props: tractor v pusher, q tip, ducted?
Old August 8th 07, 05:27 AM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Default props: tractor v pusher, q tip, ducted?
Charles Talleyrand wrote in
oups.com:
On Aug 7, 7:34 am, Bertie the Bunyip wrote:
The drag is induced by the cooling itself.
How can the drag be induced by the cooling itself?
If I understand
you, the same cowling with the same air flow shows significantly
different drag depending on whether the engine inside is hot or cold.
I honestly don't understand that.
Not what I mean. the flow inside is quite different with the prop
turning or not, though.
I'm away at the moment, but I'll look in my library when I get home for
a better definition than I can provide off the top of my head..K?
In any case, It's Cessna's claim nd not mine that cooling drag was
sorted on the airplane.
I also recently read an aricle in a very old Sport aviation about the
pros and cons of pusher/tractor arrangements. I can't remember if the
author came up with a definitive answer as to which was better or more
efficient, but I don#'t see how he could, really.
Bertie
monitoring pusher props Ernest Christley Home Built 11 May 16th 06 11:53 PM
Pusher props for WW I fighters John Bailey Military Aviation 3 September 11th 04 10:18 AM
Interested in Tractor vs. Pusher Gyroplane Dunewood Truglia, Esq. Rotorcraft 1 July 2nd 04 04:26 PM
1/2 VW and a shrouded/ducted propeller? BllFs6 Home Built 9 May 6th 04 05:33 AM
Ducted Fan Design David Home Built 5 February 7th 04 06:15 AM
