On Tue, 7 Aug 2007 14:51:55 -0500, "Gig 601XL Builder"
wrDOTgiaconaATsuddenlink.net wrote in : all this talk of electric airplanes while a nice thought is something that at best is way in the future. That's only true if you overlook Randall Fishman's electrically powered ultralight (http://www.electraflyer.com) and Mr. Monnett's Sonex proof-of-concept Waiex aircraft (http://www.sonexaircraft.com/press/r...r_072407.html). But, I know, you were referring to electrically powered aircraft with the same utility as today's GA aircraft, right? |
Larry Dighera wrote:
On Tue, 7 Aug 2007 14:51:55 -0500, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote in : all this talk of electric airplanes while a nice thought is something that at best is way in the future. That's only true if you overlook Randall Fishman's electrically powered ultralight (http://www.electraflyer.com) and Mr. Monnett's Sonex proof-of-concept Waiex aircraft (http://www.sonexaircraft.com/press/r...r_072407.html). But, I know, you were referring to electrically powered aircraft with the same utility as today's GA aircraft, right? Right. When the electric Sonex can do the same thing the VW powered Sonex can do then it will become something more than an interesting idea. |
On Aug 7, 3:04 pm, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net
wrote: Larry Dighera wrote: On Tue, 7 Aug 2007 14:51:55 -0500, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote in : all this talk of electric airplanes while a nice thought is something that at best is way in the future. That's only true if you overlook Randall Fishman's electrically powered ultralight (http://www.electraflyer.com) and Mr. Monnett's Sonex proof-of-concept Waiex aircraft (http://www.sonexaircraft.com/press/r...r_072407.html). But, I know, you were referring to electrically powered aircraft with the same utility as today's GA aircraft, right? Right. When the electric Sonex can do the same thing the VW powered Sonex can do then it will become something more than an interesting idea. I have not seen any significant flight duration claim on the Sonex, which speaks well for the design team. The 2 hours flight duration on the trike is IMO a gross exaggeration extrapolated from a much shorter actual time in thermal conditions. If the ability to get off the ground were the sole criteria we are there already but practical flight characteristics for mass consumption are way down the road. To be safe an aircraft needs a lot more power than the amount required to rise from the ground. My first home built ultralite was a 32 ft rigid wing using an IC engine of about 18hp and while it would fly the lack of climb ability was a big disadvantage. In marginal conditions it wouldn't lift beyond ground effect which resulted in interesting obstacle flights around trees and under power lines. It didn't take long for me to decide that my life was worth more than the 18hp engine and a new 30hp engine ultimately made for a much safer aircraft. |
"Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote:
I really hate to burst your bubble but, from the Sonex link above. "Initial top speeds will reach approximately 130 mph, and endurance is expected to range between 25-45 minutes or longer, depending upon power usage on each individual flight." Be sure to let us kneaux when it flies... As of OshGosh, it hadn't... |
On Aug 7, 3:49 pm, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net
wrote: wrote: On Aug 7, 3:04 pm, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote: Larry Dighera wrote: On Tue, 7 Aug 2007 14:51:55 -0500, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote in : all this talk of electric airplanes while a nice thought is something that at best is way in the future. That's only true if you overlook Randall Fishman's electrically powered ultralight (http://www.electraflyer.com) and Mr. Monnett's Sonex proof-of-concept Waiex aircraft (http://www.sonexaircraft.com/press/r...r_072407.html). But, I know, you were referring to electrically powered aircraft with the same utility as today's GA aircraft, right? Right. When the electric Sonex can do the same thing the VW powered Sonex can do then it will become something more than an interesting idea. I have not seen any significant flight duration claim on the Sonex, which speaks well for the design team. I really hate to burst your bubble but, from the Sonex link above. "Initial top speeds will reach approximately 130 mph, and endurance is expected to range between 25-45 minutes or longer, depending upon power usage on each individual flight."- Hide quoted text - - Show quoted text - I also read that but "Expected to be" isn't a claim and 45 minutes is not what I would call significant duration. |
On Wed, 08 Aug 2007 07:20:22 -0700, wrote in
