum 12 gallon tanks each tank ways let's say 10 pounds add in 145 lbs of fuel and you have 165 pounds of transportable energy that will produce ~100HP for about 4 hours. My question to anyone is what is the lightest battery that is capable of powering any motor that will produce the equivilent power for and equal amount of time? Well, depending on which end of the gearbox it's measured, 40+ pounds of NiCAD batteries got between 1-4 HP at maybe 70% motor power for 20 minutes max before the battery output began to taper off. For perspective, the Etek motor used on the ultralight in the link is probably about twice as powerful as the motors we were using, so maybe for a ballpark measurement I could double the battery time for the same weight. Theoretically if you managed and cooled your batteries correctly you could get ~30 minutes for that 40 pounds of batteries, or maybe two hours if you quadrupled it for your ~160 pounds. Max. Too much weight for an ultralight, and no way it's gonna get near 100HP. Again, that's just a ballpark estimate. -c |
Electrically Powered Ultralight Aircraft | Larry Dighera | Piloting | 178 | December 31st 07 08:53 PM |
Solar powered aircraft. Was: Can Aircraft Be Far Behind? | Jim Logajan | Piloting | 4 | February 9th 07 01:11 PM |
World's First Certified Electrically Propelled Aircraft? | Larry Dighera | Piloting | 2 | September 22nd 06 01:50 AM |
Powered gliders = powered aircraft for 91.205 | Mark James Boyd | Soaring | 2 | December 12th 04 03:28 AM |
Help! 2motors propelled ultralight aircraft | [email protected] | Home Built | 3 | July 9th 03 01:02 AM |
