Electrically Powered Ultralight Aircraft
Old August 7th 07, 10:49 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Gig 601XL Builder
Default Electrically Powered Ultralight Aircraft
On Aug 7, 3:04 pm, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net
Larry Dighera wrote:
On Tue, 7 Aug 2007 14:51:55 -0500, "Gig 601XL Builder"
wrDOTgiaconaATsuddenlink.net wrote in
all this talk of electric airplanes while a nice thought is
something that at best is way in the future.
That's only true if you overlook Randall Fishman's electrically
powered ultralight (
http://www.electraflyer.com) and Mr. Monnett's
Sonex proof-of-concept Waiex aircraft
(http://www.sonexaircraft.com/press/r...r_072407.html).
But, I know, you were referring to electrically powered aircraft
with the same utility as today's GA aircraft, right?
Right. When the electric Sonex can do the same thing the VW powered
Sonex can do then it will become something more than an interesting
idea.
I have not seen any significant flight duration claim on the Sonex,
which speaks well for the design team.
I really hate to burst your bubble but, from the Sonex link above.
"Initial top speeds will reach approximately 130 mph, and endurance is
expected to range between 25-45 minutes or longer, depending upon power
usage on each individual flight."
Old August 8th 07, 02:16 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Darrel Toepfer
Be sure to let us kneaux when it flies...
As of OshGosh, it hadn't...
Old August 8th 07, 03:20 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
On Aug 7, 3:49 pm, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net
powered ultralight (http://www.electraflyer.com) and Mr. Monnett's
idea.
usage on each individual flight."- Hide quoted text -
- Show quoted text -
I also read that but "Expected to be" isn't a claim and 45 minutes is
not what I would call significant duration.
Old August 8th 07, 03:35 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Larry Dighera
On Wed, 08 Aug 2007 07:20:22 -0700, wrote in
.com:
Would you characterize 12 seconds ad significant?
http://www.thewrightbrothers.org/fivefirstflights.html
The First Flight, spanning some 120 feet in 12 seconds. The next
flight, Wilbur’s first flight on the 17th, extended to some 175
feet in 13 seconds and a landing was accomplished with no damage
to The Flyer. Orville’s second attempt that day, and his last one
in The Flyer, carried him just over 200 feet in 15 seconds and
ended with a safe landing. At noon, Wilbur took-off on the last
and the longest flight which The Flyer would ever make, and flew
for 852 feet, staying aloft for 59 seconds.
Old August 8th 07, 04:36 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
.com:
flight, Wilbur's first flight on the 17th, extended to some 175
to The Flyer. Orville's second attempt that day, and his last one
I guess I should have clarified that my comments refer to the here and
now where 12 seconds and\or 45 minutes are both insignificant in terms
of useful flight duration. While any duration is important the first
time achieved it will only become marketable when it has reached a
practical use point. Hopefully today's developments will lead to
something in the future that is but for now they are interesting
engineering experiments. Most people should and do applaud the efforts
while some think the future is already here. For those adventurers we
have $100,000 cars and underpowered trikes available right now.
I'm going to hold off for a little while longer.
Old August 8th 07, 04:55 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Gig 601XL Builder
.com:
is expected to range between 25-45 minutes or longer, depending
upon power usage on each individual flight."- Hide quoted text -
I would now but when the best previous powered flight it was ZERO in both
time and distance anything 0 was significant. And, unfortunately, for the
electric powered airplane folks they have to be compared at least to what I
can build in my garage and attach a 1960's vintage Corvair engine too.
Sonex's electric airplane especially has to be judged against that criteria
because they already make a plane that I can build in my garage and hang a
Corvair engine on.
Old August 8th 07, 05:26 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Larry Dighera
On Wed, 8 Aug 2007 10:55:38 -0500, "Gig 601XL Builder"
.com:
Corvair engine on.
Electrically powered flight is in its infancy just as powered flight
was in 1903.
Old August 8th 07, 07:36 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Gig 601XL Builder
was in 1903.
That matters not. It still has to be compared to what it is supposed to
replace. Would you want an electric car that was the technological equal to
this? http://www.ausbcomp.com/~bbott/cars/cugnot.jpg.
The otherside of that is that we can expect to wait until 2110 for electric
flight to catch up to where we are now with gasoline powered flight.
Old August 8th 07, 08:28 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Anthony W
In 1903 it was but times change...
Tony
Electrically Powered Ultralight Aircraft Larry Dighera Piloting 178 December 31st 07 08:53 PM
Electrically Powered Ultralight Aircraft Larry Dighera Home Built 191 August 21st 07 12:29 AM
World's First Certified Electrically Propelled Aircraft? Larry Dighera Piloting 2 September 22nd 06 01:50 AM
Powered gliders = powered aircraft for 91.205 Mark James Boyd Soaring 2 December 12th 04 03:28 AM
Help! 2motors propelled ultralight aircraft [email protected] Home Built 3 July 9th 03 01:02 AM