.com: I have not seen any significant flight duration claim on the Sonex, which speaks well for the design team. I really hate to burst your bubble but, from the Sonex link above. "Initial top speeds will reach approximately 130 mph, and endurance is expected to range between 25-45 minutes or longer, depending upon power usage on each individual flight."- Hide quoted text - - Show quoted text - I also read that but "Expected to be" isn't a claim and 45 minutes is not what I would call significant duration. Would you characterize 12 seconds ad significant? http://www.thewrightbrothers.org/fivefirstflights.html The First Flight, spanning some 120 feet in 12 seconds. The next flight, Wilbur’s first flight on the 17th, extended to some 175 feet in 13 seconds and a landing was accomplished with no damage to The Flyer. Orville’s second attempt that day, and his last one in The Flyer, carried him just over 200 feet in 15 seconds and ended with a safe landing. At noon, Wilbur took-off on the last and the longest flight which The Flyer would ever make, and flew for 852 feet, staying aloft for 59 seconds. |
On Aug 8, 8:35 am, Larry Dighera wrote:
On Wed, 08 Aug 2007 07:20:22 -0700, wrote in .com: I have not seen any significant flight duration claim on the Sonex, which speaks well for the design team. I really hate to burst your bubble but, from the Sonex link above. "Initial top speeds will reach approximately 130 mph, and endurance is expected to range between 25-45 minutes or longer, depending upon power usage on each individual flight."- Hide quoted text - - Show quoted text - I also read that but "Expected to be" isn't a claim and 45 minutes is not what I would call significant duration. Would you characterize 12 seconds ad significant? http://www.thewrightbrothers.org/fivefirstflights.html The First Flight, spanning some 120 feet in 12 seconds. The next flight, Wilbur's first flight on the 17th, extended to some 175 feet in 13 seconds and a landing was accomplished with no damage to The Flyer. Orville's second attempt that day, and his last one in The Flyer, carried him just over 200 feet in 15 seconds and ended with a safe landing. At noon, Wilbur took-off on the last and the longest flight which The Flyer would ever make, and flew for 852 feet, staying aloft for 59 seconds. I guess I should have clarified that my comments refer to the here and now where 12 seconds and\or 45 minutes are both insignificant in terms of useful flight duration. While any duration is important the first time achieved it will only become marketable when it has reached a practical use point. Hopefully today's developments will lead to something in the future that is but for now they are interesting engineering experiments. Most people should and do applaud the efforts while some think the future is already here. For those adventurers we have $100,000 cars and underpowered trikes available right now. I'm going to hold off for a little while longer. |
On Wed, 08 Aug 2007 07:20:22 -0700, wrote in .com: I have not seen any significant flight duration claim on the Sonex, which speaks well for the design team. I really hate to burst your bubble but, from the Sonex link above. "Initial top speeds will reach approximately 130 mph, and endurance is expected to range between 25-45 minutes or longer, depending upon power usage on each individual flight."- Hide quoted text - - Show quoted text - I also read that but "Expected to be" isn't a claim and 45 minutes is not what I would call significant duration. Would you characterize 12 seconds ad significant? http://www.thewrightbrothers.org/fivefirstflights.html The First Flight, spanning some 120 feet in 12 seconds. The next flight, Wilbur's first flight on the 17th, extended to some 175 feet in 13 seconds and a landing was accomplished with no damage to The Flyer. Orville's second attempt that day, and his last one in The Flyer, carried him just over 200 feet in 15 seconds and ended with a safe landing. At noon, Wilbur took-off on the last and the longest flight which The Flyer would ever make, and flew for 852 feet, staying aloft for 59 seconds. I would now but when the best previous powered flight it was ZERO in both time and distance anything 0 was significant. And, unfortunately, for the electric powered airplane folks they have to be compared at least to what I can build in my garage and attach a 1960's vintage Corvair engine too. Sonex's electric airplane especially has to be judged against that criteria because they already make a plane that I can build in my garage and hang a Corvair engine on. |
http://www.thewrightbrothers.org/fivefirstflights.html The First Flight, spanning some 120 feet in 12 seconds. The next flight, Wilbur’s first flight on the 17th, extended to some 175 feet in 13 seconds and a landing was accomplished with no damage to The Flyer. Orville’s second attempt that day, and his last one in The Flyer, carried him just over 200 feet in 15 seconds and ended with a safe landing. At noon, Wilbur took-off on the last and the longest flight which The Flyer would ever make, and flew for 852 feet, staying aloft for 59 seconds. In 1903 it was but times change... Tony |
Electrically Powered Ultralight Aircraft | Larry Dighera | Piloting | 178 | December 31st 07 08:53 PM |
Electrically Powered Ultralight Aircraft | Larry Dighera | Home Built | 191 | August 21st 07 12:29 AM |
World's First Certified Electrically Propelled Aircraft? | Larry Dighera | Piloting | 2 | September 22nd 06 01:50 AM |
Powered gliders = powered aircraft for 91.205 | Mark James Boyd | Soaring | 2 | December 12th 04 03:28 AM |
Help! 2motors propelled ultralight aircraft | [email protected] | Home Built | 3 | July 9th 03 01:02 AM |
