WARNING: None of this is something that the FAA condones and may be
downright illegal. If the ship is "experimental" then you may have more leeway. A few comments; 1) The AV industry always use "gaffers" tape to affix things. This stuff is very good at keeping things stuck while still coming off cleanly. Think of this as really good cloth "duct" tape with a price to match. 2) Most external cameras I now see being used are "lipstick" cameras which are very small and have a much lower wind loading. These are small enough to be directly taped to the wing, tail, etc. They also have smaller lenses so they are less likely to get a bug in the face. They have video out so a cable must be routed back into the cockpit to a device to record the video. 3) Non-lipstick cameras have also been used. The advantage is that they are self contained cameras plus recorders. Anchoring is typically done by using a large-ish aluminum plate which wraps around the leading edge (wing or tail) and is held in place with gaffers tape. 4) Asymetrical wind loading by putting a large camera way out on a wing tip is something to avoid. 5) Don't' do this if there is even a hint of rain as this will distroy the camera in a hurry. - John |
Fixing brackets to new house walls | Michael Baldwin, Bruce | Products | 26 | January 18th 07 03:11 AM |
Fixing brackets to new house walls | Michael Baldwin, Bruce | Products | 0 | January 3rd 07 05:26 AM |
Fixing screw holes in fabric | Brian Huffaker | Home Built | 4 | May 21st 05 02:16 AM |
Tu-22M3 Backfire-C Fixing the Esci Kit | Ken Duffey | Military Aviation | 1 | December 11th 03 11:23 PM |
The joy of fixing 'repairs' | Michael | Owning | 3 | November 6th 03 05:47 PM |
